Old 11-22-2012, 04:47 PM   #751
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,362
Originally Posted by RideFreak View Post
I do the z setting with the rings off, figure out the gaskets and install the rings just prior to final reassembly. I've seen a ring compressor that would work on the 300 (about 1/2" top to bottom) but truthfully once you figure the cyl install out, proper installation takes a couple seconds. Now the piston pin clips are a different story, the stock KTM units are a huge PITA. Why did they go away from the old style that worked with a pair of needle nose plyers.
Yeah I know, the old ones are still available.
My hardest cyl install was a VW waterboxer, seperate cyl liners that fit down into a non removable waterjacket that pretty much blocks all access for a mortal like me.
Damn...that is genius. I should have thought about doing the Z gap setting with out the rings in the piston. That has just changed how I will do top ends forever.
Probably would have saved the issue I have now. ( bangs head on wall)
Thanks for the tip RF.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 11-23-2012, 02:18 PM   #752
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,362
Found where my compression went.
Not 100% sure what scratched it. Rings seemed to be correct spot and not broken at all. Cylinder looks worse than piston too. ????
Sent from my DROIDX using Tapatalk
Old 11-23-2012, 03:00 PM   #753
Wallace
Seat belt tight babe?
Wallace's Avatar
Oddometer: 833
Looks like a cold seize.
Do you support the sport? How do you give back?
Wallace is offline   Reply With Quote
Old 11-23-2012, 03:39 PM   #754
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,362
Cold seize?? Please define. I am somewhat new to 2T's, and have never heard that term.
This is piston:
other side:
head seemed to be in good shape:
So, what is opinion on best method to get this fixed?? Powerseal USA weld, rebore and Nikasil again??? Eric Gorr Iron sleeve and overbore( that is what I had on YZ125)???
Old 11-23-2012, 04:11 PM   #755
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,478
It looks like something got caught in there, the grooves look pretty deep for just a siezeure. To me it looks like whatever did that caused the ring lands to lock the rings up against the piston resulting in blowby. It that point it's a lit fuse.
The cyl grooving looks pretty deep, I don't think you'll get away with relining the cyl. I've heard they can can do a weld repair of some types of damage prior to recoating it.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 11-23-2012, 04:25 PM   #756
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,362
Yeah, looking at powerseal pricing now. looks like it will be a weld repair, rehone, and new nikasil coating.
I also just pryed rings off piston. Looked like they were lined up right and pins did not fall out or break off.
Still not sure what caused the really deep scratches.
Old 11-23-2012, 04:41 PM   #757
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,478
Was the motor open awhile? It almost looks like something came up from the bottom end, possibly something that fell into the motor. The problem with that scenero is the item in question, is it still there, are there more pieces? The fact that the head looks fine sort of goes against that theory. Usally you'll see where gouges and pits develop in the head if there's something bouncing around in there.
Chris
Old 11-23-2012, 04:42 PM   #758
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,170
Did you drop something in the bottom when you were in there? Old circlip or something???
It almost looks like something came up through the transfer port.
Gordy is offline   Reply With Quote
Old 11-23-2012, 05:17 PM   #759
Just John
Oddometer: 172
Piston appears to be scored from one side to the other. Like it was too tight to the bore.
Or it got very hot very rapidly.
Was there coolant in the bike ?
Did you heat cycle it ?
Just John is offline   Reply With Quote
Old 11-23-2012, 05:18 PM   #760
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,478
Beat ya to it by 60 sec
Chris
Old 11-23-2012, 05:22 PM   #761
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,170
. At any rate, he might want to find a new mechanic.
Sorry, but that just shouldn't happen to a fresh rebuild.
Old 11-23-2012, 06:27 PM   #762
JTucker
JTucker's Avatar
Oddometer: 2,271
I've seen powerseal fix worse, that almost looks like a circlip came out but it's obviously still in there. Definitely check the bottom end out for loose parts.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 11-23-2012, 06:30 PM   #763
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,362
Thanks for the support...or lack there of.
The motor was not open for any length of time....only when working on it.
Nothing was dropped in there, as far as I know. No missing parts, clips, etc. Everything is accounted for.
There was coolant in bike. heat cycled, as as I did on the other rebuilds. Only other thing than the previous, those were done in heat of summer, and this was during colder, more recent weather.
Basically, I did nothing different than I did on previous top end rebuilds. Makes it that much more baffling.
Old 11-23-2012, 07:45 PM   #764
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,589
Check with Lancourt. I had them weld a deep groove in a cylinder and replate.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 11-26-2012, 04:55 AM   #765
Just John
Oddometer: 172
Is that plug gray ?
W brand piston ?
Times are GMT -7.   It's 08:34 AM.
