Old 11-28-2012, 06:00 AM   #13726
Greg Bender
Oddometer: 1,025
Originally Posted by Airvent View Post
While am at it, here's the video of said get off. I don't normally crash, honestly.
Warning, a swear word or two.
I've *NEVER* done that more than a bunch of times :> :> :> :>
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 11-28-2012, 06:04 AM   #13727
Greg Bender
Oddometer: 1,025
Originally Posted by VooDooDaddy View Post
Hey Fellas,
Been awhile since I've visited this thread. Yeah, I know this topic about the 350 being hi-way capable comes up quite often, and more than once I've been fascinated at the responses of how other people's 350s have what seems like a hard time on the highway? I have a '99 DR350SE with Jessie's stock exhaust mod, a jet kit, cut air box and 16T front sprocket and my DR will run 70mph no-problem-o.
I guess I'm just surprised at all the responses about how 'difficult' it is to do highway speeds on these things? Maybe I'm not interpreting things the correct way? And my bike will do 70mph easily with 70lbs of weight behind me. Is it supremely comfortable?...No. Is it the best way to do highway miles?...No.
But its not difficult either.
I hope you didn't interpret my post as a "difficult" post, because I don't find the DR350 difficult to do highway miles on. I've never fit a 16 tooth front sprocket (only gone as high as a 15 tooth). I really should give it a try some day and see if I can swap between 14, 15, and 16 with the same chain and a 41 tooth rear sprocket.
It would be really nice if the DR350 could easily pull 80 - 85 MPH all day long. Those are the type of speeds I would really like to be able to run out here in the West with 75 MPH speed limits. Other machines do that sort of work much better...but then don't do the other stuff the DR350 does so well. Always a compromise...but I'm not going to bigger dual sport machine just to gain MPH for the highway.
Regards,
Gregory Bender
Old 11-28-2012, 06:41 AM   #13728
Timan
Oddometer: 268
Originally Posted by Timan View Post
In my continuing effort to bring back a 1994 DR350 I need a little help. Going over the bike doing some cleaning I ran across a part I can't id. Just in front of the countershaft and above the gear lever is a piece with (6) little nibs and cable looking piece with a brass end about the size of a bb. I went over the parts fiche and never did find it. Looks like it should have a cover over it, with this bike it has no cover. Thanks in advance for help.
Finally found a pic. showing the neutral switch installed. And yes, it looks like mine. Just seems there should be some type of plastic cover over switch. Thanks for the help in pointing me in the correct direction.
Timan is offline   Reply With Quote
Old 11-28-2012, 07:42 AM   #13729
2bold2getold
Oddometer: 1,249
Regards,
Gregory Bender
I have run 14, 15, and 16 X 41 on my stock "98se with the original factory chain still on it. My impression is the 16 drops the RPMs, but I don't feel it pulls a higher speed any easier. If I was going to do a lot of pavement ( cross country trip ) I'd use it just to save some wear and tear. But I like the 15 just as well. I'd rather ride 50mph on small roads. No job, so no hurry.
2bold2getold is offline   Reply With Quote
Old 11-28-2012, 04:53 PM   #13730
MrPulldown
MrPulldown's Avatar
Oddometer: 2,437
Last night I was the garage trying to sort out my parking space for the winter. Durning the summer the garage gets piled up with bikes, camping gear, rafting gear...crap. But by winter I try to get two parking spaces free so that I can enjoy a relatively warm and snow free car in the morning. I got the Mrs spot cleared out about a month ago, and last night almost completed mine. Last night I was organizing my DR350spare parts bins and found something that I thought I would share.
The DR250 comes with a large rear sprocket 49 IIRC. However it used the same stock chain guide as the DR350 fitting 41 or 43 sprockets (depending on the year). If you look at the guide and the sprok, you will notice very little clearance between the two. The way Zuks gets away with this is by fitting the guide to the swingarm via two differenent mounting plates. At first glance they might look the same. But upon further inspecttion the holes are set further back, making the guide sit further forward.
What does this matter. Well you can use a stock chains guide for larger sprockets if you use a stock dr250 guide mounting plate.
Yes not a very exciting post but somethign I found interseting and thought I would share. One of the few differnces between the 350 and its little brother.
Cheers.
94 DR 350 SE
No Load LED Flash Relay and Diode Kits for Sale
MrPulldown is offline   Reply With Quote
Old 11-29-2012, 03:52 AM   #13731
Greg Bender
Oddometer: 1,025
That is good to know. One of the reasons I have not fit a 16 tooth front sprocket is that I would have to remove the factory case saver in front of the countersprocket. With a 15 tooth front sprocket, I already had to grind a little off the case saver so the chain wouldn't rub. I don't know if this is any different on other years/models, but that was my experience on my 1993 dirt model.
Regards,
Gregory Bender
Old 11-29-2012, 04:48 AM   #13732
AtlantaViking
AtlantaViking's Avatar
Oddometer: 818
Replacement Chain Guide
A couple of weeks ago, my rear wheel locked up doing about 30mph on a forest service road. I initially thought i slipped my boot off the peg and grabbed a whole lotta rear brake. I quickly realized that wasn't the issue as the bike ground to a halt. That really would have made for an interesting turn events if had happened in a sweeper on slab - but anyway...turns out my chain guide that mounts under the swing arm gave up and sacrificed itself into my rear sprocket.
I likely threw a rock and cracked it but I have to say after that experience I really dislike the plastic design so here's my question: Has any fabbed or used something other than the factory oem piece? I'm riding without one now - but I really should have something back there...
Thanks for any info...
I'm here to chew bubblegum and kick ass....and I'm all out of bubble gum
06 Suzi DL1K
99 Suzi DR350SE
AtlantaViking is offline   Reply With Quote
Old 11-29-2012, 05:04 AM   #13733
Greg Bender
Oddometer: 1,025
When I bought my DR350, someone had already installed a chain guide from Fredette Racing Products. I replaced some parts on it after I got it and was pleased to learn that replacement parts were readily available from Fredette. I don't have experience with anything else, but I've been very happy the chain guide as it has given me no issues whatsoever.
Regards,
Gregory Bender
Old 11-29-2012, 05:05 AM   #13734
Greg Bender
Oddometer: 1,025
Regards,
Gregory Bender
Old 11-29-2012, 05:16 AM   #13735
AtlantaViking
Oddometer: 818
Regards,
Gregory Bender
Thanks Greg - I'll check them out. I'm almost tempted to fab one up with scrap plate aluminum I have - but I also know that I have a million little projects and probably would be better off just buying one.
06 Suzi DL1K
99 Suzi DR350SE
Old 11-29-2012, 06:32 AM   #13736
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 509
Regards,
Gregory Bender
Jesse has a nice one as well.
http://www.kientech.com/DR350AdjustableChainGuide.htm
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 11-29-2012, 06:59 AM   #13737
AtlantaViking
Oddometer: 818
Originally Posted by GaThumper View Post
Yeap - thx for that one too. I checked on Jesse's site earlier but I really wanted to keep this under $50 and the further the better and Jesse's is a little too much for me at the moment.
06 Suzi DL1K
99 Suzi DR350SE
Old 11-29-2012, 08:40 AM   #13738
2bold2getold
Oddometer: 1,249
Regards,
Gregory Bender
Had a little left on the "98se, after I "clearanced" it.
Old 11-29-2012, 09:02 AM   #13739
Greg Bender
Oddometer: 1,025
Hmmm...I might want to make a custom guard if I move to a 16 tooth countersprocket. That would probably be better for the long run, anyway.
Regards,
Gregory Bender
Old 11-29-2012, 09:18 AM   #13740
MrPulldown
MrPulldown's Avatar
Oddometer: 2,437
Would the guard still fit with the 16t sprocket? Seems like it should. Case savers are cheap if you need to find a replacement due to drinding them down too much. You can get them from bike bandit new OEM for $3 or so.
94 DR 350 SE
Times are GMT -7.   It's 05:39 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
