Old 12-04-2012, 04:45 PM   #1
jva118 OP
jva118's Avatar
Oddometer: 74
What to use to re-attach ID plates / badges
I have a 77 R60/7 that I need to re-attach the Id plates or badges on the motor. What is the best product for this? High heat silcone or rtv? What do you use?
jva118 is offline   Reply With Quote
Old 12-04-2012, 04:59 PM   #2
wmax351
Oddometer: 743
Gorilla Snot. In other words, trim adhesive for cars,
wmax351 is offline   Reply With Quote
Old 12-04-2012, 05:25 PM   #3
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,560
3M Weatherstrip adhesive. Traditional yellow Gorilla Snot or low-key Black. Roughen up and clean with brake cleaner/acetone/evaproating solvent, apply a thin overall coat to both surfaces, let dry a few minutes, then a "medium" coat to one surface and apply. Removes from fingers, etc, with acetone (etc).
--Bill
'73 R60/5 Toaster
Old 12-04-2012, 05:33 PM   #4
jva118 OP
jva118's Avatar
Oddometer: 74
Thanks for the info. Much appreciated.
Old 12-05-2012, 05:15 AM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
I used self tappers into the starter cover for the engine badges.
boxerboy81 is offline   Reply With Quote
Old 12-05-2012, 07:08 AM   #6
DaveBall
DaveBall's Avatar
Oddometer: 1,163
If you have a body shop near you, you can stop by and see if they have any partial tubes of emblem adhesive. You don't need a whole lot and they usually will be willing to pass along a tube that has only a bit left in it. Sometimes I have previously prepared the bike and emblems (cleaned them all up and ready to apply) and then dropped in with the bike and asked if they had an open tube that I could borrow, in exchange I offer to add a few bucks to their "coffee" fund.
DaveBall is offline   Reply With Quote
Old 12-05-2012, 09:25 AM   #7
oldroadie
Two wheel addict
Oddometer: 472
I'm sure its wrong but I used a thin coating of JB Weld to attach mine. At least that's certain to be heat proof.
oldroadie is offline   Reply With Quote
Old 06-18-2013, 03:21 PM   #8
Ben Carufel
Boxer Addict
Ben Carufel's Avatar
Oddometer: 760
Bumping an old thread instead of starting a new one...
Is there a safe way to get gorilla snot off of the tank? It was losing its adhesive properties so I peeled both tank pads off and would like to clean the old snot off the backs of the pads and the tank before I apply new stuff...
Ben Carufel
'02 BMW R1150GSA - '72 BMW R60/5
Recovering BMW Addict...
Ben Carufel is online now   Reply With Quote
Old 06-18-2013, 04:05 PM   #9
Bill Harris
Oddometer: 8,560
Acetone.
--Bill
'73 R60/5 Toaster
Old 06-18-2013, 04:34 PM   #10
Ben Carufel
Boxer Addict
Oddometer: 760
Originally Posted by Bill Harris View Post
Acetone.
--Bill
Izzat safe on the tank paint?
Ben Carufel
Old 06-18-2013, 05:21 PM   #11
Plaka
Brevis illi vita est
Oddometer: 4,615
Define "safe". Just use it on the area under the emblem.
Personally I use a carbide triangular scraper, then acetone to tack it just before my adhesive.
I stick the emblems on (heavy cloisonne) with a variation of the "2gloo" technique. In the standard 2gloo routine you use a fast weak glue, like hot glue or super glue to hold the part in palce while a strong slow glue, adhesive silicone or epoxy, sets up. In the variation I use assembly tape (red) to hold it while silicone adhesive sets up. Assembly tape is incredibly strong on smooth surfaces and silicone adhesive is almost as strong if it has plenty of surface area and good prep. The dummy screws get silicone adhesive and are just held with masking tape.
Old 06-18-2013, 05:27 PM   #12
Ben Carufel
Boxer Addict
Oddometer: 760
In this case I'm actually talking about the tank knee pads.
Ben Carufel
Old 06-18-2013, 06:14 PM   #13
Plaka
Oddometer: 4,615
Same prep. Don't scrape within 1/4" to 1/2" of the edges of the depression.
razor gasket scraper works better on the big areas.
Old 06-18-2013, 08:12 PM   #14
Bill Harris
Oddometer: 8,560
Should be safe enough for that paint under the 3M adhesive and the kneepads. It won't strip the paint-- you'd need MEK or Methyl Chloride for that. But test a hidden area first...
--Bill
'73 R60/5 Toaster
Times are GMT -7.   It's 08:47 AM.
