Old 11-30-2012, 03:15 PM   #1201
Rjatr
Sideways Sid
Oddometer: 4
Originally Posted by taninthai View Post
I have just fitted a 43t sprocket to mine still have the 14t on front,however my bike is 6 months old and has 3500 km on it so the chain was a bit stretched and it just fitted on, if your bike is new i dont think a 43t will fit unless you change the front first
Thanks for the info, probably fit the bigger rear sprocket later.
IT175H
KTM500MX
DT125LC
GPZ500s
CBR900RRT
CBR900RRY
CRF250L
Rjatr is offline   Reply With Quote
Old 11-30-2012, 09:05 PM   #1202
Bake
adventurer
Bake's Avatar
Oddometer: 10,529
The Bill Blue 280 big bore engine was up and running today. He said he completed the design for the second size engine. Bill's contacts in the business go pretty deep, if he pulls the trigger on these 2 big bore kits, it will happen relatively quickly. It's still his secret what size the bigger engine is, but I think it's about 320cc.
I got my Dobeck fuel controller today and will install it on my bike this weekend. Bill should have the new exhaust tips done soon. I will be testing one of those while he breaks in the 280. He says the cooling capacity can handle a 350, but there just isn't room to go that big.
Bake is offline   Reply With Quote
Old 11-30-2012, 09:14 PM   #1203
taninthai
taninthai's Avatar
Oddometer: 10
Originally Posted by EEKAMOUSE View Post
We have a 13-48 combo on one right now it is nice you guys need to quit messin around and go big haha
Wow i honestly dont know how you have fitted a 48t on there you must have removed the plastic chain guide, my 43t has been rubbing agaisnt the chain guide top and bottom, did you also buy alonger chain.
taninthai is offline   Reply With Quote
Old 11-30-2012, 09:42 PM   #1204
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 341
Flipped chain guide upside down it was a prob but working! Lol its nice and punchy now
EEKAMOUSE is offline   Reply With Quote
Old 12-01-2012, 02:00 AM   #1205
Bladez
Oddometer: 9
Back to the exhaust... I am interested in opening up the stock muffler a bit. On the US models, after you take off the cosmetic endcap, do you have a plate that unbolts to remove the tailpipe from the muffler? On my Thai one, its all welded, but as per a previous post (see #1108), I see one that's bolt-on but I don't know if it was modified that way or not.
Bladez is offline   Reply With Quote
Old 12-01-2012, 04:27 AM   #1206
Ed@Ford
Oddometer: 1,662
EXHAUST TIPS??? Is this some sort of revised spark arrestor? Does it keep spark arrestor function?
Ed@Ford is offline   Reply With Quote
Old 12-01-2012, 06:17 AM   #1207
G19Tony
G19Tony's Avatar
Oddometer: 418
Interesting battery I just found on another site
http://antigravitybatteries.com/?page_id=994
I'm going to look into it more when I get home next week.
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony is offline   Reply With Quote
Old 12-01-2012, 06:43 AM   #1208
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 864
gotta pic?
2014 BMW R1200GS -- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust is offline   Reply With Quote
Old 12-01-2012, 06:46 AM   #1209
ramz
Professional Trail Rider
Oddometer: 2,018
In post #1108, the rider and his friend removed the spark arrester tube from the bolt-on plate. This allows the exhaust to flow more freely, but you lose the spark arrester. Bill Blue's modified bolt-on piece will have a larger diameter tube WITH a spark arrester and perhaps a turned-down tip.
Pics of US bolt-on plate/tube/spark arrester here:
http://rickramsey.net/CRF250Lmods.htm
Scroll down two screens or so.
ramz is offline   Reply With Quote
Old 12-01-2012, 08:18 AM   #1210
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 352
Exciting stuff! Even though I have no plans to own a CRF250L right now because I love my KLX351, it's still great to see this happening. Did Bill ever consider doing a big bore kit for the WR250R? (Alternative option to the Athena kit for people...)
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Old 12-01-2012, 09:12 AM   #1211
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
http://www.advrider.com/forums/showthread.php?t=789727
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-02-2012, 02:02 AM   #1212
Bladez
Oddometer: 9
Ahh, thank you for clarifying that. My Thai muffler does not have that bolt on plate. The tail pipe is simply welded to the end of the muffler. I wonder which one is more free-flow? I have heard that the US bikes have a restricted ECU that can be swapped with a Thai ECU which is totally unrestricted. So I wonder if that would imply that your pipe would be more restricted than ours as well. Maybe I'll just try drilling a couple holes in the end. Or maybe a muffler shop here could cut out my tail pipe and weld a larger diameter one on.
Edit: Just found this; http://world.honda.com/CRF250L/chassis/page03.html which confirms that the US/Can model is different since it has a spark arrestor. This certainly makes our Thai mufflers more difficult to modify! I'll probably eventually bite the bullet and get an aftermarket pipe once I find one that doesn't have massive flat spots like a copy one I tested here, and isn't ridiculously loud.
Bladez screwed with this post 12-02-2012 at 02:13 AM
Old 12-02-2012, 01:21 PM   #1213
Guerillah
Guerillah's Avatar
Oddometer: 103
Bent my shift lever today on a very difficult trail, anyone know what other bikes ours is compatible with? Any advice on which shift lever brand to buy (ruling out aluminum)?
Guerillah is offline   Reply With Quote
Old 12-02-2012, 02:50 PM   #1214
Wargasm
Wargasm's Avatar
Oddometer: 207
I'd stick with aluminum, a stronger metal would only transfer more force to the shift shaft and you don't want that to happen.
Wargasm is offline   Reply With Quote
Old 12-02-2012, 03:15 PM   #1215
Harcomo
Oddometer: 120
Shift lever
Here you go.....if you decide to stay with aluminum.
http://bestdualsportbikes.com/produc...g-shift-lever/
Harcomo is offline   Reply With Quote
Times are GMT -7.   It's 12:53 AM.
