Old 11-28-2012, 05:18 AM   #16
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,518
Good luck with your project. Selling some of the extra stuff will pay for what you are doing, or part of it anyway.
---Albert Einstein
Old 11-28-2012, 06:40 AM   #17
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 838
At least that r100 went to an inmate. I bid on it to try and revive Jo-Nathan's r75.
Kt-88 is offline   Reply With Quote
Old 11-28-2012, 12:57 PM   #18
mrbindc
Oddometer: 75
Where are you located in Arlington? I'm in the Del Ray neighborhood in Alexandria. I'm slowly putting together an airhead project bike, might be interested in some parts once you have leftovers.
mrbindc is offline   Reply With Quote
Old 11-28-2012, 05:53 PM   #19
gfx
gfx
gfx's Avatar
Oddometer: 40
Me too. PM me if you have an extra center stand.
1977 BMW R100/7 "Satan's Lawnmower"
R.I.P - 1988 BMW K75S "Red Rocket"
gfx is offline   Reply With Quote
Old 11-28-2012, 06:05 PM   #20
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Originally Posted by centdukesfan View Post
Here is the report from the mechanic...
" On the left Cylinder their is evidence of a possible bent valve and or collapsed valve spring also this cylinder has oil above the piston which is also a signed of possible blown rings. Their is also substantial dabree in this cylinder such as small bits of metal and a lot of carbon, this cylinder also appears to have been inactive for a little bit due to the carbon build up on it their is also some scoring on the cylinder side walls as well.
On the right side cylinder the the cylinder seems okay but it has been burning slightly hot their is evidence of detonation at the top of the cylinder their is a little bit of scoring on the walls as well but not as bad as the other one the left.
The bike will shift into gear but it will not rotate at all meaning the back wheel or motor is completely locked up also the bike has a small oil leak as well."
So the engine is toast from what I read. However, I picked up a 82 r100 frame, engine, tranny and drive train from ebay for $950 and I'm gonna port everything over this winter. Should be a fun project.
Gonna have a ton of /7 extra pieces this winter so be on the lookout.
What does "Blown Rings" mean?
I've seen them broken and worn out but never "blown"....maybe the mechanics terminology for "shot"?
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 11-29-2012, 02:33 PM   #21
centdukesfan OP
Oddometer: 62
No idea what it means, but ill likely find out. Getting the bike Saturday. Ill post at some point what I've got extra. I'm in the Clarendon area.
centdukesfan is offline   Reply With Quote
Old 11-30-2012, 03:41 PM   #22
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 513
Laugh blown Rings = 0 or low compression
blown Rings = 0 or low compression -
Biebs is offline   Reply With Quote
Old 11-30-2012, 04:40 PM   #23
centdukesfan OP
Oddometer: 62
Justin bieber?
Old 12-01-2012, 06:19 PM   #24
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,257
Is this someone who has actual experience with Airheads? The writing leads me to think otherwise.
Old 12-01-2012, 09:50 PM   #25
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
I'd go as far as questioning his qualifications to work on anything that goes suck - squeeze - bang - blow -..........
Kai Ju is offline   Reply With Quote
Old 12-02-2012, 06:56 AM   #26
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,463
Has any disassembly been done yet ? Does it look like this ?
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 12-02-2012, 09:49 AM   #27
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,629
Hmm. I'm pretty hands-on, so I'd be inclined to just tear it down myself and find the real problem(s).
Hot diggity damn! That's amazing.
crazydrummerdude is offline   Reply With Quote
Old 12-02-2012, 10:17 AM   #28
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 984
Mike
If it does look like that...unless you want/need the experience, don't even bother with the tear down except to get good parts. You've probably got metal bits in all the oil passages and pump. If oil pump gouged, block is gone. Rods are probably frozen on the crank, bearings seized, etc, MAYBE good lifters.
Take your new engine, put a set of new rings,,,maybe a timing chain - and ride. Use the old block for a door stop.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 12-02-2012, 11:02 AM   #29
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,738
Ouch. This is what happens when you figure that the noise will go away if you ignore it...
--Bill
'73 R60/5 Toaster
Bill Harris screwed with this post 12-03-2012 at 08:28 AM
Old 12-02-2012, 11:11 AM   #30
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
Makes me wonder how long that one was run before the owner got tired of the noise and lack of power.
Times are GMT -7.   It's 03:38 PM.
