Old 11-02-2012, 11:45 AM   #106
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
Oh My God!!!! #2
here's Heather Lewis"s feedback on jimmy Lewis's Riding school Facebook page: Let her tell ya what her 1200GSA feels like after going 21/18,,,and FYI,,,,,Psssst,,,THAT woman can RIDE!!!!!:
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 11-03-2012 at 10:25 AM
Old 11-04-2012, 10:28 AM   #107
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,538
Did another ride yesterday, this time with some slab through the canyons. Noticed a little difference going hard into the corners with the 21" but nothing that had me concerned. I am not really into how fast I can carve the canyon roads anyway. Usually there is a lot to look at that gets missed when trying to go too fast.
Life is an adventure that requires the correct equipment
SPOT - bigtodd - where I at now?
bigtodd.whereamiriding.com
bigtodd is online now   Reply With Quote
Old 11-04-2012, 11:02 AM   #108
woody's wheel works
Built to Last
Oddometer: 3,426
want to go fast ,,on knobbies in the canyons???? Psssst...
if you are not counter-steering the beast,,well sign up for one of these great teachers classes:
1,, laine macteague or http://earthrider-amgi.blogspot.com/
2,, Neduro ,,,, http://vimeo.com/18717832 ,,,or,,,,
3.. Jimmy Lewis's classes,,,http://jimmylewisoffroad.com/
was the best skill i picked up in recent time,,you CAN teach old dawgs new tricks...
'tis remarkable how easy and natural it feels to just stay vertical in the saddle and to:
1,,turn right,,push down on right foot-peg
2,,press left knee into tank for stability
3,,push on right handlebar and adjust pressure for how rapidly ya want to turn
opposite sequence for turning left
it's as easy as 1,2,3shared by an old knee dragging canyon carver MRA #11
woody
like i've mentioned before,,i offer/demonstrate that technique for free as part of a 21'' wheel purchase...it truly is uncanny how well you can get the beast to turn with the 21'' shod with D606 street legal knobbies...TKC-80 is another well sticking pavement knobby tire.
woody's wheel works screwed with this post 11-07-2012 at 02:34 PM
Old 11-05-2012, 12:37 PM   #109
DA KLIXTER
Oddometer: 583
Count me in with the believers - I did 200 + miles of dirt this weekend on my 12 with a 21" front wheel. It was better than I could have hoped for.Thanks Woody.
CK
"isn't there an easier trail?"
DA KLIXTER is offline   Reply With Quote
Old 11-05-2012, 04:58 PM   #110
woody's wheel works
Built to Last
Oddometer: 3,426
we did it,,,modified the oem fender,,,relocated it 2"+ clearance
Originally Posted by woody's wheel works View Post
Hi GUYS,,,and yes,I AM working on it,,,ie: the front fender solution don't want to let too much of the cat out of the bag,,,we are finally getting some weather to test out my ideas,,sunny dry weather all the time isn't the ideal testing territory,,,tis the real mud n gumbo I want to check out
Will keep you all posted
Woody
OK,,,it all came together,,had my epiphany ,,followed my instincts,,,so Zach n i cut/whittled/ drilled and fabricated a simple solution to the oem unit from a crashed donor bike ,,,here's what it looks like:
caveat: What you see is the quick n dirty proto-type,,,the finished version will sport nice rounded corners n smooth cuts,,,we can even:
1,,install a mud flap on the rear half for much greater protection
2,,install a amid-flap in the front
3,,if we made a totally new fender,,the shape could be altered as well
4,,I started with the premise yo all had a an oem front fender already,,,hence the cheapest way to
Renovate it into something usefull.
this solution consisted of slicing the rear half of fender in half,drilling/grinding some holes for the lower A-arm pivot,,the front brake line,,and some relief for the L/R lower brake lines...
we fabricated some special brackets to stiffen the front and rear halves of the fender and added a strip of aluminum to tie the split back together....
we may try another version that we cut in half L-R and then provide a joining bracket,,,there is NO MODIFICATION required on any other part of bike,,,that was one of my goals,,,,Sooo,the basic premise worked on the first git go....
Please chime in if you'd like a different shape....this will handle all the complaints of dirt/mist flying up through the fairing,,,'methinks that dirt flying off and toward the front of the bike may still head back???,,,and it will NOT handle the colorado gumbo,,my trick de-gumbo set up will be next,,,in the meantime
this set-up works....
here's Part #
46 61 7 667 681 FRONT WHEEL MUDGUARD, LOWER PART - BLACK
$58.81
woody
woody's wheel works screwed with this post 11-06-2012 at 03:13 AM
Old 11-05-2012, 11:58 PM   #111
kktos
on a bright side of life
kktos's Avatar
Oddometer: 2,345
Thumb
At last ! Excellent, Master Woody :)
I need one, I want one ! :):)
/thierry
Vita brevis, ars longa, occasio praeceps, experimentum periculosum, iudicium difficile
08 R1200GSA Red 21" woody's
morocco 2006 | morocco 2007 | Traces of Kimangao: An HP2 in France, Spain and Italy | Morocco 2008: a F800GS test ride | where the destination is Anamur - Turkey via Greece...
kktos is offline   Reply With Quote
Old 11-28-2012, 05:33 PM   #112
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,538
Last weekend I rode my second LAB2V on the big GSA, will tell you right now, I couldn't have rode 1/3 of the route this year without that 21" wheel. This year's course was set up as a 500 mile desert hare scramble and had every kind of sand imaginalble. The Woody's 21" wheel kept me going straight and solid through it all.
Now I need to order one of those fancy new lower fender mods
Old 11-28-2012, 06:11 PM   #113
F8 Pilot
Bak in the Sadl & Lovinit
F8 Pilot's Avatar
Oddometer: 81
So you were the one GS!
Bigtodd, I was on the Triple Black 1200GS that you went flying past on the second day. I was so exhausted fighting the 19" x17" setup. Is it really that much easier to ride with the 21"? What size rear are you running? Did you go with the Woody's Superlite or just the Excels?
Thanks for responding,
Ross
F8Pilot
"Never Ride Twice on the Same Piece of Earth"
F8 Pilot is offline   Reply With Quote
Old 11-28-2012, 07:44 PM   #114
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,538
Ross
F8Pilot
Hey Ross, you were one of only 2 other 1200GS's I saw anywhere on the route both days. YES, YES, HELL YES the 21" wheel makes such a difference it's hard to believe it is the same bike. I am still running the stock 17" rear wheel but did go to Wilbers suspension sprung and valved for my larger size, that helps too.
Did you ride both days? How much of the route(s) were you able to do? I rode the GSA last year and the course was mainly fire roads and only a couple of sand washes. I don't know if I could have done both days this year with the set up I had last year.
Old 11-28-2012, 08:33 PM   #115
F8 Pilot
F8 Pilot's Avatar
Oddometer: 81
Hey Todd, I only rode the second day and basically started the offroad section at Baker. My riding buddies were on an F800 and an older 1150GS. Thank god I didn't try the whole second day, I would probably still be out there somewhere. It felt like I was riding a snow plow. The first thing I did Monday morning was call Woody's to discuss a 21" front.
Are you running the Tubed or Tubless version?
Since you didn't op for the 18" rear did your new Wilbers raise the back end to compensate?
What width size 21" did you get...1.60" or 1.85"?
Hope to see you at Altrider Taste of Dakar.
Old 11-29-2012, 09:33 AM   #116
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,538
Ha-ha Ross, riding a snow plow is a great description of the GS's sand handling with the stock 19" wheel. Although I have seen some great riders like Jimmy Lewis ride it like it was the easiest thing in the world but, like I said, GREAT riders.
If you thought the sand was bad from Baker to where I passed you, you wouldn't have believed what we rode through in the canyons outside of Barstow ...
I picked up the wheel from another inmate here, it is a HP-2 wheel (tubeless) laced to a GS hub. On day 2 about 2 hours out of Barstow I cut the sidewall of the front tire and got an instant flat. Pulled an emergency tube from a buddy, popped it in and kept right on going..
As for suspension, I am using the Wilbers WESA set up that integrates into the ESA system. The ride height for sure changes with the ESA set on the offroad settings.
Planning to go to Alt Rider Taste of Dakar again, last year was a lot of fun ... those guys know how to build a campfire.
Old 11-29-2012, 10:43 AM   #117
F8 Pilot
F8 Pilot's Avatar
Oddometer: 81
Thanks for the info Todd it helps a lot. This was my first big ride in sand...and my last without a 21" wheel. The event committee told us to start in Baker as the first section was only for small Dual Sports...you must be a great rider as well. Actually where you passed me was some of the easiest riding on the whole trail...it was all the sand before that that wiped me out.
I just attended the Jimmy Lewis school in early November and it was awesome. He actually let me try his GSA with the 21/18 combo. I'm no expert but if I was to compare it to mine...it felt like a Cadillac vs a Kia.
Looks like another 21" customer heading your way Woody.
See you in Pahrump Todd...
Old 11-29-2012, 02:43 PM   #118
LoneStrom
LoneStrom's Avatar
Oddometer: 339
Thanks, looking forward to the update. On another note regarding 21" conversion, came across a GS rider in Alabama talking about the fork spacers he used for his conversion ... what the what?
Here is an image if someone can clue me in.
Hard to tell from the pic, but it looks like he moved the lower fork brace up along the legs. Then used the spacers to make up the gap.
What the what indeed...
LoneStrom is offline   Reply With Quote
Old 12-13-2012, 07:02 AM   #119
Ed
Which way did he go?
Ed's Avatar
Oddometer: 234
Keepin the thread alive
I just ordered new (to me) wheels from Woody's . I called and talked to Zach about the handling characteristics of 19 vs 21 in fronts. Turns out they had a slightly used set of oem hubs laced to Behr 21/17" tubeless Rims. Not quite as strong or blingy as Superlights, but I think I'll be ok. I haven't manage to break my cast wheels no matter how hard I tried. I'm going to run K60s with the stock front fender for now. Zach told me he is going to fit a supermoto fender to the shop mule and see how it works out. I'm (not so) patiently awaiting the arrival. I'll post pics when I get them fitted.
Non Impediti Ratione Cogitationis
Where in the world is Ed? My Spot page.
Ed is offline   Reply With Quote
Old 12-13-2012, 10:33 AM   #120
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,538
You're going to love it. Here is a shot of mine right before we rolled out for the start of this year's LAB2V. The after pic when we got to Vegas the next afternoon is pretty spectacular.
Times are GMT -7.   It's 09:36 PM.
