Old 11-25-2012, 04:57 PM   #1
headtube OP
6 mesas de invierno!
headtube's Avatar
Oddometer: 339
Iridium plugs in your Airhead?
Anyone using Iridium plugs? I have had great success with Brit bikes using these plugs. Anyone know the Iridium equivalent to the recommended Bosch plug for the 79 R100RS? Thanks.
headtube is offline   Reply With Quote
Old 11-25-2012, 06:10 PM   #2
craydds
craydds's Avatar
Oddometer: 1,167
I use standard NGK BP6ES plugs. Here is an NGK cross reference for iridiums - http://www.clubplug.net/ngk_ngk_iridium.html . Here is a source - http://www.jegs.com/i/NGK-Spark-Plug...R6EIX/10002/-1 .
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 11-25-2012, 07:54 PM   #3
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
I have been considering trying the iridium plugs also but they seem to be the resistor type only so it would mean changing the spark plug caps to the no resistance type.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 11-25-2012, 10:50 PM   #4
GypsyWriter
Sarah
GypsyWriter's Avatar
Oddometer: 1,678
I always used resistor plugs in my regular (resistor) caps on my GL500 and never had problems. Is there any reason why they wouldn't work in an R100? I'm considering this for my '88 GS.
2012 R1200GS Rallye - Gypsy
2003 R1150GSA with DMC sidecar
Ask A Self-Publisher
Originally Posted by FotoTEX View Post
Life is dangerous. Not doing what you love makes life even more dangerous...
GypsyWriter is offline   Reply With Quote
Old 11-26-2012, 08:24 AM   #5
mfp4073
mfp4073's Avatar
Oddometer: 2,542
Can someone post a pic of the difference between resistor wires/non resistor wires and is there a way to ID resistor plugs/non resistor plugs visually?
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is online now   Reply With Quote
Old 11-26-2012, 08:43 AM   #6
batoutoflahonda
Oddometer: 1,386
For me any way, not sure if it's worth the money. Between the carbon build up and oil that invariably gets drawn in through the breather in the air box and finds it way to the left plug.....I just run what's cheap and in spec. Clean them and regap with tune up.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 11-26-2012, 10:04 AM   #7
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,145
How many manufacturers in the world use WIZBANG spark plugs as factory install?? NONE, ZERO, NADA
Not one of these teams of qualified engineers has found them viable for thousands of motor designs. Any improvements noted are so small as to make them far too expensive in a rational sence. A 2% benefit cannot overcome a doubling or more of the cost.
If you are not running good enough with stock plugs, the plugs are not the problem and different plugs will not fix you.
DoktorT is offline   Reply With Quote
Old 11-27-2012, 01:44 AM   #8
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,619
Heaps...that means lots and lots. If you haven't pulled many sparkplugs in your life, then get a sparkplug catalogue from any manufacturer, in the front section there will be photographs - 2,3, and 4 electrodes, extended tips, shielded electrodes, V grooves, taper seats etc. Wizbang everywhere.
Iridium ? I don't see the point, but try it and see. I'm using Bosch W78 Plus 4's. Doubled my HP and halved the fuel consumption.
motu is online now   Reply With Quote
Old 11-27-2012, 02:00 AM   #9
wmax351
Oddometer: 743
For airheads, there isn't a big advantage (or any) for using exotic multi electrode plugs. The combustion chamber is designed for normal plugs. However, the iridium has to do with the electrode. It allows it to be smaller and last longer. In that regard, it shouldn't matter. The plugs will last longer, and spark well longer, but will cost more. So its a matter of choice.
wmax351 is offline   Reply With Quote
Old 11-27-2012, 04:53 AM   #10
rambozo
rambozo's Avatar
Oddometer: 585
my two running airheads have standard Bosch plugs but I tend to use
fancy plugs on some of my cars and bikes, silver plated in my cb750
(very short life) and platinum in my gt turbo, can't remember what I have
in the others
Anything that helps a bit is good in my book but I doubt I'll bother on the
airheads
rambozo is offline   Reply With Quote
Old 11-27-2012, 08:28 AM   #11
chasbmw
Oddometer: 2,354
Wizbang spark plugs are to give extended service life in todays vehicles, think replacement @ 25-35kmiles rather than the normal 5k miles on our bikes.
Charles
1971 Commando Fastback
Old 11-27-2012, 09:27 AM   #12
wmax351
Oddometer: 743
Think 100k miles. It's really remarkable.
Old 11-28-2012, 10:47 AM   #13
digger440
digger440's Avatar
Oddometer: 74
Exactly, whizzbang plugs are meant for a engine with high efficiency I.E. a very tightly controlled combustion process. These old aircooled tractor motors (while very reliable) have too much variation in combustion chamber temps with minimal fuel control. Modern fuel injection has maps to match the fuel delivery rate precisely to internal temp, atmospheric temp, engine speed and load (and other stuff).
An old motor with carburetors will not keep the Wizzbang plugs clean enough to take advantage of the extended service intervals and the wizzbangs do very very very little, if nothing at all to promote combustion efficiency. You would not put iridium plugs in a 1972 Ford with a 300 6cyl and expect them to last 80k-90-100k miles even if the motor was fresh.
On these antique motors save yourself some money, buy a quality "normal" plug and inspect them at the correct intervals.
digger440 is offline   Reply With Quote
Old 11-28-2012, 01:12 PM   #14
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,145
Anyone who has any experience with aluminum spark plug threads knows that means teardown and thread restoration too many times. But hey, you need a complete valve job by then anyway.
Old 11-28-2012, 01:25 PM   #15
craydds
craydds's Avatar
Oddometer: 1,167
+ 1 . Iridium plugs provide no advantage over standard plugs.
ABC #12947
'75 R90S
Times are GMT -7.   It's 12:07 AM.
