11-22-2012, 09:20 PM
#1 |
Oddometer: 840
Solid Brass vs Tin Plated Terminals
Is there any benefit to the tin plated ones besides being easier to solder?
11-22-2012, 10:06 PM
#2 |
Two-wheelin' Fool
Oddometer: 2,565
11-22-2012, 11:21 PM
#3 |
Oddometer: 840
Enough of a difference to matter on a bike's electrical system provided proper wire gauges are used?
11-22-2012, 11:32 PM
#4 |
Out of the office.
Oddometer: 4,948
The way i understand it is that tin plated, or plated for that matter assuming it's plated with decent stuff
Stands up to environments that corrode much better then straight up brass, which starts to get dull fast. This is why the bulk of connections on late model bikes are plated.
On vacation for a spell |
11-23-2012, 04:47 AM
#5 | |
Wrench Rider
Oddometer: 712
choice for the motorcycle environment. |
11-23-2012, 05:55 AM
#6 |
Oddometer: 4,553
Tin plated copper is much lower resistance than brass, which can be as bad as steel. For plug in connections tin is also preferred as it makes a better connection and does not pressure weld much. If you coat plug in connections with dielectric silicone, this will exclude oxygen and make a better connection. Rod
11-24-2012, 03:48 AM
#7 |
Oddometer: 6,505
Actually brass is less resistive than tin. (Brass is mostly copper, and the only thing more conductive than copper is silver.)
http://www.engineeringtoolbox.com/re...ity-d_418.html |
11-24-2012, 05:00 AM
#8 | |
Oddometer: 8,506
After a bit of corrosion, it's the conductivity/resistivity of the resulting oxide/sulfide/carbonate films that count. That's why we gotta keep those battery terminals clean.
US out of the UN, UN out of the US. |
11-24-2012, 05:51 AM
#9 |
Unpaved road avoider
Oddometer: 890
Brass oxidizes to a very poor conductor. Ask any model railroader old enough to have used brass rail.
Pat in order of ownership 1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A |
11-24-2012, 07:17 AM
#10 |
Oddometer: 6,505
11-25-2012, 07:20 AM
#11 |
Oddometer: 55
I believe that Copper has 2.5 times the conductivity of brass.
Copper, being an element is also more noble than brass, which contains zinc, a metal that will erode(corrode?) in the presence of salt. Tinned terminals are even more corrosion resistant. Couple that with tinned Copper wire, and you have a very reliable connection, after you crimp, then cover with dual wall heat shrink. FTZ connectors, Blue Sea Systems, and Ancor Wire are good sources of information. Especially Blue Sea Systems. BD |
11-25-2012, 08:12 AM
#12 | |
Oddometer: 6,505
Considering the high currents and fairly low voltages, I wonder why they don't use something other than brass... |
11-25-2012, 10:59 AM
#13 | |
Oddometer: 8,506
It might even be capable of burning a house/trailer down to the ground.
