Old 11-26-2012, 02:43 PM   #1
Cycleman4 OP
Oddometer: 267
Clutch?
While riding this past weekend I thought i felt something strange under acceleration from a stop. felt like it took a second for the clutch to let go completely. Thought it might be wheel spin since I was riding in the dirt. Then on the way home on the tarmac i was in 3rd gear and punched it and again it felt like the RPM's ran up but the speed did not increase quickly like it should. I have never had clutch issues on any other bike so forgive my lack of knowledge. What am I headed for? thanks for your input.
Cycleman4 is offline   Reply With Quote
Old 11-26-2012, 02:50 PM   #2
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,303
It does sound like the clutch is slipping. If it is adjustable, losening the cable may fix the problem. I'm guessing yours has a hydraulic clutch, though, which I am not that familiar with. It could be that the plunger is sticking in the clutch master cyclinder or slave cyclinder, or it may need a new clutch.
If you've ever thought about adding a slipper clutch or Rekluse clutch, this could be a good time to do it.
High Country Herb is offline   Reply With Quote
Old 11-26-2012, 02:56 PM   #3
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,069
The clutch plates/springs are pretty easy to do.. you can swap them in ~20 mins if you know what you are doing (check the HOW if you aren''t familiar - www.ktm950.info ). Mine had been fine for 25,000 miles .. and then one day I decided to ride the bike over Pearl Pass
I ordered my plate/spring kit from CJdesigns and it was at my door two days later
p.s. make sure you properly torque/spec the clutch plate spring bolts so you don't pull a "Qwik"
Old 11-26-2012, 05:19 PM   #4
Cycleman4 OP
Oddometer: 267
Thanks for the info guys. Has anyone used the Barnett clutch rebuild kit?
Old 11-28-2012, 07:31 AM   #5
Central Cali Rider
Central Cali Rider's Avatar
Oddometer: 408
Now that is a clean arse work bench... No beer caps , grease, dirt, extra bolts which weren't needed Bravo
Central Kali Coast
2005 KTM 950 Adventure
1965 Meyers Manx Dune Buggy
2006 Suzuki SV1000S for wifey Sold !
1997 KLR650 For sale SOLD !!
Central Cali Rider is offline   Reply With Quote
Old 11-28-2012, 08:48 AM   #6
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
another expert lurker working on increasing their post count
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 11-29-2012, 07:00 PM   #7
mikeegee
Oddometer: 298
Yeah, I used a Barnett, and all was fine until my oil jet decided to plug up.
All things considered, it couldn't have happened at a better time as I was in the woods behind CJ's house at his big bike weekend extravaganza.
The Barnett comes with a stringer spring, so be prepared for a bit of a stiffer clutch than the stock - which I run now.
It's a perfect time, however, to take a look at the Rekluse. If you've ever thought of it the money you'll spend on new clutch disks will go a long way in that direction. Given the chance, I'd redo my choice for the KTM clutch and get the Rekluse.
Of course, you can also get one of those from CJ.
meh
mikeegee is offline   Reply With Quote
Old 11-29-2012, 09:06 PM   #8
triplenickel
triplenickel's Avatar
Oddometer: 2,426
You don't think it could be the cable?
07 SE
PG007
Old 11-29-2012, 11:50 PM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,877
I think the clutch booster sometimes plays up.
I believe I have experienced the same with the OP. The clutch kind of slips and then engages completely. Comes and goes I believe. Nothing to worry about. I don't remember being the sign of failed clutch.
Cheers.
gefr screwed with this post 11-30-2012 at 04:12 PM
gefr is online now   Reply With Quote
Old 11-30-2012, 04:15 AM   #10
walstibsf
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
Out of curiosity: How many miles on your bike now? And when was the last time service included cleaning the clutch oil jet?
W A L S T I B........ S F......................
what a long strange trip it's been......SO FAR......
walstibsf is offline   Reply With Quote
Old 11-30-2012, 04:33 AM   #11
walstibsf
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
Not only that, the granite portion is reserved for more important parts like triple clamps......etc.............
Old 11-30-2012, 11:56 AM   #12
Cycleman4 OP
Oddometer: 267
I am going to get into the bike this weekend. I will check the cable and the oil jet. The bike has just under 12k on the clock. Thanks for the ideas.
Old 11-30-2012, 04:17 PM   #13
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,877
The only cables are the throttle cables. Your clutch is hydraulic. They are pulling your leg.
Cheers.
Old 11-30-2012, 06:05 PM   #14
Qwik
Adrenaline Addict
Oddometer: 6,539
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 12-01-2012, 08:46 AM   #15
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,371
Check clutch booster before replacing clutch.
"The BSC was strong in that one, had to get out !"
dlrides is offline   Reply With Quote
Times are GMT -7.   It's 11:46 PM.
