Old 11-23-2012, 03:28 PM   #1
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,542
Sealed connector crimping tool?
On my next project bike I have realized that I need to get more professional with my wiring which means no more autozone insulated bullet connectors. I want to start using more WeatherPack type connectors and also sumitomo type connectors.
I have a ratcheting type crimper for insulated connectors and I really like that style. I see that they now come with interchangeable jaws for all sorts of crimping tasks.
Is there a set you can point me to that will handle all my future crimping needs for the sealed connector variety?
and
I was thinking this? but I don't know how the jaws are numbered?
http://www.amazon.com/Tool-Aid-18920...heting+crimper
or
http://www.amazon.com/Astro-Pneumati...heting+crimper
I've seen the Eastern Beaver one too, but want something in the US.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 11-23-2012, 06:19 PM   #2
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,775
Used those on my Ford- hate them, will not go back.
I like the Sumitomo Eastern Beaver ones.
Sorry....
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 11-23-2012, 06:59 PM   #3
1greenmachine
Oddometer: 710
This is like what we have at work for doing those connectors you have shown, i have a kit like you listed i got dirt cheap and have never used it.
http://www.tooltopia.com/sk-hand-too...ricegrabber_r1
1greenmachine is offline   Reply With Quote
Old 11-23-2012, 07:57 PM   #4
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,542
Thanks I bought a Wiha crimper tonight based on my past excellent experience with their tools made in Germany. A buddy recommended the correct "jaws" so I think I'm good.
Nessmuk
Old 11-23-2012, 08:00 PM   #5
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 4,891
Crimpers you say. . . . .
The top one is a genuine crimper from Packard Electric for Weather Pack terminals like you have pictured in your bottom picture. Crimps both the terminal & water tight seal at the same time. Good luck finding that one!
The other 3 below are GM tools from Kent-Moore for terminal crimping. Watch Craiglist or FleaBay for those.
The bottom one, you can still get and, it does a very good job!
It's made by Xcelite. Part # ECP-112 LINKY
I think you would be very happy with the Xcelite crimper. Shop around and find the best price.
Sargent also makes good crimpers. They also make the tools used by GM service techs from Kent-Moore. The second one down in my picture is a Sargent that came from Kent-Moore at a GM dealership.
Wasser is offline   Reply With Quote
Old 11-23-2012, 08:29 PM   #6
RealOldDualSportGuy
RealOldDualSportGuy's Avatar
Oddometer: 488
Crimpers
The Hewlett Packard Crimper is still available.
Just pricey.
LOL
BTW Weather Pack connections have a finite life cycle, so would not suggest using them anywhere that there will be a lot of plugging and unplugging.
The NASCAR Teams have converted to Deutsche fittings, due to their extended plug and unplug life cycle.
Unfortunately the crimping tool for those connectors is a bit pricey also.
Good Luck
I wont be wronged, I wont be insulted, and I wont be laid a hand on. I dont do these things to other people, and I require the same from them. John Wayne -- The Shootist (1976)
RealOldDualSportGuy is offline   Reply With Quote
Old 11-23-2012, 08:36 PM   #7
BluByU
BluByU's Avatar
Oddometer: 497
If you are interested in Weather-Pac connections I would suggest this
http://www.mactools.com/Product/tabi...6/Default.aspx
Also available from most tool trucks or online
Yes Weather pack connectors have a finite life span, they are easy to rebuild and seem to work for years of service on my bikes without issue
BluByU is offline   Reply With Quote
Old 11-23-2012, 09:52 PM   #8
Beezer
Oddometer: 5,646
I do quite a bit of wire work. I have at least 3 or 4 Molex type tools and they all do some terminals but not others. They all went into retirement when I got this one a couple years ago:
http://www.easternbeaver.com/Main/El...ols/tools.html
for ring terminals & splices I use Amp PIDG aircraft stuff.... the crimper MS 59250 is like $1400 new last I checked but comes up on fleaby pretty regular under a 100 or so
http://www.ebay.com/itm/AMP-CRIMPING...d9d882&vxp=mtr
Beezer is online now   Reply With Quote
Old 11-23-2012, 09:55 PM   #9
Beezer
Oddometer: 5,646
from the Mac tool in the post above:
" Note: Nests may not be suitable for certain contacts due to the wide range of material thicknesses, length of ears, and design variations."
says it all. I have that tool. it is retired in favor of the Beaver.
Old 11-24-2012, 07:10 AM   #10
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,542
Thanks guys I had a look around and wasn't surprised some of the aviation stuff was obscenely priced, wow.
I just threw the weatherpack connector out there as an example.
here's why i want this stuff. On my project bikes, I have the factory harness from a street bike, but then I have added tons of LED, GPS, HID ballasts etc and the wiring becomes stupidly messy. Plus bullet connectors and spade connectors it's a mess.
So I have a new project bike where I am going to build a rally type front fairing on a Ninja 650. The main tower I would like to have just a few connectors to remove it all completely from the bike. One stock one for the gauges and another one I make with 12-16? pins for everything else. I really like the Sumitomo type connectors Eastern Beaver has and plan to use those in the build. I want to take my wiring from complete garage hack to at least something resembling marginally professional
Here's a pick of the crimper I bought. It was 50% off, I have really enjoyed the Wiha screwdrivers, plus I got a nice set of Linesman pliers free with another philips screwdriver to bump my order over $100. They also have crimpers that look exactly like the Exclilte thing posted above so I assume they are made by the same firm.
http://www.wihatools.com/400seri/436_crimps.htm
Nessmuk
Old 11-24-2012, 07:44 AM   #11
1greenmachine
Oddometer: 710
That crimper looks nice and i had forgotten to say get one that rachets as those make it so much easier to hold the terminal while pushing the wirer into it. Have fun practicing with it, once you get the hang out it their super easy.
Old 11-25-2012, 07:37 PM   #12
fast4d
Oddometer: 2,277
I solder then crimp to make sure the wire never comes off.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 11-25-2012, 08:43 PM   #13
Bad Daddy
Oddometer: 103
I like the deutsch connectors.
http://m.youtube.com/#/watch?v=RWs_V...%3DRWs_V2_KMqc.
We use them in the marine industry, and they have proven to be quite robust.
BD
"My biggest fear, is that when I die, my wife will sell all my stuff for what I said I paid for it." ...
Bad Daddy is offline   Reply With Quote
Old 11-29-2012, 05:52 PM   #14
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 1,023
I have a ratcheting set from Del-City that was inexpensive and works very well.
Tipsy
2008 Buell XB12X Ulysses
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger is offline   Reply With Quote
Old 11-29-2012, 09:18 PM   #15
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,542
Just got my Wiha crimpers in the mail today, love that place. they feel very quality, I like the made in Germany too. I will actually get some of the crimpy things and report back
Nessmuk
Times are GMT -7.   It's 01:37 PM.
