Old 11-21-2012, 05:36 PM   #1
sleevedout OP
Oddometer: 26
New Guy Introduction
Well hello all. I thought I would introduce myself and what I'm up to.
I just registered for this site as I just recently purchased my first BMW as my next project. I moved from Wisconsin to England in July and upon moving here got my next project.
Well I'll let the pictures speak for themselves. Its was a 1987 BMW R80RT that the previous owner thought would look great as a welded together attempt at a chopper that I'm trying to straighten out.
In the back of a VW Passat Estate
Condition I bought it in
Half an hour later
mock ups
Gas Tank the bike came with
Moved into new house/home for bike
Got new front end
sleevedout is offline   Reply With Quote
Old 11-21-2012, 10:38 PM   #2
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 766
Hi Sleevedoubt,
Welcome to the site and to England, I hope your getting on alright on the wrong side of the road and working with spanners not wrenches.
That looks like a bit of a challenge, it is amazing what some people think looks good.
A tip, if anybody says something that doesn't make sense they are either making a joke or from up north, you will get the hang of which it is.
Mark
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is offline   Reply With Quote
Old 11-21-2012, 11:22 PM   #3
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 896
Nice! I love the tracker bars and the USD forks. What tank is that you're putting on there ( the yellow one ) and what was the mock up tank?
Kt-88 is offline   Reply With Quote
Old 11-21-2012, 11:23 PM   #4
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 896
Also, is that a hole in the valve cover?
Old 11-21-2012, 11:48 PM   #5
ontic
Oddometer: 1,070
At least the purists aren't going to hassle you to keep it stock
What is the front end off? Big brakes!
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 11-22-2012, 01:54 AM   #6
sleevedout OP
Oddometer: 26
Thanks guys.
Yellow tank I got for 10 and is a Norton Jubilee, black tank it came with I have no idea but its gonna be my new rear cowl.
Front end is Triumph yokes with Kawasaki ZX9R forks, wheel, and brakes.
Yes there's a valve cover hole from where the previous owner dropped bike then it appears he tried to stick weld the hole together.
I don't mind driving here in England, and I think roundabouts are better than traffic lights, I just wish my area had as many Autojumbles as it seems the north gets.
Cheers
Trevor
Old 11-22-2012, 11:49 AM   #7
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
What were you thinking? The whole country to choose from and you went south!! It's not too late to move.
Rob Farmer is offline   Reply With Quote
Old 11-22-2012, 01:37 PM   #8
sleevedout OP
Oddometer: 26
My new wife is from Wiltshire area so I had no choice.
Old 11-23-2012, 07:25 PM   #9
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,572
Old 11-24-2012, 01:52 AM   #10
sleevedout OP
Oddometer: 26
I just need to find someone that has a R1100 rear swingarm I could borrow. I need to see if an idea would work.
Old 11-24-2012, 04:01 AM   #11
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
The 1100 Swinging will fit straight into your frame but you will end up with too much offset on the rear wheel. With spoked wheels you can pull the wheel rim over and get it almost back in line.
This is an 1100 swinging arm in a Paralever airhead frame. You can see how far from the central line the wheel ends up.
Old 11-24-2012, 04:06 AM   #12
sleevedout OP
Oddometer: 26
Hmm...
If you re-lace the rear wheel how much of this can you take up?
Old 11-24-2012, 07:44 AM   #13
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
Hmm...
You can take the majority of it out, enough to be acceptable, but it isn't a cheap mod to do. There are only one or two people who will do it because the spoke angles in the rear hub have to be altered. There's also an adapter to buy to convert the airhead gearbox output flange to take an 1100 driveshaft - http://www.bmwboxersupplies.com/adap...aft-p-331.html you also need to sort out some way of mounting an upright shock where the battery normally sits and you will need a custom made rear shock.
You could always fit a Paralever GS/R swinging arm and rear wheel but that may not be look your going for, the parts are expensive and not easy to find.
Rob Farmer screwed with this post 11-24-2012 at 07:50 AM
Old 11-24-2012, 08:48 AM   #14
sleevedout OP
Oddometer: 26
I love how all of these ideas I have seem to follow the path of "pain in the ass to attempt", haha
Old 11-24-2012, 09:07 AM   #15
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
best to know the pitfalls before you spend any cash?
Times are GMT -7.   It's 01:32 AM.
