Old 11-29-2012, 09:35 PM   #15
digger440 OP
digger440's Avatar
Oddometer: 37
I know I said exhaust but here are the Rearsets
What cafe bike is complete without rearsets?
I love the rearsets Boxermetal (be sure to like on facebook) puts out but they were not the look I wanted, much too clean and too nice. I like the look of rubber and steel pegs which say "when you drag me you will be in huge trouble" so I set about to build my own.
I unbolted the stock peg and stared at them I looked at where rearsets normally mount and had an idea-rrrrrr, if I take the stock pegs and mount them where rearsets usually bolt up......
...so I got to work
Left peg first as it has the shifter I cut the support and set it to the side
I thn mocked it up to the upper hole in the rear peg support
Then I had to make a shouldered boss for the shifter to ride so I used a bolt (that was hard as Hades BTW) and put it in the lathe. I turned thread on both ends ad machined a section fo te shift lever to ride
After I machined it it threaded into the peg on one side and nutted to the frame on the other and the shift lever pivots in the middle
On the passenger side I had to cut the squiggly piece out between the peg and the mount hole to get the correct height then weld it back together
now I have to find a way to support them and since they are mounted near the old passnger pegs that seems like a good idea. So I cut up the old passenger pegs to join with the new rearsets.
I love molten metal
The finished product
bolted up and looking like I wanted
Got linkage (even if temporary)
Das Boot
The next chapter is the brake pedal and linkage (I have had too many libations to type much more
BTW I promised exhaust and it is coming
To be continued......
digger440 is online now   Reply With Quote
Times are GMT -7.   It's 07:40 PM.
