Old 12-04-2012, 05:32 AM   #1
mtrdrms OP
Oddometer: 398
valve cover leaking after valve check
So I pulled the valve cover to check the valves on my 07 and once I put it all back together the covers are seeping just a bit. I cleaned them and the mating surfaces well enough. My question is, should I have to replace the gaskets after pulling the covers? Never had this prob before but. I haven't done a valve check when it was 20 degrees outside either. Thanks.
Everyday. No excuses.
2007 BMW R1200GS
2013 KTM 450 XC-F
mtrdrms is offline   Reply With Quote
Old 12-04-2012, 06:40 AM   #2
eric2
®egister this:
eric2's Avatar
Oddometer: 3,797
The gaskets generally survive valve checks, but its possible you may have torn one. I've had some seepage from the spark plug gasket so I make it a point to rotate them and make sure their reseated properly.
Eric
'06 R12GS, '13 s1000RR
Originally Posted by Big Steve View Post
I've yet to see a poor person driving a real gas hog......
lottery: A tax for people bad at math
eric2 is offline   Reply With Quote
Old 12-04-2012, 09:06 AM   #3
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,415
The OHV cover gaskets on my 2001 GS are OE and have never leaked....never will.
Handled properly and wiped dry of oil prior to re-installing them is the secret. Make sure you wipe dry the surfaces on the cylinder head and OHV cover as well. Insure that the spark plug donuts are aligned correctly.
def screwed with this post 12-04-2012 at 03:44 PM
def is offline   Reply With Quote
Old 12-04-2012, 09:24 AM   #4
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,716
Check the spark plug gasket is rotated so it seals. That is the usual, first place if all were cleaned prior to re-assembly.
Noting should be broken or torn it is only the really extra-credit types who are able to tear these up.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 12-04-2012, 09:58 AM   #5
mtrdrms OP
Oddometer: 398
Got it. Operator error.
2007 BMW R1200GS
2013 KTM 450 XC-F
Old 12-04-2012, 11:20 AM   #6
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,716
I did this on my 1150 after decades of working and riding bikes. oiled a gortex boot really well.
...Dick
Smugmug
Old 12-04-2012, 02:07 PM   #7
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,616
I thought you were supposed to lightly oil the gasket before reassembly .... don't have a manual around to check.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 12-04-2012, 02:33 PM   #8
pcwirepro
Aspiring Adventurer
Oddometer: 282
Dry, dry, dry
And dry some more
pcwirepro is offline   Reply With Quote
Old 12-04-2012, 03:28 PM   #9
roadtrip22
roadtrip22's Avatar
Oddometer: 334
Originally Posted by pcwirepro View Post
And dry some more
Always dry and make sure everything is clean the kits you can usually get have a spark plug seal in there for a purpose. I recommend always replacing that seal BC it's a leak your never see till it fouls out your plug
roadtrip22 is offline   Reply With Quote
Old 12-04-2012, 03:42 PM   #10
def
def's Avatar
Oddometer: 10,415
Just the opposite. Dry the gaskets and mating surfaces so there is no oil path from inside the OHV cover to the outside. Use caution when handling the gaskets so as not to bend or crimp them.
And no hogging down on the OHV cover fasteners otherwise, you'll be whining about the stripped threads in your cylinder head.
Just a small excerpt from my 2001 BMW REPROM;
• Install cylinder head cover.
e Caution:
Make sure that gaskets are correctly seated. Gaskets
and sealing faces must be free from oil and
grease.
X Tightening torque:
Cover screw............................................. ...... 9 Nm
Old 12-04-2012, 04:10 PM   #11
MotorradMike
MIL-TFD-41
MotorradMike's Avatar
Oddometer: 1,018
You sure about the 9Nm def?
I have 8Nm.
Not being picky, that's over 10%.
Mike
So far, everything that has surprised me has been completely unexpected.
BMW R1100RS
MotorradMike is offline   Reply With Quote
Old 12-04-2012, 04:27 PM   #12
Wallowa
Oddometer: 5,457
Ha,Ha!
I have 8Nm.
Must just be me...but using a torque wrench and getting that type of accuracy is impossible..like I said at least for me.. 8 or 9 Newton Meters is damn little [5.9 vs. 6.6 ft/lbs].
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 12-04-2012, 04:37 PM   #13
jzeiler
ADWrencher
jzeiler's Avatar
Oddometer: 109
8 or 9 Nm just means turn until the fastner bottoms out and then STOP!
John
2009 R1200GS (Gone)
2005 K1200LT
2009 K300GT
K4AN
jzeiler is offline   Reply With Quote
Old 12-04-2012, 06:13 PM   #14
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,526
And dry some more
Clean, dry is not necessary or preferred.
http://www.jimvonbaden.com/R1200_24K.html
Jim
Old 12-04-2012, 06:15 PM   #15
JimVonBaden
"Cool" Aid!
Oddometer: 53,526
Jim
Times are GMT -7.   It's 10:37 PM.
