Old 11-29-2012, 05:53 PM   #1
wjrudo OP
homemade
wjrudo's Avatar
Oddometer: 117
Fuel strip fix?
I've been diving into this problem for a while and may be able to provide a fix. I'd like to get an idea what you've been paying for a replacement strips, if the strips come as an assembly(plastic support, wires, any other items in the tank, etc.) Labor, if it requires resetting the system, etc. Any pics would be helpful. I have a faulty strip in my '07 and have removed it just to look, but haven't bothered to replace it or get a price or anything. The fix would be a direct replacement strip made by an aircraft fuel system manufacturer, built to my specs. Just tossing this out there to see what response I get. Thanks.
wjrudo is offline   Reply With Quote
Old 11-29-2012, 06:38 PM   #2
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,560
It looks like it is $144.32 Mine was fixed under warranty and gets a 2 year warranty for that repair.
scooteraug02 is offline   Reply With Quote
Old 11-29-2012, 07:57 PM   #3
Davis53
Oddometer: 574
Is the strip number ten?
Davis53 is offline   Reply With Quote
Old 12-01-2012, 02:18 PM   #4
Callisto224
Callisto224's Avatar
Oddometer: 1,144
Yes it's number 10 in the drawing. I'm on my 3rd one now (my original went bad this summer). They've been covered under warranty and, according to my dealer (BMW Motorcycles of SE Michigan ), they will continue to be covered under warranty.
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 12-01-2012, 08:00 PM   #5
jzeiler
ADWrencher
jzeiler's Avatar
Oddometer: 109
You can continue to have your dealer replace them under warranty or you can fix them yourself -on the bike with $3.50 tool.
Just zap the two middle pins in the fuel flange four pin connector with a scripto piezo electric lighter. Disconnect the connector and stick the opened end into the flange connector and click it two or three times. The sensor element in the strip is not as flexible as it should be and develops fractures causing an open circuit.
The momentary high voltage arc from the lighter travels the length of the sensor substrate and fuses it back together. I am on my first strip and it failed two weks ago. After zapping it it has worked for two tank fulls.
Note that during the first fill up the Miles to Empty function will re-calibrate itself and be back to normal after about 40 miles of driving.
John
2009 R1200GS (Gone)
2005 K1200LT
2009 K300GT
K4AN
jzeiler is offline   Reply With Quote
Old 12-02-2012, 11:33 AM   #6
Condolini
Fountain of useless info
Condolini's Avatar
Oddometer: 2,137
Mine is an early build '06, doesn't have the strip. Cost almost $700 to fix it, not covered by warranty. Dealer had the strip, didn't have what mine needed. Oh we'll, I have a functioning fuel gauge for the first time in 4 years.
Condolini is offline   Reply With Quote
Old 12-04-2012, 03:25 PM   #7
roadtrip22
roadtrip22's Avatar
Oddometer: 336
I have a 2008 GSA. I was informed that my fuel strip had to be programmed to the bike and a simple plug an play was not an option. Was I mis-informed or can a gs911 perform this task??
roadtrip22 is offline   Reply With Quote
Old 12-04-2012, 03:40 PM   #8
acejones
acejones's Avatar
Oddometer: 5,282
If you had known when you bought it that you would have to pay $ 175 a year for a functioning fuel guage would you have thought that to be a good deal ?
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 12-04-2012, 04:33 PM   #9
jzeiler
ADWrencher
jzeiler's Avatar
Oddometer: 109
All I can say is that when I "repaired" my old strip (2009 GS) and I filled the tank my MTE read 163 instead of the normal 225. It counted up as I drove the first 39 miles and when it got to 205 it started counting down again. Sounds like it was re-calibrating itself. I will report again when it hits the low fuel warning and compare what that to what it used to be as well at the MTE on the next fill up.
No need to pay $175 - just buy a $3.50 Scripto Lighter and zap your old strip back to life.
John
2009 R1200GS (Gone)
2005 K1200LT
2009 K300GT
K4AN
Old 12-05-2012, 09:30 PM   #10
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,970
I seem to remember reading a thread in which someone posted about zapping the things into working order with the right amount of electricity but it sounded complex. A lighter? Really?
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 12-06-2012, 07:12 AM   #11
pancho
Oddometer: 128
Go for it Wheazy! I'll stand by with camera and fire extinguisher! We could become famous! LOL
When are we heading to San Miguel Allende? I'm ready, or am I late?
pancho is offline   Reply With Quote
Old 12-06-2012, 08:09 AM   #12
roadtrip22
roadtrip22's Avatar
Oddometer: 336
I like my bike to not blow it up.. I'd rather spend $175 for a new part than deal with insurance.. Convincing them my bike just blew up for no reason or because i dropped it may only work in movies..
Old 12-06-2012, 08:13 AM   #13
WeazyBuddha
Oddometer: 4,970
Hey Pancho. I was thinking of you the other day.
Yes; I'd very much like to do SMA. I need to get the KLR running but I suppose I could take the GS.
We're doing a valve adjustment, throttle body synch on Saturday, you are welcome to join us. It'll be a bit of tech day, Cory will be doing work on his KLR and Jim will be helping me with the valves and throttle synch. I'm suggesting we get together at 107 cafe for breakfast at 8:30. I'll send an email shortly and will include you.
Old 12-06-2012, 09:26 AM   #14
dede
Lefty
dede's Avatar
Oddometer: 162
Has anyone checked to see if the newer model non strip (float) system would fit the earlier tanks and put out a signal or easily modified signal that the older system would read? Surely this has been thought of, I just haven't read it.
The democracy will cease to exist when you take away from those who are
willing to work and give to those who would not. Thomas Jefferson
dede is offline   Reply With Quote
Old 12-06-2012, 04:47 PM   #15
wonderings
Oddometer: 950
Would like to know that myself, I think I asked that very question, but did not hear if it was possible. I would rather pay a bit more and get a system that will be reliable.
“If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse
and you say that you are neutral, the mouse will not appreciate your
neutrality.” Bishop Desmond Tutu
2010 GSA
wonderings is offline   Reply With Quote
Times are GMT -7.   It's 03:51 AM.
