11-22-2012, 04:47 PM
#751 | |
Lacks Freetime
Oddometer: 4,922
Probably would have saved the issue I have now. ( bangs head on wall) Thanks for the tip RF.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
11-23-2012, 02:18 PM
#752 |
Lacks Freetime
Oddometer: 4,922
Found where my compression went.
![]() Not 100% sure what scratched it. Rings seemed to be correct spot and not broken at all. Cylinder looks worse than piston too. ???? Sent from my DROIDX using Tapatalk
11-23-2012, 03:00 PM
#753 |
Seat belt tight babe?
Oddometer: 815
Looks like a cold seize.
Do you support the sport? How do you give back? |
11-23-2012, 03:39 PM
#754 |
Lacks Freetime
Oddometer: 4,922
Cold seize?? Please define. I am somewhat new to 2T's, and have never heard that term.
This is piston: ![]() ![]() other side: ![]() head seemed to be in good shape: ![]() So, what is opinion on best method to get this fixed?? Powerseal USA weld, rebore and Nikasil again??? Eric Gorr Iron sleeve and overbore( that is what I had on YZ125)???
11-23-2012, 04:11 PM
#755 |
Torque Junkie
Oddometer: 3,561
It looks like something got caught in there, the grooves look pretty deep for just a siezeure. To me it looks like whatever did that caused the ring lands to lock the rings up against the piston resulting in blowby. It that point it's a lit fuse.
The cyl grooving looks pretty deep, I don't think you'll get away with relining the cyl. I've heard they can can do a weld repair of some types of damage prior to recoating it. |
11-23-2012, 04:25 PM
#756 |
Lacks Freetime
Oddometer: 4,922
Yeah, looking at powerseal pricing now. looks like it will be a weld repair, rehone, and new nikasil coating.
I also just pryed rings off piston. Looked like they were lined up right and pins did not fall out or break off. Still not sure what caused the really deep scratches.
11-23-2012, 04:41 PM
#757 | |
Torque Junkie
Oddometer: 3,561
11-23-2012, 04:42 PM
#758 |
Team Listo
Oddometer: 18,300
Did you drop something in the bottom when you were in there? Old circlip or something???
It almost looks like something came up through the transfer port.
11-23-2012, 05:17 PM
#759 |
Oddometer: 149
Piston appears to be scored from one side to the other. Like it was too tight to the bore.
Or it got very hot very rapidly. Was there coolant in the bike ? Did you heat cycle it ? |
11-23-2012, 05:18 PM
#760 | |
Torque Junkie
Oddometer: 3,561
11-23-2012, 05:22 PM
#761 |
Team Listo
Oddometer: 18,300
11-23-2012, 06:27 PM
#762 |
Oddometer: 1,815
I've seen powerseal fix worse, that almost looks like a circlip came out but it's obviously still in there. Definitely check the bottom end out for loose parts.
http://www.ktm-parts.com 03 Aprilia Caponord 06 Buell XB12X 05 XR650R 05 WR450F 87 T-dub |
11-23-2012, 06:30 PM
#763 |
Lacks Freetime
Oddometer: 4,922
Thanks for the support...or lack there of.
![]() The motor was not open for any length of time....only when working on it. Nothing was dropped in there, as far as I know. No missing parts, clips, etc. Everything is accounted for. There was coolant in bike. heat cycled, as as I did on the other rebuilds. Only other thing than the previous, those were done in heat of summer, and this was during colder, more recent weather. Basically, I did nothing different than I did on previous top end rebuilds. Makes it that much more baffling.
11-23-2012, 07:45 PM
#764 | |
Scone Rider
Oddometer: 6,719
Check with Lancourt. I had them weld a deep groove in a cylinder and replate.
We don't stop riding because we get old, we get old because we stop riding. |
11-26-2012, 04:55 AM
#765 |
Oddometer: 149
Is that plug gray ?
W brand piston ? |
