11-30-2012, 08:20 PM
#1 |
rocketman1
Oddometer: 126
Help- R1150GS front brake- no brake light
Hi I have a 2003 R1150GS, first little problem in 3 years. The front brake will not not make the rear brake light operate.
The rear brake brightens the brake light no problem. All other electrics works fine and bike runs well. I have traced the wiring back as far as I can from the front brake and cleaned up the first connection. Has anybody else had this problem? I would like to know where to start . |
11-30-2012, 09:07 PM
#2 |
Taste Gunnels!
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,151
Do you have ABS? The brake lights work opposite for ABS/Non-ABS bikes.
____________________________________________ 2005 GS1150 Adventure - Range Rover, 2002 DR650 SE - Land Rover "Not all who wander are lost" - JRR Tolkien |
12-01-2012, 01:40 AM
#3 |
Oddometer: 256
Sir,
There is a microswitch near the base of the brake handle. You should also hear that click when you move the handle. When you have the servo ABS, the switch is "normally closed" which is the opposite of normal brake light switches, which are "normally open". If I not mistaken the switch has its connector under the front of the fuel tank. |
12-01-2012, 02:42 AM
#4 |
DR Don
Oddometer: 399
Ran into this problem with a 1999 R1100gs, it was the brake light switch. I'm not sure if the 1100 and the 1150 share the same front master cylinder or not, but the brake light switch on the 1100 sits just below and attached to the master cylinder. Over the years, brake fluil had leaked out of the master cylinder bowl and onto the switch. It ate away at the switch until one day, no brake light. Replaced the switch light worked again.
2005 BMW R1200GS 1983 GL1100 Honda Aspencade 1982 Honda GL500 Interstate 1988 Honda NX650 - X2 1987 Honda XL600r |
12-01-2012, 02:45 AM
#5 | |
Oddometer: 21,714
EDIT: replaced ALL with Most. It took some digging, but I did find indications that I was wrong. The parts fiche shows two FD PNs, one for ABS and one without. Based on that, I've got to assume a non-ABS version was available at some point. Twilight Error screwed with this post 12-01-2012 at 03:17 PM |
12-01-2012, 03:12 AM
#6 | |
steptoe
Oddometer: 2,181
The poster is assuming all abs equipped bikes from 1994 up until 2005 are the same. They aren't. The posters example is relevent ONLY to 1150 bikes equipped with ABS AND SERVO brakes from 2003.
www.gsshop.co.uk |
12-01-2012, 10:59 AM
#7 |
Hey Rocky...........
Oddometer: 3,045
And there was a model called the " Sport " that only came in yellow and it did not haave ABS. And the 1150 used different switchgear than the 1100.
___________________________________________ Mike 1998 R 1100 GS 2007 K 1200 GT |
12-01-2012, 02:01 PM
#8 | |
Taste Gunnels!
Oddometer: 1,151
Since the OP has a 2003, he may or may not have servos but if he has ABS he will have servo brakes..
12-01-2012, 03:01 PM
#9 | |
Boss STAG
Oddometer: 3,831
The Battle Bike dont got no stinkin' ABS!! and I believe its an 1150!
I live more in 5 minutes on my motorcycle than some people live in a lifetime............... 52 factorial... WARNING Do not open link if big numbers and concepts scare you!
12-01-2012, 07:43 PM
#10 |
Oddometer: 2,726
Stick your ear next to the front brake handle. Squeeze the handle and see if you hear it clicking. My '99 had issues like that. Maybe it would work, maybe it wouldn't. If you don't hear it click then the plunger switch is not fully activating the light.
I was preparing to replace the switch and started to tear into it to see if I could fix it or replace something. I found the microswitch. I sprayed some contact cleaner and soaked it real well. Exercised it well, stuck it back in the bike and haven't had an issue in over a year.
Where will you be when you get where you're going? Terminus Incognito 1999 1100GS 2007 KLR 650 |
12-01-2012, 07:51 PM
#11 |
rocketman1
Oddometer: 126
Fixed it, R1150GS front brake switch
Thanks for your help guys.
I separated the wired connection juntion which is fixed to the frame just below the handle bars on the right hand side. I checked the resistance to the circuit with my ohm multimeter, and the there was a high resistance ie. 0.50 / 0.60 ohms when operating the handbrake, .should be Zero I removed the microswitch and wiring from below the front brake master cylinder, then checked the open circuit on the bike with a couple of wires and sure enough the brake light works. Ichecked the internet and saw that this replacement part was about $60.00. I thought , thats 3 tanks of gas!! I then decided to pull the wee microswitch apart and clean it up. So I put on my magnification glasses 4x, and if you look very closely you will see that this switch has a little stainless hinged lever, with a very small screw driver lever this clip off, then very carefully use the same jewellers screwdriver to separate the two parts of the switch. Wow inside is a tiny little spring and a set of contacts. All i did was to get some fine emery paper and sand the contacts which are about half the size of a pinhead, I then squirted it all with CRC cleaner and carefully dried it all. At this stage before I checked it with my multimeter, sure enough the resistance was Zero. Fitted it back on the bike, cable tied it all back together and it works perfectly. Zero cost. This took about two hours to complete, fiddley, but satisfying to fix. Thanks for your help again. Cheers |
