Old 11-05-2012, 05:04 PM   #286
sturgeon
sturgeon's Avatar
Oddometer: 932
Easy to find out - just remove bulb and turn on the ignition.
Sent from my Nexus 7 using Tapatalk 2
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 11-05-2012, 08:25 PM   #287
biodieselandon
biodieselandon's Avatar
Oddometer: 358
I am going to ask the dealer. It would be pretty cool to have an official indicator for aux lights... even though it is completely unnecessary.
The thing I am most concerned with is the cut-out on the switch block. It would sure be nice to have an OEM switch that controls them.
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 11-06-2012, 08:12 AM   #288
TFB43
TFB43's Avatar
Oddometer: 66
Rigid
From BMW F800gs Aux light wiring harness
Factory switch that doesn't work
The switch I made that works.
TFB43 is offline   Reply With Quote
Old 11-06-2012, 08:17 AM   #289
sturgeon
sturgeon's Avatar
Oddometer: 932
The 1200GS fog light switch works, but it's pretty pricey. It replaces the front half of the switch block (front of bike, opposite to the regular light switch). The new switch looks much like the regular light switch except that it sits crossways across the top of the switch block.
Dyslexics Untie!
Old 11-06-2012, 12:12 PM   #290
EIGHTLUG
Lost on purpose.
EIGHTLUG's Avatar
Oddometer: 32
I mounted the Rigid Industries LEDs to Touratech's Crashbars. The 2 position switch was mounted into the blank in the black trim that surrounds the ignition switch.
-Now back to your regularly scheduled thread.
'12 BMW F800 GS TROPHY
EIGHTLUG screwed with this post 11-06-2012 at 03:56 PM
EIGHTLUG is offline   Reply With Quote
Old 11-12-2012, 08:17 AM   #291
Yip
g - n00b
Yip's Avatar
Oddometer: 23
I have the same "trophy" and mounting the aux-lights at the same position, what a co-incident!
But I am worry that when the crash bar touch the ground, the light will be the first to get damage!
"life's a journey..."
Yip is offline   Reply With Quote
Old 11-12-2012, 10:03 AM   #292
danielks
danielks's Avatar
Oddometer: 38
THose are mine!!!
HID 35W Warn WXT 200 2" spot beam
works VERY fine.... it really makes the difference on the road... reaches about to 75% more than the OEM headlights.
here are fit with amber protections, for daylight and traffic.
omeone can make a comparision with the leds??? somewhere here I have pics for a comparision with the Hawk.. Ill ASA I find it!
danielks is offline   Reply With Quote
Old 11-27-2012, 09:14 AM   #293
fireman.peter
fireman.peter's Avatar
Oddometer: 16
GIVI S310 - Trekker Lights
Does anyone have experience with these lights?
http://www.givi.it/Accessories-for-b...Trekker-Lights
F800 GS- 30 years GS
fireman.peter is offline   Reply With Quote
Old 11-28-2012, 03:50 PM   #294
EIGHTLUG
Lost on purpose.
EIGHTLUG's Avatar
Oddometer: 32
No hands on experience with those particular lights and housings, but I'd definitely steer you in the direction of LEDs instead of halogens or xenons. The Pros, in the case of LED lighting, makes it a no-brainer.
Old 11-28-2012, 05:31 PM   #295
picard
engage!
picard's Avatar
Oddometer: 1,254
You covered your turn signals....
Originally Posted by Andres Tamez View Post
This are mi lights!
Baja Design Squadron Lights, they are great!!!! Each of them has 3600 Lumens, I really recomend them!
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard)
picard is offline   Reply With Quote
Old 11-28-2012, 08:26 PM   #296
Avner
Not noob anymore
Avner's Avatar
Oddometer: 136
Twisted Throttle and Skene Design Photon Blasters:
Avner is offline   Reply With Quote
Old 11-29-2012, 05:41 AM   #297
fireman.peter
Oddometer: 16
OK LEDs are nice. What kond of LED do you recommend? Ratio solid price / good quality.
This are mi lights!
Very nice lights, I like them, but $ 300 for each, too much for me.
Old 11-29-2012, 06:36 AM   #298
fireman.peter
Oddometer: 16
Nice lights & nice work!
What kind of type are they?
Where did you buy it and how much do they cost?
Thanks for the reply!
Old 11-29-2012, 07:17 AM   #299
Avner
Not noob anymore
Avner's Avatar
Oddometer: 136
I love the Rigid Industries LEDs. Nice job on the switch! I had the amber ones installed on my old 1200GS (sold), but I used the PIAA switch instead ($24), because I felt it was more rugged. The reason I chose the single Denali LEDs over the Rigid Ind. LEDs for the F800 was for size and weight, but after seeing your setup I kind of wished I got them...
https://www.rigidindustries.com/category-s/131.htm
$199 for two - Highly recommended!
Old 11-30-2012, 01:44 PM   #300
fireman.peter
Oddometer: 16
Thanks for this informacions.
Wich pair would be mostly choosen, one piece of spot and the other flood?
Times are GMT -7.   It's 02:53 PM.
