Old 11-26-2012, 02:41 PM   #6406
desmodronic
desmodronic's Avatar
Oddometer: 17
Do I have to read all 400+ pages to find out is 690 SMC good or bad?
desmodronic is offline   Reply With Quote
Old 11-26-2012, 02:43 PM   #6407
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 817
It will rock your world. Best supermoto out there... and my supermoto is an Aprilia 550. Next one will be a 690 smc.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting.
Open-Exporers----->A collection of travel blogs
Old 11-26-2012, 03:07 PM   #6408
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 817
Originally Posted by modeselector View Post
Trying to picture the "extra loop" part. Would be interested in seeing a close up picture of your set-up.
Also curious - anyone carry a spare quick connect (fuel line) piece as part of your parts/tool kit? Heard they may prone to failing.
1. I removed the line from the tank to the disconnect.
2. I removed the line from disconnect to injector.
3. I got a piece of line about 30 inches long (don't quote me on the length). This is run from the tank past the injector down to the filter.
4. The piece of line that was removed from the tank/disconnect is now from the filter to the injector.
I hope that helps.
Old 11-26-2012, 03:41 PM   #6409
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,178
Talking No bike or trailer needed
Originally Posted by Mini Trail View Post
I won't have it together this weekend. I did an event yesterday and now I don't have a trailer. I would do ANF anyway if it wasn't for the 12 hour drive. Plus the added insult that you can be sleeping in your bed in 5 minutes.
That garage is full of Hondas. At least 10 if you only count the ones with tires and an engine in the frame. Only 3 if you count >100cc. It's hard to get away from them. Now that you mention it, Last year I had that 750 all loaded up for a trip to Birmingham. It was idling in the drive, I had my helmet on and twisted the throttle to clean it out and the cable snapped. I had to unload it and took the KTM instead. I didn't ride it again until this summer.
I'll be camping Friday, and Saturday night.
Make the drive Brother. Ride my 690
or the sporty
When there is no way out - Find a way further in.
690 DL650 XL1200C Past bikes
Originally Posted by Mugwest View Post
Stay half-assed, my friends.
Buzztail is online now   Reply With Quote
Old 11-26-2012, 07:25 PM   #6410
desmodronic
Oddometer: 17
I had 2006 640sm, didn like the uneven ride at "steady" RPM and I could hear all bearings from machine + vibrations.
Hope that smc is better
Old 11-26-2012, 09:34 PM   #6411
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 584
So my 690 was running good, now it will start and idle for a couple minutes then it dies.... when I try to restart, it just cranks and cranks but wont come to life unless I leave it for half hour or so... fuel pump?
tattewell is offline   Reply With Quote
Old 11-26-2012, 10:36 PM   #6412
striped tomato
striped tomato's Avatar
Oddometer: 42
Mine just did something similar, unpredictable cutting out at idle - turned out to be a dodgy side stand switch/wiring.
'11 KTM 990 Adventure Dakar 30th Edition
'13 Husaberg FE 350
striped tomato is offline   Reply With Quote
Old 11-26-2012, 10:41 PM   #6413
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 584
interesting, as it has been dropped a few times latelly
Old 11-27-2012, 08:40 AM   #6414
SigPig
SigPig's Avatar
Oddometer: 136
Those are the same symptoms mine had and they went away after a fuel pump swap out to the ca-cycleworks pump. Listen for the whirr of your fuel pump when turning the key on. Mine wasn't making the priming noise all the time.
SIGPIG
2010 KTM 690 SMC
2011 KTM 200 XCW
SigPig is offline   Reply With Quote
Old 11-27-2012, 09:55 AM   #6415
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,841
+1, I sold my SXV 550 and kept the 690.
Guess what doofus, nobody reads your lame blog.
Old 11-27-2012, 10:09 AM   #6416
modeselector
Common as muck
modeselector's Avatar
Oddometer: 482
I hope that helps.
Ah OK, thanks for the pic and reply.
modeselector is offline   Reply With Quote
Old 11-27-2012, 11:10 AM   #6417
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,996
I hope that helps.
Isn't the fuel filter there for the pump, not just the injectors?
Old 11-27-2012, 11:15 AM   #6418
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Not possible, the pump is at the very start of the line. The screen protects the pump.
Just say'IN
crankshaft is offline   Reply With Quote
Old 11-27-2012, 11:15 AM   #6419
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 772
no the sock filters pre pump and the filter pre injector
Ride the DEZ
05 FE 550 Husaberg plated
09 KTM 690
bobzilla is offline   Reply With Quote
Old 11-27-2012, 12:00 PM   #6420
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 817
Oh.. I'm not getting rid of my Ape. It is retarded fun. Just as practical and as bulletproof as a 690.
Times are GMT -7.   It's 02:33 PM.
