Old 11-29-2012, 05:19 PM   #4411
the borg
the borg's Avatar
Oddometer: 106
Originally Posted by Rode2Nowhere View Post
The KLR Dash units look awesome.
I've never ridden with one, but I can't speak highly enough of the Madstad system. 100% adjustable, quiet, turbulent-free air for any rider.
What brand of side racks are you using to mount those pelican cases?
the borg is offline   Reply With Quote
Old 11-29-2012, 05:35 PM   #4412
beemerjim
beemerjim's Avatar
Oddometer: 434
I have an '06, and in the summer I just take the stock shield off & run with the fairing only. I get wind, but it's clean & quiet..No buffeting. To me it's a big improvement over the stock shield. I have a tall shield I put on in the cold weather, and it's noisy, but keeps the cold wind off my chest.
(I'm 5'9" 30" inseam)
JIm
The older I get, the faster I was.
It's all about attitude & timing.
I'm not sure where we're going, but this road seems to be paved with good intentions.
beemerjim is offline   Reply With Quote
Old 11-29-2012, 07:02 PM   #4413
Nitro1970
Nitro1970's Avatar
Oddometer: 191
Which shield is that?
Nitro1970 is offline   Reply With Quote
Old 11-29-2012, 08:39 PM   #4414
KustomizingKid
Oddometer: 678
1989 KLR650 owner checking in!
Broken at the moment... won't rev over 3500 rpms, something wrong in the carb I recon.
KustomizingKid is offline   Reply With Quote
Old 11-30-2012, 12:30 AM   #4415
Aprilia
Oddometer: 710
Slide diaphragm has a hole or slight tear. Pick up a replacement from your local HD shop...1/2 price of your local Kawi dealer.
Aprilia is offline   Reply With Quote
Old 11-30-2012, 01:37 AM   #4416
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,787
Originally Posted by XpressCS View Post
Are there any windshields that bolt to the forks directly and don't rely on the stock fairing mount? That entire assembly is going away on my bike and obviously I'm going to need something that mounts to the forks, or something that doesn't rely on the fairing.
1st gen?
Look at Parabellum.
http://parabellum.com/
I have one on my GS and it's great. I have been pondering getting one for the KLR too.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt screwed with this post 11-30-2012 at 08:37 AM
ausfahrt is offline   Reply With Quote
Old 11-30-2012, 07:34 AM   #4417
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,208
Madstad 18" clear Adventure shield on their RoboBracket system
Originally Posted by greasyboy View Post
bad man!!!
I was thinking bout getting a little more front
I fade mine every time i ride, even using the fluid we use in the race cars
A braided stainless brake line will make a world of difference.
Local company called cobbled-together-outta-the-scrap-bin-at-work.
They're actually Seahorse SE 720 cases, not Pelicans. Less expensive, quote tough, and waterproof.
Don't seem to have any better pics than this. Apologies.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 11-30-2012, 05:41 PM   #4418
mxboy96
mxboy96's Avatar
Oddometer: 65
Tire pressures?
Hey guys. Curious what you guys run for tire pressures, especially offroad? I know factory says 21, but I remember running about 10-12psi on my old mx bike for offroad use. Should you run it that low even for the KLR? What do you guys use? And also, I finally replaced the useless factory dunlop on the front finally with a Pirelli MT21, and it's better(gravel), but not great. Gravels mainly what I ride on. Are your guyz bikes squirrely on loose soil too? Thanks for the input
Tanman
mxboy96 is offline   Reply With Quote
Old 11-30-2012, 05:49 PM   #4419
CA Stu
CA Stu's Avatar
Oddometer: 47,320
D606, 16f/18r.
Any lower around here and you are asking for a pinch flat...
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 12-01-2012, 08:39 AM   #4420
Aprilia
Oddometer: 710
In my area I wouldn't run lower than 18psi. Any 400lb motorcycle will be squirrely on gravel/dirt. You'll get use to it or learn to steer with the throttle. Bike settles down when on the gas...
Old 12-01-2012, 08:46 AM   #4421
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,292
MT21 fronts are great!
I don't run less than 18. Dropping from 20 to 18 makes a huge difference.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is online now   Reply With Quote
Old 12-01-2012, 08:53 AM   #4422
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,353
+1
Also stand up on the pegs, stay loose on the grips,use the pegs for direction,and let the bike dance a bit.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 12-01-2012, 11:38 AM   #4423
beemerjim
beemerjim's Avatar
Oddometer: 434
k270's
approximately
30 on the street
20 in the dirt.
front and rear.
Old 12-02-2012, 02:47 PM   #4424
MC-Shifter
aka Shifter
MC-Shifter's Avatar
Oddometer: 225
Need Front Brake Help
Hey Guys,
Hoping someone can help me out. I bought this CZR system from ebay. The seller has sold a ton of them and has lots of great reviews. But I'm having a strange problem with mine. It fits the bike fine, but the calipers won't bite the rotor until the lever travels all the way to the handle bar. And then it just barely grabs the rotor. If I fiddle with the adjustment screw on the lever, the pads drag on the rotor. Basically, the caliper remains partially engaged. And even with the caliper partially engaged, with the pads dragging on the rotor, significant lever travel is required before the caliper grabs the rotor.
I have installed a new steel braided line, there are no leaks and there is no air in the system. Repeatededly bled the brakes. Everything is new. New caliper, new rotor, new master cylinder/lever, new brake line, new pads, new fluid. I'm stumped.
Wondering if anyone has any experience with this system and/or advice. Thanks
Thanks flea market.
MC-Shifter is offline   Reply With Quote
Old 12-02-2012, 03:42 PM   #4425
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,239
Perhaps the master can't push enough fluid to properly engage the brake caliper. Or there is still air in the lines. I've bled brand new hydros before and sometimes it takes a lot of bleeding to get all of the air bubbles out.
Gents (and ladies), I passed my MSF class today with outstanding success. Just have to wait for my forms to come in the mail and then I can take my DMV permit test. Then I can actually get out on the open road rather than screw around on the trails and private roads around town here
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Times are GMT -7.   It's 11:01 AM.
