Old 11-29-2012, 10:32 AM   #121
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,232
Originally Posted by wayne_l View Post
Like your build up so far ..Thanks Have a question on the front end .. which tripple trees did you use for the forks ? did you have to modify the neck bearings to fit ?
The triples and stem are stock DRZ parts. The bearings were replaced with different sizes to match the Stem and Headtube. The diameters were off requiring different bearings but the height of the stem was about perfect for the CB head tube. The steering stops even lined up.
I got the bearings from All Balls Racing. They have lots of information on sizes for fork swaps, and lots of different sizes of bearings.
Luke is offline   Reply With Quote
Old 12-02-2012, 12:02 AM   #122
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,232
Swingarm madness.
As mentioned, the rectangular tubing sprung open when cut. Welding the bevels on to it was a little trickier than planned, but it worked out.
Crap picture, but it's glowing metal.
Stick welds are not subtle.
A scrap that I welded and cut up to check penetration.
More welds, this one with the slag still on.
Measure twice, cut once. Measure 10 times, weld once.
Adding some posts so that the cam snail adjusters will work.
They're a 'tap' fit. These are actually just placeholders. The final ones will be eccentrics that will be adjusted to make the snail positions match, then welded into place.
I put the camera down for a while, and when I picked it up again I had this:
I'd guess it's half done at this point. The cross brace needs to be welded in, then the mounts for the shocks, brake, chain guide and sliders.
Old 12-02-2012, 06:34 AM   #123
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 11,293
Dang Luke, you're really making headway and it sure looks like you are putting a lot of work into this project. It's going to be so much fun seeing the finished product.
Yesterday Jr. stopped by and helped me with my Suzuki then we had an early dinner. We spent dinner chatting about what you are doing with this bike. Thaks for the dinner conversation.
Ladybug0048 is offline   Reply With Quote
Old 12-02-2012, 07:13 AM   #124
norton(kel)
vintage
norton(kel)'s Avatar
Oddometer: 1,250
Subscribed. Man really like this build. Thanks for the report!
norton(kel) is offline   Reply With Quote
Old 12-02-2012, 08:27 AM   #125
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,539
Sorry I didn't stop by last night, Luke. I didn't leave from working on my "project" til after 9pm and you were long gone by then. Quick question, what is the weight difference between the modded swingarm and the stocker?? BTW, looks like you're getting pretty damn good at welding Wanna build a roll cage?
Old 12-02-2012, 02:47 PM   #126
Merfman
Trustin' my cape...
Merfman's Avatar
Oddometer: 900
Subscribed! Excellent work, I'm in awe!
Merfman is offline   Reply With Quote
Old 12-02-2012, 06:56 PM   #127
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 331
Awesome Luke, it's looking great! You've definitely gone where Honda SOHC CB650 swing arms have never gone before!
It appears as if the time to order a set of shocks is drawing near...
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 12-02-2012, 08:02 PM   #128
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,232
I'm glad everyone is enjoying the thread.
The scale says that it weighs a bit under 20 pounds. I'm not so sure about the scale, it feels heavier than that. It's similar weight to the DRZ wheel, so not totally out of line. It's much heavier than stock.
Just trying to spread the axle mounts it's clearly a lot stiffer than the stock one, and that's in its weak direction.
Old 12-02-2012, 08:04 PM   #129
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,232
I think that time passed long ago.
What's the project management rule? Take the schedule and double it.
Old 12-02-2012, 08:15 PM   #130
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 766
More pics...
A few more pics of Luke's swingarm madness;
What would John Penton do?
LC Garage is offline   Reply With Quote
Old 12-03-2012, 07:44 AM   #131
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 814
Subscribed! My first bike was a '76 CB550, and I dreamed of doing something like this. Awesome to see it happening!
DustyRags is online now   Reply With Quote
Old 12-04-2012, 03:39 AM   #132
DOCsprocket
Sprocket
DOCsprocket's Avatar
Oddometer: 514
Holy Mackerel! I've been away too long! That looks killer. My schedule has been crazy, but I'd love to get back in the shop with you. Looks like things are moving along...
2003 F650gs, 2005 KTM 525exc, 2006 Santa Cruz VP-Free
DOCsprocket is offline   Reply With Quote
Old 12-06-2012, 12:56 AM   #133
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,232
You'd better hurry, or I'll finish it without you.
I got some more done on the swingarm this evening.
First up was to weld in the cross brace. This didn't work out quite as hoped. It welded in great, but it pulled the arms together. So now the swingarm is just wide enough to work with the DRZ wheel, but without any spacers. The sprocket fits so I may leave it alone, or I may cut and spread it if there are any other clearance issues.
A stock 550 swingarm is included for scale:
The weigh-in:
20 pounds. Stock is 10, the frame is 30. Ouch. At least it's stout.
Time to install it:
Check the sprocket locations; it looked about right.
Good thing I cut the wedges off the front of the swingarm. The chain should just graze the guard.
Finally, starting on checking the shock length.
Old 12-06-2012, 06:55 AM   #134
Loud Al
Loud Al's Avatar
Oddometer: 3,920
So the swingarm will be the strongest point on the bike
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 12-06-2012, 07:29 AM   #135
oregoncoast
Racing Like a Noob
Oddometer: 4,539
And the heaviest....
It does look pretty damn sweet, Luke.
Times are GMT -7.   It's 09:59 AM.
