11-28-2012, 06:08 PM
#1 |
Oddometer: 20
Mounting a tool box
New to the forum, thanks for all the helpful information the regulars post here. I am thinking about mounting a tool box behind my license plate on my '12, 1200GS. I got the idea on the forum and have seen a couple of pictures here however the search engine makes it difficult to find more info. I have the standard BMW luggage so there is not really enough room to mount anything behind the luggage (think about this when buying the BMW luggage!)
I was looking at these boxes http://www.pelicancases.com/1150-p/1150.htm. Any feedback would be appreciated, it looks pretty easy to do but not sure if there is a better option, if box is a good size, if there are problems others have experienced etc. Thanks. |
11-29-2012, 02:41 PM
#2 |
Oddometer: 2,459
"100 Threads..."
http://advrider.com/forums/showthread.php?t=836736 Item #44 More for GSA's but perhaps some ideas...?? |
11-29-2012, 03:19 PM
#3 |
Cameron Park, CA.
Oddometer: 211
If you find the thread let me know. All I can find is the GSA behind the luggage rack. I would like to see the one you are talking about behind the lic. plate.
11-29-2012, 05:24 PM
#4 | |
Oddometer: 20
11-29-2012, 05:52 PM
#5 |
Oddometer: 2,459
11-29-2012, 06:46 PM
#6 |
One brick shy...
Oddometer: 2,062
“Sorry I'm late, feck'n off takes a lot of time.” " The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder " This post is full of VonBadenisms." - Gordy Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry |
11-30-2012, 02:52 AM
#7 |
Nobody in particular
Oddometer: 396
OK there is this
http://www.advrider.com/forums/showt...hlight=pelican this http://www.advrider.com/forums/showt...hlight=pelican and this http://www.advrider.com/forums/showthread.php?t=681075 I know some are not what you wanted but may get you going in right direction. I will say the pelican on the inside of GSA cases is a pain in the butt to get at. Nice and out of the way mind you but not very easy access. Tubes are accessible all the time. I may put my tubes back on in the spring. My 2 cents anyway.
Were all here because were not all there! 2009 BMW R1200GSA(Grey Boy) 2007 BMW F800ST(Blue Boy) www.danieljenkins.ca |
11-30-2012, 05:05 AM
#8 |
Oddometer: 568
Here's how I did mine on the 1150. Used for a first aid kit. Gotta like Pelican, indestructible and water/dust proof.
11-30-2012, 10:52 AM
#9 |
Oddometer: 274
These are mine:
![]() ![]() ![]() ![]() ![]() ![]() Terry |
11-30-2012, 03:21 PM
#10 |
Oddometer: 396
After seeing these past post i will be moving my pelican in the spring!!
11-30-2012, 03:45 PM
#11 |
I'm a Seoul Man...
If you go solo, and don't have the GSA luggage mounts (I have Micatechs, so no frames), you can always do something like this...it's mine, I have it mounted on a pillion deck plate:
'07 BMW 1200GS and Yamaha WR250X/R (split personality) ![]() Save $5 on a Smugmug account, use this code: hVs9vtN9NsQRQ |
11-30-2012, 08:02 PM
#12 |
Oddometer: 20
Terry and Rockmuncher
The pelican behind the plate is excactly what I had in mind. Ater using it how do you like this type of mount, is there anything you would suggest? Can you fit a decent tool kit in it? Is that the "small" 1150 pelican?
Thanks |
11-30-2012, 08:05 PM
#13 |
Oddometer: 20
Desert Skies
Very nice work! I wish I had the means to fabricate something like that.
12-01-2012, 03:00 AM
#14 |
Oddometer: 473
12-01-2012, 05:48 AM
#15 | |
Oddometer: 568
Here's the interior dimensions of the 1150, 8.18" x 5.68" x 3.62". The only concerns I would have about using it for tools is when you open it, will they all fall out? Also, if they are wet at all when you put them away, they might rust bad being a waterproof box. Worst case scenario, you use it for something else. |
