Old 11-30-2012, 04:24 PM   #1531
Red_dog
Red_dog's Avatar
Oddometer: 39
normally if something shifts, i can put a bolt in, get 2 turns on the threads and the bolt will pull it straight. this one however, no go. a mate suggested drilling a hole in the front, cuz the front hole (slotted thing) only has vertical movement, im thinking it might be the go as i need to go up and across to the right. and if i do it cleanly, won't be able to see the hole unless i take the bolt out. hidden and sorted! i like it, will post pics when i get it done.
2004 XR250R- The Toy SOLD
2013 CRF250L- The Daily HOON SPEC
2002 Forester- DRIVING MISS DAISY
Red_dog is offline   Reply With Quote
Old 12-01-2012, 10:56 PM   #1532
Red_dog
Red_dog's Avatar
Oddometer: 39
didnt end up lining up correctly,
just left it as it is, as i didnt want to bend/break the lug on the frame if i ever wanted to refit the stock skidplate (unlikely)...its pretty solid as it is..looks schmick..and doesnt impede the bike in any way.
Old 12-03-2012, 08:23 AM   #1533
nbrooks
Oddometer: 30
More Seat Pics
Several more pics of the seat concepts seat. After several rides, it is much more comfortable than stock.
nbrooks is offline   Reply With Quote
Old 12-08-2012, 12:17 AM   #1534
nbrooks
Oddometer: 30
Air Filter Option
I took a stock filter and cut all the paper out. I used a Dremel to cut out the front of the stock filter to make an even surface. I cut to fit Uni Filter bulk foam and siliconed it into the stock filter. This should allow much more air to flow. I am surprised any air passed through the paper of the stock filter. Oiling and cleaning will be a bit difficult since the foam is fixed onto the frame, but it is an option until someone comes out with a good aftermarket filter.
Old 12-08-2012, 10:34 AM   #1535
MrFurious
MrFurious's Avatar
Oddometer: 704
Best Dual Sport Bikes has one in the works, but if I read their site right they're going to be $100. That's pretty spendy for a foam air filter!
Jim B.
MrFurious is offline   Reply With Quote
Old 12-08-2012, 11:45 AM   #1536
Bake
adventurer
Bake's Avatar
Oddometer: 10,521
And the pics the noob posted look like photoshop. Like the guy claiming his bike has a factory plastic tank. I call BS.
Bake is offline   Reply With Quote
Old 12-08-2012, 01:46 PM   #1537
Ed@Ford
Oddometer: 1,646
I'm not about to rain on nbrooks' efforts, but if you look closely, the stock paper filter has a very fancy plastic frame that may have to be replicated...at $$$$$$$ cost by the foam filter vendor. Most foam filters are not much more than a sock or a stocking cap bit of material, and are fairly straightforward to manufacture. Twin Air already makes a filter for the CRF250R street model....but if you look at the parts book, it is a stand alone piece that appears to get sandwiched in in the airbox....quite different from the "L" model....so the L model filter will be way more than the $30 or so for you pay for CRF or XR honda filter assembly. A reuseable "frame" to stretch the foam "cap" over won't be cheap.
Ed@Ford is offline   Reply With Quote
Old 12-08-2012, 09:22 PM   #1538
Red_dog
Red_dog's Avatar
Oddometer: 39
i backpedalled after testing the tank bro. my mistake.
on another note i received my ManRacks rack yesterday afternoon, fitted it up this morning. will post pics later. all in all, fits quite well.
Old 12-09-2012, 04:58 AM   #1539
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 860
And the pics the noob posted look like Photoshop. Like the guy claiming his bike has a factory plastic tank. I call BS.
I zoomed in and examined the edges (go to the photo bucket site and you can use the zoom feature of the browser)- which would be the places that would give it away - there is overhang in material over edges which lead me to believe that the photos are real. If not real, then its a pretty good fake and noob should be doing crop circle and UFO pictures too!
2014 BMW R1200GS -- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust screwed with this post 12-09-2012 at 05:09 AM
SugarDust is offline   Reply With Quote
Old 12-09-2012, 09:59 AM   #1540
nbrooks
Oddometer: 30
Pic of the filter installed.
One more pic of the filter installed on the bike. If you click on the pic it will take you to my photobucket page where you can view the full pic and use the zoom feature if you would like. I have not found a better was to post pics off my camera onto the forum. So if anyone has a better suggestion, please let me know. I did add an aditional bead of siliconearound the edges of the outside of the filter to add a bit more confidence in the filter. I had also ordered an additional stock filter prior to cutting up the one I had, just in case things went wrong, I would still have a filter to use. Overall I am happy with the way the filter turned out. I thought it was quite entertaining for someone to assume I photoshopped the filter, just did not anticipate that one. What would be in that for me? Besides I am not that good with a computer. I came up with an idea due to lack of an aftermarket filter, I tried it, and then shared my results. That's what forums are for. I may be a Noob to this site, but I have had Motorcycles and ATVs for the the past 25 yrs. I always find myself taking things appart to see how they work or to "improve" them . Sometimes it works in my favor and sometimes I end up creating a lot more work for myself. I have put 1000 miles on my CRF in the last two months, mostly riding in the desert of Utah and Arizona. I have really enjoyed the bike and the mods I have made have really opened the bike up. FYI the bulk foam from Uni was about $12 and came with enough foam to cover this filter area about four times, so plenty.
nbrooks screwed with this post 12-09-2012 at 10:06 AM
Old 12-09-2012, 10:09 AM   #1541
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 211
Good work and well said above.
Dave
Husqvarna FE250...Street Legal
Rider1 is offline   Reply With Quote
Old 12-09-2012, 10:11 AM   #1542
Ed@Ford
Oddometer: 1,646
nbrooks:
Do I assume you have foam of one kind only? Cleaned my KLR Twin Air and my XR400 Uni filters recently, and they have real "fine" foam on the inside, and a more coarse foam kinda like your red stuff on the outside.
Also...did you install your seat concepts seat/foam yourself? It sure looks more supportive than stock.
Old 12-09-2012, 12:12 PM   #1543
mxbundy
mxbundy's Avatar
Oddometer: 936
Really, what is this all about?
I really don't get this mentality from some guys on message boards, like the number of posts you have, in some way has something to do with what you are talking about.
What does the op have to gain by misrepresenting his homemade air filter.
Bundy
The 80`s..........ah yes...back in the days when men looked like women, women dressed like whores and the music F@#KING ROCKED!
Check out http://seatconcepts.com/ , your ass will appreciate it!
http://advrider.com/forums/showthread.php?t=621311
mxbundy is offline   Reply With Quote
Old 12-09-2012, 12:13 PM   #1544
mxbundy
mxbundy's Avatar
Oddometer: 936
Does look good, even if I do say so myself!!
Bundy
Old 12-09-2012, 05:39 PM   #1545
nbrooks
Oddometer: 30
Filter and seat info
I did only use one layer of foam. I used Uni Filter part #BF-5 which is rated at 40PPI. Uni Filters most course bulk filter is rated at 30 PPI and most fine is 65 PPI. I am using the 30 PPI foam on all openings on my air box. I popped in 8 Uni Filter box vents, two in the top and six on the cover. I even put a piece of the course foam over my snorkel. Meaning all air entering is going through two filters. Which leaves the question, is 40PPI too coarse to use? Should I just layer a 65 PPI and then put a 30 or 40PPI over it? Just not sure what would be the best balance between low air restriction and best protection. The seat concepts seat is much more comfortable than stock. I did a 145 mile desert ride with the stock seat and I had a hard time sitting down for two days. Same ride with the seat concepts seat and I could sit fine. I guess that's science for you. I did the seat install myself and recommend an air or electric stapler. I used a hand spring loaded stapler and it caused addition work to get the staples to seat all the way in. It's doable with the hand stapler, just made it more difficult.
nbrooks screwed with this post 12-09-2012 at 06:19 PM
Times are GMT -7.   It's 12:20 AM.
