Old 11-30-2012, 08:48 AM   #1
motomandan OP
motomandan's Avatar
Oddometer: 446
Power Controller
I received a "Power Controller" from "Hightechkoonass" in the vendor section and couldnt be happier! After a quick install on my 2012 R1200GS. I took it for a ride. No more snatchy throttle, smoother idle, no surging at cruise speeds. Almost eliminated the decel popping entirely. Excellent build quality. PROMPT DELIVERY!. When I receive the one I ordered from "Poolside" I will do a complete comparison and writeup.
motomandan is offline   Reply With Quote
Old 11-30-2012, 10:43 AM   #2
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,262
Just curious, what tests could you make to compare the two?
I ask because among all the vendors there are no specific measurement of the effect they have (and I own one of them and have checked another). The vendors all indicate that the air temperature drops, but they all seem say that the effect on performance can't be measured by an instrument.
roger 04 rt is offline   Reply With Quote
Old 11-30-2012, 11:11 AM   #3
motomandan OP
motomandan's Avatar
Oddometer: 446
What I would like to compare is Quality of build and materials. I would also like to see if they have the same effect on the motorcycle when installed. I will probably run each over a 30 period for the same mileage interval. Keeping note of changes i.e: stumbling , hesitation , surging, fuel economy. After 60 days I will compare my notes!
Old 11-30-2012, 11:34 AM   #4
TuefelHunden
TuefelHunden's Avatar
Oddometer: 600
Hey, what you talkin' bout Wilson??? Is that a cross between a Power Commander and a Performance Controller?
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 11-30-2012, 11:35 AM   #5
motomandan OP
motomandan's Avatar
Oddometer: 446
check here: http://www.advrider.com/forums/showthread.php?t=777887
Old 11-30-2012, 07:57 PM   #6
motomandan OP
motomandan's Avatar
Oddometer: 446
Rode more this evening. Great product!
Old 12-01-2012, 08:23 AM   #7
roger 04 rt
Oddometer: 2,262
I've made dozens of test runs and measurements on my 1150 with test instruments attached you can see many of them in this long thread, Motronic with Wideband O2 Sensor. One of the tests I made while Open Loop shows the improved mixture obtained by adding an IAT reducer (see graph below). It really shifted the Air Temperature seen by the Motronic and that did richen the mixture. However, after I reattached the O2 sensor, even measuring the Open Loop transients (acceleration enrichment) I could not measure any difference after I rode the bike for a couple hours (see the second graphs in the link).
So my question is, what test could I devise or what measurement could I make that would show an effect after I'd ridden with the O2 sensor connected. Any thoughts?
Old 12-01-2012, 08:33 AM   #8
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
Hmmmmmmm......it appears we have a conundrum here.
def is offline   Reply With Quote
Old 12-01-2012, 11:38 AM   #9
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,618
just get out and ride the f*&%ing thing
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline   Reply With Quote
Old 12-02-2012, 06:25 PM   #10
motomandan OP
motomandan's Avatar
Oddometer: 446
Gonna ride a couple hundred miles tomorrow. I will report on if the Power contoller effects the fuel economy
Old 12-02-2012, 06:31 PM   #11
Ayrshire Bull
why the hell not?
Oddometer: 2,618
have fun - and I'd be keen to hear about smoothness - especially the low speed stuff (please) cheers - D
Old 12-03-2012, 06:38 PM   #12
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
Laugh
Kewl! Looking forward to your test!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 12-03-2012, 11:46 PM   #13
Alkinoos
Oddometer: 1
Some time ago I had installed the performance controller to my R1200GS and I also installed a wideband commander to check how it works.
I wasn't happy with it.
The adjustments where primitive.
I've sold it and I bought a rapid bike 3 and a pair of O2 eliminators.
It is ages beyond performance controller.
P.S sorry for my English.
Alkinoos is offline   Reply With Quote
Old 12-04-2012, 06:53 AM   #14
roger 04 rt
Oddometer: 2,262
It will be interesting to hear what you come up with. In order to have a lasting effect, you have to believe that IAT errors (or alterations) are not compensated by your motorcycle's Closed Loop Adaptation-Values function.
Old 12-04-2012, 10:08 AM   #15
motomandan OP
motomandan's Avatar
Oddometer: 446
Rode 294 miles yesterday. Mostly street but about 9 miles gravel . Bike was much smoother at low speed. Surging when slow speed downshifting all but eliminated. Gas mileage was unchanged. I let a friend who has ridden my bike before ride it. I had not told him I had done anything to it. He got off the bike and said "wow it is much smoother now that it is broke in. It doesnt stumble anymore at low speeds" . I then told him I had installed the "Power Contoller" . Remember this or any of the others like it are not to be confused with a fuel management system like a "Power Commander" . These are designed to smooth out low end fuel delivery issues only.
Times are GMT -7.   It's 07:37 PM.
