Old 11-28-2012, 03:16 PM   #6301
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,667
Hey Mutant,
There's no mention about the FET's current rating.
Your wiring dio looks to be the same as in my install guide.
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 11-28-2012, 04:10 PM   #6302
Royal Club
Royal Club's Avatar
Oddometer: 392
Originally Posted by elsalvadorklr View Post
anyone? bike will not restart...
only after it cools down a bit...
when this happened befiore it was due to a rich pilot...BUT dont know...just seems off
valves are in spec
carb has no intake leaks...
ive replaced all pertinent parts in the carb related to issue like the acv, float valve...needle...jets...gaskets etc...
anybody have an idea of what the hrc cam would need pilot jet wise? it obviously needs something different as when I took this carb off it started fine cold and hot...
sorry to repeat myself so much but Im so tired of alwasy fiddling with the bike instead of hopping on it and just go....
when the bike runs however it rips...maybe play with the needle a bit but it rips...
I had the same problem with mine when the temperatures dropped to around 0. Cold start was do-able, hot start a crisis..
What I did was close the fuel to off. grab the manual decompressor, hold the killswitch and kick it a couple of tims (6~10) then open fuel to ON again. and try to kick it.. worked for me. Problem disappeared after the temperatures got milder..
Royal Club is offline   Reply With Quote
Old 11-28-2012, 06:12 PM   #6303
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 715
Originally Posted by 22manyrides View Post
Hey Mutant,
I'm not surprised by that as I rarely see such info published on these things. Thanks a bunch for checking. I was just curious if it would handle different bulb(s) with higher wattage requirements. I have an idea on what components might be inside the FET box, but since they cannot be replaced anymore, I won't be opening mine up to find out
Ghost_Mutant is offline   Reply With Quote
Old 11-28-2012, 06:24 PM   #6304
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,633
stock + cared for =
Mods, hop ups ect =
fixed.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 11-29-2012, 04:32 AM   #6305
lookfar
from the land of OZ
Oddometer: 679
What is it with Supertrap mufflers?
Everybody seems to love them, I haven't seen an American bike without one for a very long time...
It appears to me, that amongst other things,, they cleverly divert some of the hot exhaust gasses directly on to
our expensive plastic bits, and either cover them in black soot, or melt them into an unrecognisable sculpture.
Maybe I am just an old bushie and ex-ringer, but I can't see for the life of me why one would want to purposely, albeit unintentionally destroy or damage one's bike......
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 11-29-2012, 06:25 AM   #6306
elsalvadorklr
southern xr rider
Oddometer: 4,154
thanks,
thats pretty much the honda drill...when hot do de flood it and get some clean air in you hold the throttle wot, kill switch and decomp and cycle through about 10-15 times
used to work like a charm
however having put the hrc cam im assuming it has thrown even my pilot circuit off...
I too thought kikcback was a rich issue...my plug does look darker after doing the idle adjustment before shutdown...
in any case thanks guys
just more tinkering to do huh?
cheers
elsalvadorklr is offline   Reply With Quote
Old 11-29-2012, 06:28 AM   #6307
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by beechum1 View Post
fixed.
jeje you fixed the faces however my bike not! jajaja
any ideas
jet down on pilot?
I do agree withy 22 many just thought that a little modding after all the suspension mods would be the way to go. however the mods HAVE made the bike go wow!!!!!!! jajaja
Old 11-29-2012, 06:31 AM   #6308
elsalvadorklr
southern xr rider
Oddometer: 4,154
the sound was one reason...they also were the only ones who made a pipe for the dual header xrs... like you though I do not like the discs and the way they soot up the whole rear end, plus they are loud! so I havent bought one for my 88 despite the fact that it would work
most recently mental guru posted a link to the trioval mufflers for our years made in italy...waiting on some reviews to see what they are like
anywhoo
Old 11-29-2012, 08:48 AM   #6309
elsalvadorklr
southern xr rider
Oddometer: 4,154
so I had a 60 in there not a 62! geeze...put in a 62 since I dont have a leaner pilot jet and it starts better...
im at 1.5 tuns out...
so would a lean condition cause a no start more so than a rich pilot jet? just wondering
I got 1 kickback but thats a lot less than before
restarted 3 times after that using the drill and she started
oh how interesting this can be! jjajajajaja
Old 11-29-2012, 01:10 PM   #6310
duxrneet
duxrneet's Avatar
Oddometer: 671
Jeez, Christian. You're doing an awesome job of "if it ain't broke, fix it 'till it is!"
On a side note, I doubt if a rich pilot was preventing you from starting. Lean is usually the problem! I'm most of the way through sorting my FCR, so I'm in a carbie frame of mind right now.
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 11-29-2012, 01:37 PM   #6311
Mike the Yank
Oddometer: 450
anywhoo
Have you seen the "Staintune" that came on the Aussie 6's? Very nice piece, nice note with or without baffle.
BTW, that phone call last month only cast me $13 gotta love Telstra!
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Old 11-29-2012, 01:45 PM   #6312
Royal Club
Royal Club's Avatar
Oddometer: 392
On that lean = problem note, isnt that the same reason why the pig will break your leg if you open the throttle while kicking it over? as in, more air = lean = cast for zeh leg?
Royal Club screwed with this post 11-29-2012 at 01:50 PM
Old 11-29-2012, 02:02 PM   #6313
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,289
Good point. Have you seen this eyebrow thingie? Use it to deflect the exhaust gas away from the plastic. Google Supertrapp deflector to find out more.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 11-29-2012, 02:05 PM   #6314
lookfar
from the land of OZ
Oddometer: 679
anywhoo
There is also Musket Mufflers in New Zealand. They have the full range of reproduction factory mufflers to suit our Hondas and others.
I have one on my XL6. It is a very well constructed and solid muffler, bolts up to the original mounting points.
Linky...
http://www.musket.co.nz/musket.asp
Stu in FNQ
1985 XL250R
Old 11-29-2012, 02:53 PM   #6315
Alaskajeff
Alaskajeff's Avatar
Oddometer: 1,254
It works marginally OK. I had one and it still allowed some sooting on fender I finally removed my Supertrapp and went with a nice DG silencer that has a pretty mean growl to it. NOT as loud as my Supertrapp even after it was repacked. I do not have the OEM dual header any longer so the options for replacement silencers are more plentiful.
Palmer, ALASKA
1 Tim 6:11-12 "FIGHT the GOOD Fight"
2011 Verys ADV
92 FATBOY (in rebuild status)
Alaskajeff is offline   Reply With Quote
Times are GMT -7.   It's 01:55 AM.
