12-04-2012, 05:32 AM
#1 |
GGGGG-MEN!!
Oddometer: 96
valve cover leaking after valve check
So I pulled the valve cover to check the valves on my 07 and once I put it all back together the covers are seeping just a bit. I cleaned them and the mating surfaces well enough. My question is, should I have to replace the gaskets after pulling the covers? Never had this prob before but. I haven't done a valve check when it was 20 degrees outside either. Thanks.
Bikers check the weather in the morning to see if they're gonna ride, motorcyclists check to see what they're gonna wear.. 2007 1200gs |
12-04-2012, 06:40 AM
#2 |
®egister this:
Oddometer: 2,950
The gaskets generally survive valve checks, but its possible you may have torn one. I've had some seepage from the spark plug gasket so I make it a point to rotate them and make sure their reseated properly.
12-04-2012, 09:06 AM
#3 |
I have little to say
The OHV cover gaskets on my 2001 GS are OE and have never leaked....never will.
Handled properly and wiped dry of oil prior to re-installing them is the secret. Make sure you wipe dry the surfaces on the cylinder head and OHV cover as well. Insure that the spark plug donuts are aligned correctly. def screwed with this post 12-04-2012 at 03:44 PM |
12-04-2012, 09:24 AM
#4 |
PowerPoint ADV
Oddometer: 5,117
Check the spark plug gasket is rotated so it seals. That is the usual, first place if all were cleaned prior to re-assembly.
Noting should be broken or torn it is only the really extra-credit types who are able to tear these up.
...Dick "...the road goes on forever and the party never ends..." - Robert Earl Keen Go Pyndon! Go Ned! Eight Years |
12-04-2012, 09:58 AM
#5 |
GGGGG-MEN!!
Oddometer: 96
Got it. Operator error.
12-04-2012, 11:20 AM
#6 |
PowerPoint ADV
Oddometer: 5,117
I did this on my 1150 after decades of working and riding bikes. oiled a gortex boot really well.
12-04-2012, 02:07 PM
#7 |
Ride Far - Ride Fast
Oddometer: 4,779
I thought you were supposed to lightly oil the gasket before reassembly .... don't have a manual around to check.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS, 99 R1100S, 2002 R1150GS, 2005 F650 Dakar Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
12-04-2012, 02:33 PM
#8 |
Aspiring Adventurer
Oddometer: 281
Dry, dry, dry
And dry some more
12-04-2012, 03:28 PM
#9 |
Oddometer: 309
12-04-2012, 03:42 PM
#10 | |
And no hogging down on the OHV cover fasteners otherwise, you'll be whining about the stripped threads in your cylinder head. Just a small excerpt from my 2001 BMW REPROM; • Install cylinder head cover. e Caution: Make sure that gaskets are correctly seated. Gaskets and sealing faces must be free from oil and grease. X Tightening torque: Cover screw............................................. ...... 9 Nm |
12-04-2012, 04:10 PM
#11 |
MIL-TFD-41
Oddometer: 872
You sure about the 9Nm def?
I have 8Nm. Not being picky, that's over 10%.
Mike So far, everything that has surprised me has been completely unexpected. BMW R1100RS |
12-04-2012, 04:27 PM
#12 | |
Oddometer: 4,474
Ha,Ha!
"In Wallowas" ==================== 2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
12-04-2012, 04:37 PM
#13 |
ADWrencher
Oddometer: 87
8 or 9 Nm just means turn until the fastner bottoms out and then STOP!
John 2009 R1200GS 2005 K1200LT K4AN |
12-04-2012, 06:13 PM
#14 |
"Cool" Aid!
Oddometer: 41,488
12-04-2012, 06:15 PM
#15 | |
"Cool" Aid!
Oddometer: 41,488
![]() Jim
