Old 11-24-2012, 06:54 PM   #1
mattcfish OP
R90SS/6
mattcfish's Avatar
Oddometer: 221
Dellorto flooding float issue
I left about a half gallon of gas on the ground at my last motorcycle club meeting. A little embarrassing to say the least. Glad no one was smoking or a whole line of vintage bikes would have gone up in a fireball.
Turns out one of my floats filled up with gas and doesn't float anymore. I know, I should have closed the petcocks, I almost always do.
What is especially vexing is that this particular float was only 1 year old and not exactly cheap. Luckily I had saved one of the old floats and was able to reinstall it. The only reason I had replaced it in the first place was that it was a little heavier than spec. The question is, are new floats for PHM's as good as the old ones? Is there something in fuel these days that is dissolving them more rapidly? Anyone else suffering from flooding floats?
The interesting thing is that there is no apparent hole in the float. It's just completely full of gas in one of the chambers. The new floats are a translucent white in color, even after one year. The old float, which I'm using now, is a solid yellowish color.
I'm worried about the other carb, it's also got the newer float.
mattcfish is offline   Reply With Quote
Old 11-25-2012, 08:05 PM   #2
bmwrench
Oddometer: 2,057
I haven't seen this happen-yet. I hope yours was a fluke.
bmwrench is offline   Reply With Quote
Old 11-26-2012, 02:28 PM   #3
hopscotching
On the road...
hopscotching's Avatar
Oddometer: 256
After I did a full rebuild
One of the new floats i installed sprung a leak!!! It was replaced at no charge but very annoying to say the least, the replacement seems to be holding up well thou... I have a feeling that if they are to leak it will happen quickly, at least i am hoping
In Dog Beers I've Only Had One!
Ride Report
http://advrider.com/forums/showthread.php?t=901273
Mexico starts on this page
http://advrider.com/forums/showthrea...1#post23188421
hopscotching is offline   Reply With Quote
Old 11-26-2012, 03:44 PM   #4
mattcfish OP
R90SS/6
mattcfish's Avatar
Oddometer: 221
I wonder if the newer floats are even made in Italy. What a PITA, they should last at least a decade or more.
mattcfish screwed with this post 11-26-2012 at 04:30 PM
Old 11-26-2012, 04:10 PM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,165
I don't see a problem. You bought a new part. The part failed in service. They replaced it free. Even building quality and testing everything it would be difficult to have 100% success. (they don't test everything but) I don't think you can expect any better than that. I don't think they owe you anything else.
---Albert Einstein
Old 11-26-2012, 04:36 PM   #6
mattcfish OP
R90SS/6
mattcfish's Avatar
Oddometer: 221
Mine hasn't been replaced. What bothers me is that mine functioned for at least a year and then failed. That rings of a design problem, not just a faulty part. I think the alcohol used in the gas around here may be too much for the plastic in these floats. Just want to see if this is a reoccuring problem or just a fluke.
Old 11-26-2012, 04:51 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,165
Sorry. I confused the OP with somebody else that had the same problem.
I do think you should get a new part. Maybe you will. But after one year the seller may balk. Alcohol in the gas strikes again.
---Albert Einstein
Times are GMT -7.   It's 12:02 AM.
