Old 11-27-2012, 12:14 PM   #271
England-Kev
Oddometer: 3,606
where we at then?
England-Kev is online now   Reply With Quote
Old 11-27-2012, 01:43 PM   #272
danedg
Horizontally Opposed
Oddometer: 6,645
We are here
Just about to remove engine alltogether for lower end inspection and cleaning, hopefully not too much rebuilding!
Wiring harness soon to follow. The frame is probably gonna get repainted...
And the tank & toolbox....
danedg is online now   Reply With Quote
Old 11-27-2012, 01:53 PM   #273
England-Kev
Oddometer: 3,606
Is that where they hide the fuse rack, inside the headlight! man I am scared to look in there
Old 11-27-2012, 02:10 PM   #274
danedg
Oddometer: 6,645
Don't worry, it's Bosch
The fuse panel turned out very stout. No big deal. Well marked.
This is a chrome cylinder with 49,000 miles on it. When is this going to fail????
Old 11-27-2012, 06:31 PM   #275
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 352
Maybe already. How deep is that ridge?
Life's too short.
F_Sahms is offline   Reply With Quote
Old 12-02-2012, 01:02 PM   #276
danedg
Oddometer: 6,645
Old 12-02-2012, 01:05 PM   #277
England-Kev
Oddometer: 3,606
Nice shot there, did you notice that my bike is a right hand shifter?
Old 12-02-2012, 01:22 PM   #278
danedg
Oddometer: 6,645
No, but I'm famous for not payin' attention!
That floppy, sloppy left shifter is an ornate transfer from the right side.
Dissembling the shifter, footboard and kixtand will be an adventure. The exhaust was a PITA!
Because of all the other bits. And it had become one with itself!
How many miles on your bike?
At 50,000 miles, I'm just gonna take it all down to inspection. The seals are shot and thus a messy rear drive.
The OIL was clean so I'm thinking the gear train is ok.
But she's a dirty girl.
Old 12-04-2012, 07:41 AM   #279
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 352
Yes sir! It's not too bad really. I added two small relays in there as well to save the original headlight switches from melting.
Life's too short.
Old 12-06-2012, 01:46 PM   #280
danedg
Oddometer: 6,645
Rear drive
So I pulled off this greasy bitch to day.
The drive came off the shaft housing and there was 90wt that dribbled out. Not much and clean. Splines looked great and the whole thing spun smooth and tight.
I'm parts cleansing now.
Should there be lube in the drive shaft area? I somehow had the impression that the drive shaft assembly was "dry", unlike the BMW assembly. Or is this a seal issue. I'm going to replace seals, but hope to NOT crack the assembly open.
And what's that little finned reservoir doing under the unit? I can't find it listed in the tavola ....
What should I be checking for?
danedg screwed with this post 12-06-2012 at 01:53 PM
Old 12-06-2012, 02:01 PM   #281
mtiberio
mtiberio's Avatar
Oddometer: 88
No seal at fwd end of rear gears. Some lube invariably makes its way fwd
mtiberio is offline   Reply With Quote
Old 12-06-2012, 02:16 PM   #282
danedg
Oddometer: 6,645
I'm usually paranoid about NOT having lube in that area. What is an inspection routine for this thing? Recommended service at 50,000 miles?
danedg screwed with this post 12-06-2012 at 02:54 PM
Old 12-06-2012, 05:08 PM   #283
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,617
I just cleaned mine as good as I could
with some simple green and qtips,
changed the oil and ran it.
What eventually killed it,
And I did kill it,
Was a po who must have broke it open.
I was riding pretty hard one day
And the rear locked up.
It just ate itself.
These things need to be shimmed
in a dozen directions at the same time,
well maybe like 3 or something.
Someone shimmed mine up bad.
I lubed mine,
especially the driveshaft splines.
Must of lubed the wheel splines too,
I can't see any harm in doing it anyway.
Just a little dab'll do ya.
Look up charley cole of zydeco racing.
He's like the only guy in the world with the rig to true one,
And he's on Long Island.
He set me up with a new unit
That ran real nice.
So yeah, wipe its ass and see If it's notchy.
Or send it to charley if you want it top shelf.
Bloodweiser is offline   Reply With Quote
Old 12-06-2012, 08:39 PM   #284
MZRider
Neo-Luddite
Oddometer: 711
As mtiberio says, no seals on the pinion shaft. Gear oil finds it's way up past them to (hopefully) lube the spliny bits. Still a good idea to grease the splines liberally during assembly and once in a while afterwards.
Bloodweiser has given you some very good advice. Charley Cole will reshim and reseal the rear drive, thus ensuring that it won't leak and will live a long life. Not at all expensive for what you get (piece of mind). http://www.zydecoracing.com
The "little finned reservoir" is a sump of sorts, #37 in the drawing above.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 12-10-2012, 08:42 PM   #285
danedg
Oddometer: 6,645
Times are GMT -7.   It's 11:23 AM.
