Old 11-25-2012, 10:07 PM   #1
az63u OP
az63u's Avatar
Oddometer: 140
19/17 inch rims on a 990adv
Would like to ask anyone using the 19/17 inch rims setup.
How is.the handling of the bike compare to the 21/18?
Offroad handling?
Thanks alot
az63u is offline   Reply With Quote
Old 11-25-2012, 11:17 PM   #2
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
it sits lower, transitions are quicker, front reacts quicker, more fun on road because it opens up the tire selection to nice sticky stuff..... AND if you want you can also mount Heidenau K60 Scouts 17/19 for DS work
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 11-26-2012, 08:55 AM   #3
Tedthesped
Oddometer: 10
Wink 990 Adv. wheel conversion
Thanks for this info. Have been thinking about doing this on my ' 07. May also look at trading up to a left over 2012 and converting the wheels. Aside from putting out less $$$$, I'm not sure I need a 150 HP dual sport.
Question....what was the cost and what other changes did you have to make other than brake rotors and sprocket??
Thanks.
Tedthesped
Tedthesped is offline   Reply With Quote
Old 11-26-2012, 09:20 AM   #4
wpbarlow
Oddometer: 10,438
Have to give a big +1 on all this. I'll also add that the bike feels more natural (for lack of a better word) on pavement- making fast riding an easier and more enjoyable experience (sorry for getting all Zen). It's like the bike was made for a 19/17 setup.
If you decide to do it, bite the financial bullet and get everything you need for the 2nd set so it's a quick and easy switchover if you think you'll be wanting to keep the 21/18 for more technical riding.
wpbarlow is online now   Reply With Quote
Old 11-26-2012, 01:14 PM   #5
The Gobbler
The Gobbler's Avatar
Oddometer: 192
I have the 19/17 setup on my 990. When I got it I was doing mostly street and it was great! I have the K60 on the rear and it's ok in the dirt, but not great (the wheels). If you plan on moving back and forth you will have to get an adjustable side stand. I cut both my side stand and center stand.
You don't even want to know what the Gobbler is...
Current bike:
2007 KTM 990 Adventure
Past bikes:
2 97 VFR's,
2001 ZX9R,
2004 ZX10 and 3 (yes 3) 2006 ZX10's
2005 Vee
The Gobbler is offline   Reply With Quote
Old 11-26-2012, 03:22 PM   #6
Peanuts
Peanuts's Avatar
Oddometer: 1,565
I cut my side stand and centre stand too.
Peanuts is offline   Reply With Quote
Old 11-26-2012, 07:01 PM   #7
az63u OP
az63u's Avatar
Oddometer: 140
thank you for the valuable info
Old 11-27-2012, 11:52 PM   #8
az63u OP
az63u's Avatar
Oddometer: 140
So what is the best size to order?
2.15 or 2.5 x 19 ?
4.25 or 4.5 x 17?
Old 11-28-2012, 12:49 AM   #9
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
2.15 or 2.5 x 19 ?
4.25 or 4.5 x 17?
4.5 rear and the 2.5 front will work well
Old 11-28-2012, 12:51 AM   #10
az63u OP
az63u's Avatar
Oddometer: 140
Even off road? Cause i plan to fit a K60 scout on it.
Rear tyre size 150/70-17 will be fine?
Old 11-28-2012, 12:53 AM   #11
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
yep. 4.5 rim width will work with the K60 150/70-17
Old 11-28-2012, 12:55 AM   #12
az63u OP
az63u's Avatar
Oddometer: 140
Thanks for the info.
Front 2.5 no problem to clear the front fork? cause oem is 2.15
Old 11-28-2012, 01:07 AM   #13
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
2.5 front rim also not a problem both for tire size and fitting between the forks.
The SM and SD wheel will fit between the ADV fork legs and they are both much wider than 2.5". SM/SD wheels require special adapters for the ADV brake rotors to be re-positioned inboard on each side. But of course these wheels are 17" not 19"
Old 11-28-2012, 02:45 AM   #14
Cactus Dave
Born to Argue
Cactus Dave's Avatar
Oddometer: 693
How do Super Duke sidestands compare to a shortened 990 sidestand, i.e., mounting points & length? I'd like to keep my stock sidestand for 21/18 use, and there are several Super Duke sidestands available on Ebay. TIA.
Cheers,
Dave
Cactus Dave is offline   Reply With Quote
Old 11-28-2012, 05:34 AM   #15
az63u OP
az63u's Avatar
Oddometer: 140
anyone care to show their 19/17 on a adv
Times are GMT -7.   It's 09:31 AM.
