12-03-2012, 01:24 PM
#1 |
Oddometer: 22
Hiding battery in airbox / Lithium batteries
Right, I have my bike fully stripped
and am ready to get it coated etc but one thing I want to investigate is hiding the battery. I hate the location of the stock battery especially when there are no side covers.Boxermetal's under frame unit looks good but a little pricey when postage to the UK is considered so I've been thinking about other places to put the battery. How about the airbox? I intend to use pod filters anyway as this will be a fair weather form over function machine. The little lithium batteries seem ideal and should fit in there nicely and then the cabling can be routed through the holes left in the airbox. Anyone see any problems with something like this? http://www.ebay.co.uk/itm/Lithium-Io...item337dd39347 |
12-03-2012, 01:29 PM
#2 |
Oddometer: 1,026
If you are removing the airbox, then do put the battery there, longways Is best, otherwise with the airbox removed there is a big empty space that just emphasizes the spindly nature of the BMW frame.
Unless you have a short wheelbase bike, you will have to fit some sort of sidecovers, otherwise you will have again a big empty space that needs to be filled. iMHo etc etc
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
12-03-2012, 01:34 PM
#3 | |
Oddometer: 22
12-03-2012, 02:08 PM
#4 |
glutton 4 punishment
Oddometer: 356
if the battery fits, i don't see why there would be any problem hiding it in there if you're going pods. my concerns would be mounting it inside the airbox so it isn't loose, and then fabbing up some sort of cap for the stock airbox holes just for aesthetics...
I like this idea - I too think that the airheads look a little weird without something finishing off that airbox area.
1978 BMW R80/7 "all we need is time and courage." - Renner "A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M www.blindfishz.com |
12-03-2012, 02:35 PM
#5 | |
Semi-Occasional
Oddometer: 1,535
I would eliminate the airbox, but I've not come up with anything that doesn't look hacked together to replace the air filtration. I think I'll be keeping it in place. Pod filters just aren't suited to a bike made for actual traveling -- not the best solution for dust, rain and puddles.
'74/'70 R98/6/GS Traveling Bike (construction under way) '91 Bill Holland Steel w/Dura Ace |
12-03-2012, 02:43 PM
#6 |
Mad Scientist
Oddometer: 3,005
What about something like this.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
12-03-2012, 02:44 PM
#7 |
Oddometer: 909
While in theory I like the idea, anytime someone eliminates the air box, I wonder what the loss of cooling does to the electrical components. How do the lithium batteries handle heat?
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
12-03-2012, 03:14 PM
#8 |
Big Daddy
Oddometer: 34
12-03-2012, 03:52 PM
#9 | |
Mad Scientist
Oddometer: 3,005
12-03-2012, 06:59 PM
#10 |
Jon-Lars
Oddometer: 419
You really don't want to load on a threaded section like that. On top of that, they appear to be cut threads. Jon-Lars screwed with this post 12-03-2012 at 07:15 PM |
12-03-2012, 07:19 PM
#11 |
around the bend
Oddometer: 991
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding. All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV |
12-03-2012, 11:21 PM
#12 |
Mad Scientist
Oddometer: 3,005
I don't understand?
12-04-2012, 01:04 AM
#13 |
Oddometer: 41
![]() ![]() ![]() I dont get it either you could use a 6x1.0 to hold that small load and it would never fail. In fact most "ah-murican" vehicles only use a 1/4-20 or 6x1.0 with a shitty wedge to hold the battery in and it whieighs in at 35-40 lbs. Oh teh noes someone cut some threads; that will snap off like a 13 year old fat ginger in a 25 cent peek-a-booth. seriously man it is a very light static load held by larger than necessary, yet stylish, hardware. ETA it looks like 6X1.0 after I re calibrated my eyes, which make no difference in what I said
R100 cafefighter build in progress http://www.advrider.com/forums/showthread.php?t=844297 digger440 screwed with this post 12-04-2012 at 01:08 AM Reason: still drinking didnt notice the size of the threads |
12-04-2012, 05:29 AM
#14 |
Jon-Lars
Oddometer: 419
Consider what happens when the bike accelerates and decelerates.
The battery's momentum is applied to the structure in the direction of that acceleration. You are side loading those threads, with the length of the shaft acting as a lever. The cut threads are notch points that focus the force, and the base plate attachment gives the lever a fulcrum point. Jon-Lars screwed with this post 12-04-2012 at 05:42 AM |
12-04-2012, 05:52 AM
#15 |
Oddometer: 22
It's a nicely made bit of kit but I don't like the way the batter looks sitting there really. If there was a fibreglass cover or something that hid the battery it would be perfect but I just don't fancy it much!
I will be ordering the choke pulls from you at some point though! |
