Old 11-27-2012, 11:57 AM   #61
Seba1
Seba1's Avatar
Oddometer: 159
Seba1 is offline   Reply With Quote
Old 11-27-2012, 01:24 PM   #62
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,499
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 11-27-2012, 01:37 PM   #63
Paratrout
Paratrout's Avatar
Oddometer: 176
Joe, thanks for posting on here and sharing your adventure with us! Is there any specific reason you use panniers instead of soft bags?
If you go to the gym everyday and workout you don't feel as sore. Same with riding bikes. The more you ride the easier it gets. -JDowns
2008 KLR 650
Paratrout is offline   Reply With Quote
Old 11-28-2012, 05:45 AM   #64
gagnaou
gagnaou's Avatar
Oddometer: 1,410
Looking forward to this one, thanks for sharing with us on ADVrider, it looks like it is going to be fun and by the look of your pictures with the 990, I am looking forward to see how the 1190 will fare in the same type of environment.
French vacation house for rent! 15 min from the WEC finale this fall!!!
501 FE Husaberg
1190 KTM adventure R
gagnaou is offline   Reply With Quote
Old 11-29-2012, 08:10 AM   #65
Joe Pichler OP
Oddometer: 50
For the long distance trips I’m always using panniers.
The luggage is more protected then in soft bags.
You can lock them on the bike and also in your room.
If you are camping, you can use them as a seat.
Until you have no accident they are waterproof.
Regards
Joe
Joe on tour in Africa
www.josef-pichler.at
Joe Pichler is offline   Reply With Quote
Old 11-30-2012, 08:45 AM   #66
DiasDePlaya
DiasDePlaya's Avatar
Oddometer: 636
Regards
Joe
May I suggest you to use Pelican cases? They are waterproof before, during and after an accident. My bike was totaled years ago, but all in the cases had no damage! Including all my photo equipment that was installed in its own Pelican case.
DiasDePlaya
"Ya veras como quieren en Chile al amigo cuando es forastero"
Traditional song
DiasDePlaya is offline   Reply With Quote
Old 11-30-2012, 09:55 AM   #67
Faulpelz
Offroader
Faulpelz's Avatar
Oddometer: 79
Now the bike is finish for sending to Addis Abeba.
Hello Joe,
when you when you arrive in Ethiopia, and there are problems, then tell them
you come from the GDR.
The people will think...think...think: GDR...those are the with solidarity hangover; of which we have the copper pot ! And everything will be fine...
Hallo Joe,
wenn du in Äthopien ankommst und es gibt Probleme, dann sag Ihnen du kommst aus der DDR.
Die Menschen werden nachdenken...nachdenken...nachdenken: DDR... das sind doch die mit dem Solidaritätsfimmel; von denen haben wir doch den Kupferkessel ! Und alles wird gut...
Tausend Meter im Quadrat,zwischen Minenfeld und Stacheldraht,jetzt wisst ihr wo ich wohne,ich wohne in der Zone.
Faulpelz is offline   Reply With Quote
Old 12-02-2012, 06:01 AM   #68
Marc LaDue
Oddometer: 153
Adding US DVD Format anytime soon?
Hi Joe,
I've been following you via your website for some time now and would love to sit in on one of your presentations, but alas I live in the US and am in Germany only occasionally. I figured watching your DVD's would be an option, but upon closer examination I found them to be PALS format, which works fine for your neighborhood, but not too well over here in the US of A. Do you have any plans on expanding your offerings anytime soon? I know I'd be buying everything you've put out so far, and I suspect a number of other inmates might follow suit as well.
Thanx in advance,
Marc LaDue
Marc LaDue is offline   Reply With Quote
Old 12-02-2012, 12:03 PM   #69
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
Hi Dias
I saw your note and was curious if you were using "Caribou Cases" or if you had made our own Pelican luggage with different luggage mounts and racks.
gbx2001 screwed with this post 12-02-2012 at 06:11 PM
gbx2001 is offline   Reply With Quote
Old 12-02-2012, 04:23 PM   #70
Bullskin
Bullskin's Avatar
Oddometer: 71
I'll use the Pirelli Sorpion Rally 90/90 21" and 140/80 18"
The same tyres I've used on the 950/990 Adventure.
I'll also change the rims to the same rims with I have used he last years.
This is 2,50 inch on the rear and 1,85 on the front.
I've been yust riding 300 km with the new bike, so its hard to say how many miles you can go on one tank.
But a lot more then with the old one. In normal conditions I think it should be around 400 km or even more, but we'll see.
Do the 990 wheels/hubs directly swap over to the 1190 or did you relace the 1190 hubs with narrower wheels?
Bullskin is offline   Reply With Quote
Old 12-02-2012, 04:39 PM   #71
hillsdonsmith
Oddometer: 3
Subscribed! Best of luck!
hillsdonsmith is offline   Reply With Quote
Old 12-02-2012, 04:48 PM   #72
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,780
When does trip start?
Guero from Texas
COHVCO
AMA
PAPA
SJTR
jimmex is offline   Reply With Quote
Old 12-03-2012, 07:17 AM   #73
DiasDePlaya
Oddometer: 636
Originally Posted by gbx2001 View Post
Hi Dias
I used my own mounts that was designed to be used with soft luggage but works very well with the Pelican Cases.
DiasDePlaya
Traditional song
Old 12-05-2012, 12:38 AM   #74
Joe Pichler OP
Oddometer: 50
I used the front hub of the 1190 and changed the rim to a smaller.
On the rear wheel I use the 990 hub but also a smaller rim.
Old 12-05-2012, 12:44 AM   #75
Joe Pichler OP
Oddometer: 50
First the good news from Addis. Thanks to the girls from MACCFA it only takes 3 hours to bring the KTM through customs.
And now the bad news.
Flavio, the fastest Ethiopian on 2 wheels can unfortunately not travel as planned, the first stage with me.
On the Ring Road, a car crashed into him. This idiot drove across the multi-lane main road and Flavio has no chance to avoid the accident.
Several broken ribs and problem with the shoulder are the results. He can’t ride a motorcycle within the next weeks. But I’m glad that not more happend to him.
Times are GMT -7.   It's 07:14 AM.
