Old 11-24-2012, 06:07 AM   #71566
procycle
procycle's Avatar
Oddometer: 1,597
Originally Posted by Emmbeedee View Post
Is pulling the enrichener (choke) going to help if the problem is that there's no fuel in the carb?
When the bike is misfiring there is still fuel in the carb - just not enough for smooth running. The enrichener will suck up enough fuel to stop the misfiring. If pulling the choke temporarily solves the problem then you are pointed in the right direction for finding the source of the problem.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 11-24-2012, 06:13 AM   #71567
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,475
Is the 19" front wheel of a width that the rear OEM rim can stay, or does the rear still have to be changed out for balance like with SM wheels?
Mambo Dave is offline   Reply With Quote
Old 11-24-2012, 06:26 AM   #71568
barko1
barko1
barko1's Avatar
Oddometer: 2,511
Originally Posted by Garak View Post
+1. I'm very happy with my Oxfords. The wiring can be delicate in spots so exercise caution when installing, but once they are on they work very well and seem pretty robust.
I usually just buy the cheaper wrap ons and add a relay which works fine for about $35 and sometimes new grips if I have to destroy the existing ones during removal. This time I had just gotten an ad from Aerostitch for Bikemaster heated grips for $59 which seemed decent so I ordered them. Then Aerostitch told me they were back ordered until January so I cancelled and found the same grips for $45 and $5 shipping from Koups Cycle shop. Started to install them on my Moto Guzzi last night. Just need to run one ground wire, one wire to a switch source, runs the wires from the battery to the front of the bike, use a few zip ties, and put the grips on. I just have to do the last part yet but everything is working.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi
barko1 is offline   Reply With Quote
Old 11-24-2012, 08:40 AM   #71569
O'B
O'B's Avatar
Oddometer: 316
Originally Posted by Jammin View Post
Ha! Found the culprit: clogged fuel filter (paper core). Replaced it with a new spare (copper core) and sanDRina runs like a champ! Went for a 60 km test ride and no issues. I think that was it Continuing south tomorrow
Come on, motorcycle gods, what else you got? Let me have it.
I got jolted last night and told myself that 'give up' isn't in my dictionary. I beat my demons back in their cave and listened to the advice from ADV brethren who directed me to inspect this part.
If I don't make it to the next town tomorrow, I'll figure it out
Thanks!!!
Wierd! Glad it was something simple. If that ain't a real WTF momement I don't know what is!
O'B is offline   Reply With Quote
Old 11-24-2012, 11:23 AM   #71570
DR Steve
DR Steve's Avatar
Oddometer: 143
Originally Posted by dogjaw View Post
Galfer brake, stock size, definitely improved braking
Thanks for that.
Did you notice an improvement over the stock rotor while using the 19" fornt wheel or did you fit the Galfer when you fitted the 19" wheel ?
'08 DR650
DR Steve is offline   Reply With Quote
Old 11-24-2012, 12:08 PM   #71571
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,435
@Multisurface Rider: I'm on it!
@JagLite: I love the DR Simple rules!
@ADV Grifter: I'm so glad it was fuel related, much easier to solve mechanical problems Yeah, my bad that I repositioned the fuel filter recently so that it was hidden from view. The rectifier and coil were donated by DR riders in South Africa. Hopefully now I'll get there and give them back
@Emmbeedee: (at myself, too)
@procycle: great tip, will remember that
@Randomroad: That's exactly what I yelled out and then a big smile grew on my face
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 11-24-2012, 05:00 PM   #71572
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,175
New Springs
Got my new springs installed on the 2006 DR this Thanksgiving weekend. NO photos taken. Only broke one 3/8" ratchet handle and a 3/8" extension. Probably needed a 1/2" drive socket set. That is on the shopping list.
8.3 kg/mm rear spring (black)
0.55 kg/mm fork springs
Took it for a 20 mile test ride in the rain and it's much better than stock OEM. Not nearly so much brake dive. The suspension feels slightly stiff, but me being used to the OEM springs, I have some learning to do. The stiffness will be good for hauling adventure camping equipment.
Dave
smilin jack is offline   Reply With Quote
Old 11-24-2012, 05:08 PM   #71573
LeDakaR!
LeDakaR!'s Avatar
Oddometer: 423
Rear shock blew thus summer, pro rebuilt and now it's leaking after a hard offroad ride wtf?!?
How many time will I have to rebuild?
Pm me with what you want, Hooking up the adv community since 2010
Adv discount on all brands
www.motoclubhouse.com
www.route66moto.com
moto rental/sales and tours, location et vente moto, import-export
LeDakaR! is offline   Reply With Quote
Old 11-24-2012, 05:12 PM   #71574
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,214
Dave
Congrats! You'll really realize the value of the springs when you get off road and into something that would tax the stock bouncers.
And there's something about a fully loaded DR that just looks and feels right.
Yours truly -- northern New Mexico, July 2010.
'08 DR650SE; '91 GL1500SE; USMC 1972-76; NRA Life Member
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 11-24-2012, 05:21 PM   #71575
Sierra Thumper
Oddometer: 641
You got a bad rebuild job.....a properly rebuilt shock should last for years and thousands of miles just like the stocker. Its hard to find good service anymore...........
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 11-24-2012, 05:45 PM   #71576
procycle
procycle's Avatar
Oddometer: 1,597
If you plan on retaining the stock rear rim I would recommend either a 2.15x19 or a 1.85x19 rim on the front.
Old 11-24-2012, 06:12 PM   #71577
TrophyHunter
Oddometer: 918
I borrowed a set from a buddy. Stock rear, 19 front, no issues at all. GoodCat8 ran the combo all the time and never mentioned any problems. The 19 is a blast in the corners and it looks symetrical on the DR.
www.dualsportmoto.com
2005 DR650
2013 HD Road King
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 11-24-2012, 08:24 PM   #71578
opium89
opium89's Avatar
Oddometer: 1,134
Engine Swap
Needs some opinions from my fellow DR inmates....
Have a 1999 DR with a grenaded case. Found a replacement bottom end at a salvage yard. Seeing as I am not quite sure how many miles might be on the bottom end I purchased, my original plan was to swap *everything* from the original engine and move it over to the new case. Now that I have it apart, I am not so sure it's worth the bother to split the cases, and simply move everything else over to the replacement. Anything you folks can think of that I should look for in making this decision? I'd really hate to not do it, then find out there's a bad bearing or gear in the replacement bottom end. Anything above the obvious I should be looking for in making this determination? Keep in mind I was an auto mechanic for 11 years of my life, so I am not completely oblivious to signs of normal engine wear. So far, I can't fault the replacement in any way, at least visually, performing some cursory spins, and looking for play in the rod, bearings and output shafts.
Something else has me a little stumped so I have another question. The grenaded case is from a 1999 model bike and did not have this washer behind the flywheel when I took it off.. Parts fiche shows it for 1999, and 2000, but not for 2001...I was told the replacement bottom end was from a 2000 model year bike. What's it doing there?
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 11-24-2012, 09:05 PM   #71579
TRAVELGUY
Old Traveler
Oddometer: 463
Who did the rebuild?
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '07 ( lives in Costa Rica )
DR 650 "08
TRAVELGUY is offline   Reply With Quote
Old 11-25-2012, 12:15 AM   #71580
basketcase
basketcase's Avatar
Oddometer: 1,214
(Rick snipped some stuff...)
1. Can you check the engine # from the replacement and ascertain what year bike it came out of?
2. Is there a way to make certain the parts fiche is correct in displaying/not displaying the washer with respect to the model years?
Times are GMT -7.   It's 01:35 PM.
