Old 11-05-2012, 11:44 AM   #16
babuja OP
babuja's Avatar
Oddometer: 353
When at relanti if I give a strong aceleration the motor hesitates and some time dies...
If I gradualy acelerate a bit and then give a strong acceleration I have no problem.
What cold be the problem? Tnks guys
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja screwed with this post 11-05-2012 at 02:45 PM
babuja is offline   Reply With Quote
Old 11-05-2012, 01:38 PM   #17
sintax
Oddometer: 495
If I gradualy acelerate a bit and been give a stronh aceleration I have no problem.
sounds like you might be a little too rich.
You might try dropping the needle down one spot, see what effect that has on it. Since the need needle plays a big role in the whole mid range power, it may affect it poorly. If that happens move the needle back. And try dropping down one size main.
You and I have close to the same elevation and temp, but you have much higher humidity. When I get home tonight I can see if i can find my settings for when I jetted my stock carb. I have since moved to the TM40. I completed jetting it yesterday, it is amazing!
sintax is offline   Reply With Quote
Old 11-05-2012, 01:52 PM   #18
babuja OP
babuja's Avatar
Oddometer: 353
Thanks sintax, I appreciate that...tnks man
Cheers guys
Babuja
________
KTM 950 ADV
Old 11-05-2012, 02:46 PM   #19
babuja OP
babuja's Avatar
Oddometer: 353
Some Photos
Cheers guys
Babuja
________
KTM 950 ADV
Old 11-05-2012, 04:50 PM   #20
sintax
Oddometer: 495
very sexy man. Love the USD forks!
Old 11-26-2012, 12:07 AM   #21
babuja OP
babuja's Avatar
Oddometer: 353
New graphics
Cheers guys
Babuja
________
KTM 950 ADV
Times are GMT -7.   It's 09:41 PM.
