Old 08-28-2012, 08:52 AM   #211
johnbo
Oddometer: 24
Pissed How to get in touch with Continental?
Anyone know of a US number to contact Continental? All I'm finding are numbers and addresses in Germany. I'll be there in a month, but won't have much time (nor the ability to speak enough German) to work with then.
Thanks,
johnbo
John D. Bowne
Cornelius, Oregon
johnbo is offline   Reply With Quote
Old 08-28-2012, 09:04 AM   #212
Bell driver
Bell driver's Avatar
Oddometer: 371
http://www.conti-online.com/generato...safety_de.html
http://automotive-industry-facts.com...ration_474.htm
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver is offline   Reply With Quote
Old 10-16-2012, 01:11 AM   #213
lotoofla
Oddometer: 3
Laugh Getting some traction on a bmw r1200rt
While you may wonder why a guy who rides a BMW R1200RT touring bike is responding about the Conti Trail Attack, it's because I've been were the road ends, and the dirt begains. I can assure you that this is not by design, but how the various State, and County highway depts run. On my maiden trip in spring 2011 to cross the norther part of the USA on US High Way 2, I ran out of pavement in Montana for 20 miles (about 30 Km), mud, pot holes, and ruts were the norn, and it was slow going. I was using dunlops D616 tires http://www.dunlopmotorcycle.com/tire...ce/sport/d616/ they did a good job but the rear wore out at 6,000 (10,000Km) I tried Pirreli's Scorpion Trail, but did a little better milage wise. Now I'm testing the Conti Trail Attack. I have over 2,000 (3,000Km)miles on them, and wearing very well. The embossed lettering on the tread for the rear tire is half way worn off, and the front tires lettering is still completely there. Continental makes the KTC's in my size 120/70x17 F 180/55x17 R but that's gross over kill for a touring bike. I like the extream lean angles, braking, and running in the rain, I can't report on accleration, as the Beemer has Traction Contol (no wheelies). Running in dry dirt the tires are very good, but I don't have any mud experience with them. You said that your front tire was made in Korea, and the rear in Germany, it got me curious about were mine can from, and both came from Germany. The tire pressures I'm running are 32 PSI front, and 30 PSI in the rear (sorry no metric equivalent) 30 PSI is 6 pounds under factory recomended pressures, but this has shown me to be near ideal, and I suspect that 31 PSI to be perfect, but mileage will tell.
lotoofla is offline   Reply With Quote
Old 10-16-2012, 07:34 AM   #214
DIRTSCOOTER
DIRTSCOOTER's Avatar
Oddometer: 118
My 2cts
I've had two pairs of Conti Attacks, I like them a lot. Millage has been about 13 or 14 k, my only complaint is that the front tire does not have a lot of tread depth so when the dirt gets a little wet, the front tire becomes a slick. Oh, I'm riding an '09 1200GSA, if that means anything.
Exercise your mind and motorcycle frequently.
2013 Triumph Trophy
'05 drz s/sm
DIRTSCOOTER is offline   Reply With Quote
Old 10-16-2012, 04:27 PM   #215
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,430
Great on pavement. Bad on dirt, rocks, etc. Great in rain.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 10-17-2012, 02:23 PM   #216
Snownut
Snownut's Avatar
Oddometer: 75
I have had a few TA rears and was very happy with them, I did have the wobble with the front but because I bought it during the winter and didn't get it installed until March Jake Wilson told me to pack sand.. I dealt with it but wasn't happy about it..
Sometimes the best discovery is to find we are lost...
Snownut is online now   Reply With Quote
Old 10-18-2012, 07:10 AM   #217
DIRTSCOOTER
Oddometer: 118
wobble
Originally Posted by HelmetHead Cycle View Post
I am also debating whether or not to go back to the Conti TA. If I knew for sure the shimmy problem has been resolved or not. Any more problems on recent purchases? I ride an 08 BMW GS Adventure. Loved the tire - hated the wobble.
I have had a wobble at slow speeds off throttle below 30mph, at first I thought it was the bike, the tech at the dealer said it might be the tires. It was the same on the second set that I bought, It never was troublesome to me, I tried changing pressures to no avail.
2013 Triumph Trophy
'05 drz s/sm
Old 11-21-2012, 11:54 PM   #218
Two Plugs
Two Plugs's Avatar
Oddometer: 1,411
Hold your horses... New Trail Attack 2 early 2013
@ All,
The Dutch Conti importer has just announced the new Conti Trail Attack 2 by early 2013.
Here's the English translation from the press release:
Continental presents the Conti Trail Attack 2, the second generation of the motor tire specially designed for large and high-performance travel enduros. The Conti Trail Attack 2 features an innovative new rubber compound. The result: optimum grip, short braking distances and long life. Brands like BMW and KTM use the Conti Trail Attack 2 already the first mounting band for new top models.
The Conti Trail Attack 2 has all the good qualities of its predecessor.
He makes use of an innovative new compound technology.
Some special features:
- Optimal performance and traction on dry and wet roads
- High degree of stability and comfort
- Longer life
- Short running-thanks Traction Skin Technology
- Continuous Compound Technology
- 0 steel belt construction
Initial assembly with top brands
With all his good qualities, the new Conti Trail Attack 2 already approved as original equipment tire for several top-enduros from several leading brands. Assembles the new KTM enduro tire factory instance on the 2013 models Adventure Adventure T and R. BMW has the Conti Trail Attack 2 designated as original equipment tire for its newly introduced new flagship enduro R 1200 GS.
The Conti Trail Attack 2 is available from early 2013.
Bernard 'Two Plugs', NL
Honda XL1000V Varadero & VFR1200X Crosstourer Forum www.vci-forum.com
22-25 May 2015: 17th Varadero & 4rd Crosstourer International Meeting, Milau, France!
Two Plugs is offline   Reply With Quote
Old 11-22-2012, 06:52 AM   #219
JRWooden
Oddometer: 4,311
Sounds interesting ....
If anybody sees a tread picture please post?
Old 11-22-2012, 03:12 PM   #220
10/10ths
Road Trip Fool
10/10ths's Avatar
Oddometer: 1,003
Sounds like....
....same improvements made to the Conti Road Attack IIs I have on my V-Strom.
The "Traction skin" is great, no mold release compound on new tires.
1997 Ducati Monster 750
2004 Honda RC51
2011 Suzuki GSX1250FA replaced my '04 Wee 2-14
10/10ths is offline   Reply With Quote
Old 11-22-2012, 11:25 PM   #221
Two Plugs
Two Plugs's Avatar
Oddometer: 1,411
Exactly. It was just a matter of time that Conti would reveal the Trail Attack II after the succesfull introduction of the Road Attack II.
Old 11-23-2012, 07:15 AM   #222
Snownut
Snownut's Avatar
Oddometer: 75
http://www.nieuwsmotor.nl/motornieuw...-attack-2.html
Old 11-23-2012, 08:59 PM   #223
JRWooden
Oddometer: 4,311
Originally Posted by snownut View Post
thanks! :-)
Old 11-24-2012, 11:11 PM   #224
HelmetHead Cycle
Oddometer: 308
I don't see what the difference is between the original and the "TA-2". Looks the same and the specs seem to be the same. Anybody know what the difference is supposed to be other than a "new and improved" marketing ploy?
HelmetHead Cycle is offline   Reply With Quote
Old 11-25-2012, 06:18 AM   #225
Two Plugs
Two Plugs's Avatar
Oddometer: 1,411
Read the comments about the differences between the Conti Road Attack vv the new Road Attack 2 and you will learn its more than just a marketing ploy...
Times are GMT -7.   It's 10:15 AM.
