Old 11-22-2012, 09:20 PM   #1
indr OP
Oddometer: 861
Solid Brass vs Tin Plated Terminals
Is there any benefit to the tin plated ones besides being easier to solder?
indr is online now   Reply With Quote
Old 11-22-2012, 10:06 PM   #2
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,571
Lower electrical resistance than brass.
tbarstow is online now   Reply With Quote
Old 11-22-2012, 11:21 PM   #3
indr OP
Oddometer: 861
Enough of a difference to matter on a bike's electrical system provided proper wire gauges are used?
Old 11-22-2012, 11:32 PM   #4
squish
Out of the office.
Oddometer: 4,981
The way i understand it is that tin plated, or plated for that matter assuming it's plated with decent stuff
Stands up to environments that corrode much better then straight up brass, which starts to get dull fast.
This is why the bulk of connections on late model bikes are plated.
On vacation for a spell
squish is offline   Reply With Quote
Old 11-23-2012, 04:47 AM   #5
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 713
Yes; also the solid brass is weak and can loosen or break off easily. Poor
choice for the motorcycle environment.
CycleDoc59 is offline   Reply With Quote
Old 11-23-2012, 05:55 AM   #6
ragtoplvr
Oddometer: 4,600
Tin plated copper is much lower resistance than brass, which can be as bad as steel. For plug in connections tin is also preferred as it makes a better connection and does not pressure weld much. If you coat plug in connections with dielectric silicone, this will exclude oxygen and make a better connection. Rod
ragtoplvr is online now   Reply With Quote
Old 11-24-2012, 03:48 AM   #7
Pike Bishop
Pike Bishop's Avatar
Oddometer: 6,505
Actually brass is less resistive than tin. (Brass is mostly copper, and the only thing more conductive than copper is silver.)
http://www.engineeringtoolbox.com/re...ity-d_418.html
Pike Bishop is offline   Reply With Quote
Old 11-24-2012, 05:00 AM   #8
Benesesso
Benesesso's Avatar
Oddometer: 8,693
After a bit of corrosion, it's the conductivity/resistivity of the resulting oxide/sulfide/carbonate films that count.
That's why we gotta keep those battery terminals clean.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 11-24-2012, 05:51 AM   #9
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 896
Brass oxidizes to a very poor conductor. Ask any model railroader old enough to have used brass rail.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 11-24-2012, 07:17 AM   #10
Pike Bishop
Oddometer: 6,505
Well, I'll be darned...you're right. I remember that!
Old 11-25-2012, 07:20 AM   #11
Bad Daddy
Oddometer: 62
I believe that Copper has 2.5 times the conductivity of brass.
Copper, being an element is also more noble than brass, which
contains zinc, a metal that will erode(corrode?) in the presence of salt.
Tinned terminals are even more corrosion resistant. Couple that with tinned
Copper wire, and you have a very reliable connection, after you crimp, then cover
with dual wall heat shrink.
FTZ connectors, Blue Sea Systems, and Ancor Wire are good sources of information.
Especially Blue Sea Systems.
BD
Bad Daddy is offline   Reply With Quote
Old 11-25-2012, 08:12 AM   #12
Pike Bishop
Oddometer: 6,505
As a kid, I had a model train set with brass rails, and I remember that ... but nowadays I have a TIG/stick welding machine that has solid brass DINSE connectors, which sometimes need to carry 310A @ some low voltage (maybe 20-30V depending on arc length?).
Considering the high currents and fairly low voltages, I wonder why they don't use something other than brass...
Old 11-25-2012, 10:59 AM   #13
Benesesso
Benesesso's Avatar
Oddometer: 8,693
You're lucky it's not an older Hobart Mig welder. The high-current buss bars are freakin' aluminum. When copper/brass has some corrosion, the oxides/whatever will still have reasonably low resistance. Not so with alum. Al2O3 is a great insulator (think spark plugs), and as a connection resistance goes up so does the temperature.
It might even be capable of burning a house/trailer down to the ground.
Times are GMT -7.   It's 10:58 AM.
