11-23-2012, 05:10 PM
#1 |
Aspiring Adventurer
Oddometer: 281
Helicoil or TimeCert for valve covers?
I need to do five of these things and wasn't sure if one was better than the other. It looks like the helicoil is actually a coil of steel whereas the timecert is an actual threaded barrel of sorts. ~$25 for the helicoil vs ~$60 for the timecert.
Any insight would much appreciated. |
11-23-2012, 05:28 PM
#2 |
Oddometer: 59
Timecerts are better then Helicoil, but for a bolt that does not have to hold a lot of torque, you are probably just fine with the Helicoils. Anything that needs to hold more torque, I would rather trust a Timecert.
11-23-2012, 06:38 PM
#3 |
Grumpy Old Goat
Oddometer: 4,363
I have Helicoils in one of the caliper mounts on my truck. It's low (ish) torque, at 28 ft / lbs. but has held well.
No experience with TimeSerts or the respective torque they will handle.
I found Jesus. He was behind the sofa the whole time. 1996 M900, "Patience" 2012 GS "Sonar" 2008 Megamoto "Big Blue" 2008 S2R "WTF" |
11-23-2012, 08:08 PM
#4 |
Oddometer: 391
I had to repair about 7 holes when i first got my old 1100GS (previous owner was a HACK.)
I used Heli-coils as that was what I had in the tool box at the time, never had a problem, nothing backed out. Two valve cover bolts on one head and 3 on the other as well as two exhaust holes stripped. Worked for me |
11-23-2012, 08:27 PM
#5 | |
Aspiring Adventurer
Oddometer: 281
11-23-2012, 08:40 PM
#6 | |
Oddometer: 2,418
http://www.youtube.com/watch?v=Gxnm8J9WXz8 |
11-23-2012, 09:00 PM
#7 |
Aspiring Adventurer
Oddometer: 281
Good video
They both look like good options for the valve covers. My left side is currently blowing hot air/oil out the top.
11-23-2012, 09:08 PM
#8 |
Oddometer: 4,440
timecerts are not "better", only different. helicoils have been used on aircraft engines for new installation as well as certified repair for at least 60-70 years. I have 36 years as an aircraft mechanic... never seen a properly installed helicoil fail. to install a timesert you have to drill a bigger hole in the parent metal
11-23-2012, 09:46 PM
#9 | |
Aspiring Adventurer
Oddometer: 281
11-24-2012, 03:30 AM
#10 | |
Ex Coelis
Oddometer: 504
35 years of tool and die making has let me replaces 1000's of threads that people have stripped. As Beezer says...Helicoil is the King. But watch the video Laurel perry posted. There is a whole tool kit you need to install a Timesert $$$ IMHO #1. Helicoil - strong threads and minimal toolkit 2. Keensert(self locking) - installs with a standard tap set. see link http://www.newmantools.com/kee.htm 3. Timset - Good but lotsa tools req'd
I do not intend to tiptoe through life, only to arrive safely at death |
11-24-2012, 06:00 AM
#11 |
SWM Adventuer
Oddometer: 4,153
Another vote for Timesert. I was told you have to drill a smaller hole then a Heli Coil to install, so is a plus where there is not allot of extra material. Looks much better for a bolt that will see frequent removal as well because it locks in place. If you go for timesert, be sure to get the right length. You need around 5mm of depth past the Timesert to allow the installation tool to travel deep enough to lock the insert in place.
11-24-2012, 08:20 AM
#12 |
I have little to say
I used Helicoils when repairing the threads on old Brit bike cylinder heads. Never a failure. No special tools just a bit of care.
11-24-2012, 08:27 AM
#13 | |
11-24-2012, 11:10 AM
#14 |
"Cool" Aid!
Oddometer: 41,494
I've repaired dozens of valve cover threads with Helicoils, never an issue. It is simple, easy to do freehand, and holds the minimal 8nm of torque just fine.
I've used Helicoils on head studes and brake calipers with no issues as well. Jim
11-24-2012, 12:08 PM
#15 |
Aspiring Adventurer
Oddometer: 281
Expensive kit
The kit with tap, tool and 12 inserts is $40. Do I need the tool?
