12-03-2012, 03:34 PM
#13981 | |
xendurist
Oddometer: 1,548
These seats range from near mint to faded and discolored. I also have just a blue seat cover that was taken off of a 89 seat but you need the entire seat and cushion right? Maybe someone else knows if the seat attachment changed from 89-90 to 96.
Transalps |
12-03-2012, 03:47 PM
#13982 | |
Oddometer: 1,202
1999 XRV 750 Africa Twin 1996 XL 600v Transalp "Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ... |
12-03-2012, 03:55 PM
#13983 |
xendurist
Oddometer: 1,548
USA bikes were only blue and gray. I had a 1991 TA that did have a black seat.
Transalps |
12-03-2012, 08:05 PM
#13984 |
It's a short cut, really
Oddometer: 4,263
Sure looks like the identical frame and tank so older seats should fit.....
.....unless Honda did something odd and changed the mounting points. My money is on the seats being identical. |
12-04-2012, 04:56 AM
#13985 |
Crashing since 1964
Oddometer: 4,245
I wonder if there'd be any hints in the part numbers between the last model year of one and the 1st of the next? I like how KTM does their part numbers. Each part gets a number that cross references to every bike it fits. I think Honda has a model code in their part numbers. I'm hoping to be enlightened on that.
Michael |
12-04-2012, 08:51 AM
#13986 |
Nobody Home
Hi All,
it's been a while since I stopped in to read and catch up (about 18 months since I had a TA). I was in France for Thanksgiving break and came across this near the Sorbonne. I've never seen black bodywork before (in person). Since most bikes/scoots spend most of their life exposed to the elements, this example needed some TLC (especially the saddle). Happy Holidays! ![]() I have no idea about the model year. I see it has a sliver motor with a rear disc, center-stand and gold rims (I'm pretty sure the wind screen is after-market). Did European models differ that much from US spec stuff or is this example from the early-to-mid 90s? And, no, it's not leaking oil/gas, it had been a damp morning.
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
12-04-2012, 09:19 AM
#13987 | |
Oddometer: 73
Are you absoultely sure the bike is actually lowered, and not raised on rear side? Judging by the above pics, it seems to sit just as high, if not higher than the average Transalp 600. These bikes are very common here in Europe. In the pics it is indeed obvious that the fork tubes are raised in the triple clamps to lower the front end, however overall the bike seems higher than most, which puzzles me. For instance here is a pic of my '99 model ![]() My bike is definitely not lowered in any way. In the meanwhile (since this pic was taken), I cranked the real preload to maximum, which raised the rear end by another 1-2 cm but that's about it.. ground clearance is still crappy, below the officially stated 195mm of this model. In fact, it would be nice if you could measure the ground clearance, between the ground and the bottom of the center stand mount joints, while holding the bike vertical, and under it's own weight only. |
12-04-2012, 04:31 PM
#13988 | |
Oddometer: 1,202
I just purchased a used OEM link on ebay.de which will give me the option of jacking it back up again. Hey, is that an AT skid plate on your TA? Does it bolt right up?
12-04-2012, 10:17 PM
#13989 |
Oddometer: 4,263
The AT bashplate will certainly fit into that space (at least the RD03/04 one would...not the RD07). But the AT plate uses one bolt at the front and the AT plate uses two...the other mounting hole may or may not line up. It doesn't seem like it would be too difficult to mod some brackets to bolt it up, though.
The TA plate from Twisted throttle is much stronger and will bolt right up to the TA. Mine has brushed off some pretty severe hits over the years. |
12-04-2012, 11:17 PM
#13990 | |
Oddometer: 73
Of course, I did see the custom suspension links on your bike. Well, I am not sure exactly to which point on the frame did you measure, but in my case the clearance was about 175mm (that was before I maxed out the preload, I think I will measure again today just to have an idea). Of course, if the center stand mounting joints did not exist at all, ground clearance would be about 20-25mm higher. This is a bad design on the EU frames... the center stand mounting is always the first to hit in certain situations, such as climbing high curbs or crossing railways in not specifically intended places when going offroad
![]() Quote:
The thing is, the higher you wish to mount it, the more you have to cut. As the transalp engine cases are very exposed, protruding a bit below the main frame rails, I wanted a little "buffer" space, around 10mm, between the underside of the engine and the skidplate.I don't know what kind of space is there on a RD04/RD07 AT, but I wanted to allow the skid plate to bend and deform to absorb impacts, not to ruin my engine cases. This also compensates a bit for the height of the centerstand mount joints, and should allow the underside of the bike to slide a bit easier over obstacles. AFAIK, the Africa Twin RD03 skidplate (one-piece model) is a bolt-on on the Transalp frame, but I may be wrong, maybe others can confirm this. |
12-05-2012, 05:11 AM
#13991 |
from Baltic side of river
Oddometer: 405
RD03 skidplate also needs similar modifications as RD04 and RD07 ones to fit TA frame. Though, RD03 skidplate, in my opinion, is best to use for TA.
12-05-2012, 02:34 PM
#13992 | |
Oddometer: 1,202
12-05-2012, 02:58 PM
#13993 | |
Factory Rambler
Oddometer: 1,027
I drilled 2 holes in the rear bottom part and used 2 countersunk bolts to mount the plate to the frametubes, using 2 of these. It has taken a few beatings, never moved, no damage to the mounting points.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy) want to save on Smugmug? use this code (VoUO8M1ukmnMY) |
12-06-2012, 12:24 PM
#13994 |
Loco, pero no estúpido!
Oddometer: 2,266
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
12-06-2012, 12:34 PM
#13995 | |
Oddometer: 2,266
Love the crate! Is it yours? Of course, needless to say that the bike is awesome!
![]() Quote:
