11-23-2012, 06:59 PM
#17026 |
projects > time alloted
Oddometer: 79
Well the project 900 dollar drz was sold before I called the guy....so I went to the dealer and bought a new black 2012 drz400s...... I'll pick it up tomorrow :) already have a jet kit en route...gonna see if I can get the dealer to knock a good chunk off a full system...most likely the yoshi. Excited to own another drz...yippppppeeeeeeeee
11-23-2012, 07:23 PM
#17027 |
KLR Carter
Oddometer: 13
Does UFO make make headlight shrouds and where can I find one ? I'm also needing a GPS that I can down load tracks.......I'm not a comp whizz .
11-23-2012, 08:34 PM
#17028 | |
Oddometer: 1,692
I have a Nikon FM and a D3X (amongst others) and I use the FM with CZ lenses by choice.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
11-24-2012, 06:46 AM
#17029 | |
Tundra Thumper
Oddometer: 2,227
Easy peasy, does tracks and routes Garmin GPSMAP 60CSx Handheld GPS Navigator google is your friend............................
DONATE TO ADVRider sidestandup.com ridedualsport.com motoboss-terlingua-bound.blogspot.com MSF Rider Coach-Rider's Edge Instructor-Track Coach |
11-24-2012, 07:17 AM
#17030 |
Oddometer: 16
[QUOTE=150ron;20103135]Well its a $3.99 a quart vs $11.99+ a quart, so 8 dollar oil change vs a 25 dollar oil change, but yeah i see your point for sure.
I meant the difference in the valvoline and the Rotella T6 full synthetic. Rotella is only a couple bucks more. It does not say anything about motorcycles on it, it can be found on the automotive aisle, but I have had extremely good luck with it. |
11-24-2012, 10:54 AM
#17031 |
ride2discover
Oddometer: 3,180
From a ride past summer in Northern AZ, mixed terrains. Bit more rocky but it got rockier
later that day ![]() 230 MILES OFF-RD/DAY/3
DR-Z400E 00 - DR650SE 02. Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY". |
11-24-2012, 11:03 AM
#17032 | |
Oddometer: 434
![]() Thats the video do you have it
A good time to keep your mouth shut is when you’re in deep water! DRZ400S BMW R100/7 BMW1150GS Yamaha TY 175 trials KLR650sold |
11-24-2012, 11:31 AM
#17033 |
ride2discover
Oddometer: 3,180
I posted it way back in May, go back few posts
...Or lemme find one similar where i hit the same terrains but different date.
11-24-2012, 11:39 AM
#17034 |
ride2discover
Oddometer: 3,180
Here u go that's part of it, we did that a year ago but when i did it again back in May it was way worse, erroded from last winter. I almost ate it once
![]() but that stabilizer saved my a$$. ![]() GRANDE FALL RIDE2-2
11-24-2012, 12:55 PM
#17035 | |
Oddometer: 434
been suffering withdrawal since the snow started round here and its down to minus degrees Celsius these days ![]() Gotta wait till May now unless the roads improve April or I trailer down south. Thanks for this ![]()
11-24-2012, 01:24 PM
#17036 | |
ride2discover
Oddometer: 3,180
. Got to give up downHill skiing though, oh well i can still go downhill on a DRZ
11-24-2012, 01:49 PM
#17037 |
Oddometer: 366
Clutch pull
Seams like my clutch pull has gotten hard as a rock anything specific on these to cause this? I figure the baskets is getting notched was sure if there would be another cause. I already changed the cable but it made no difference
11-24-2012, 02:49 PM
#17038 |
ride2discover
Oddometer: 3,180
I saw 1 case similar when piece of the bascket broke (very tiny piece) and got jammed in one the clutch spring. So the safest assumption is to open it & take a look u might only have to replace the basket. A good clutch w/hd springs runs about $60 to $100 on ebay, no need to over spend.
11-24-2012, 04:54 PM
#17039 |
Oddometer: 816
Tested out the range of my IMS 3.2 gallon fuel tank today,
170 miles and it ran out of gas switched to reserve at 170 miles, ran out of gas at 186 miles, so 16 miles on reserve, 186 totall miles, i was able to fit 3.4 gallons in there, so im pretty happy with that milage, i did have to do a 1/4 miles walk of shame to the gas station tho, when the reserve ran out made to sure to leave the helmet on, so noone recongnizes me
Just some dude... |
11-24-2012, 05:54 PM
#17040 | |
ride2discover
Oddometer: 3,180
