Old 11-30-2012, 11:01 PM   #1
lzyellodog OP
lzyellodog's Avatar
Oddometer: 364
Possible recall for 2005 to 2008 R series
Not sure if this has been posted before but I was just looking at the most recent recall from Ford and saw this tidbit.
LINKY
Safety Agency Investigating Fuel Leaks in BMW Motorcycles
The National Highway Traffic Safety Administration is investigating whether it needs to recall about 24,000 BMW motorcycles because of possible fuel leaks.
A report posted on the agency Web site identifies the models as the 2005-8 R Series. The agency says it decided to investigate after receiving 28 complaints and seeing additional reports on Internet forums of cracks in the fuel-pump housing.
There was no mention of fires or accidents.
One owner, who complained to the safety agency in September, said that when he arrived at his destination he noticed a strong smell of gasoline and “my left pant leg with soaked in fuel.”
He found a leak in the fuel-pump housing “in close proximity to the vehicle’s left exhaust pipe and ignition.”
lzyellodog is offline   Reply With Quote
Old 12-01-2012, 12:40 AM   #2
GSMarc
GSMarc's Avatar
Oddometer: 1,006
is it related to this ??
http://www.advrider.com/forums/showthread.php?t=530713
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 12-02-2012, 07:42 AM   #3
Delta61
Delta61's Avatar
Oddometer: 234
Recall
It relates to this problem
http://advrider.com/forums/showthread.php?t=711467
Take a look at the entire thread. I checked mine because of reading this thread and posted pictures of what i found
Jim
"Keep the Greasy Side Down"
10 1200 GSA
07 X Challenge
04 1150 GS(SOLD)
Delta61 is offline   Reply With Quote
Old 12-02-2012, 07:58 AM   #4
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,102
It would be good to see a better resolution on a similar fuel concern for plastic-tank Ducatis. Seems to me if your fuel pump seal is affected and leaks gasoline onto the rear header. . . it may be a concern.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 12-02-2012, 11:30 AM   #5
Tosh Togo
Oddometer: 1,594
The seals that are failing in these fuel pumps are not made of the same material that Ducati fuel tanks are.
-It might be the same cause (ethanol ), but it's a very different problem.
Tosh Togo is offline   Reply With Quote
Old 12-02-2012, 02:18 PM   #6
hillbillypolack
Grumpy Old Goat
Oddometer: 6,102
Yes, I know. Just saying that any leaking gasoline over an engine or header is pretty serious. In both instances, the 'issue' has been known for several years.
2006 HP2e
Old 12-02-2012, 07:15 PM   #7
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,749
Does somebody have to be seriously injured or die in order for action to be taken?
Fuel system leaks on a motorcycle with fuel injection and a high pressure fuel system can be serious.
Thinking out loud here, I would speculate that the NHTSA will give relatively low priority to a motorcycle issue where there have been no property damage or deaths reported.
NHTSA....a bureaucracy in which I have little faith.
def is offline   Reply With Quote
Old 12-03-2012, 11:06 AM   #8
hillbillypolack
Grumpy Old Goat
Oddometer: 6,102
+100
If these issues were from an automotive manufacturer, it would be front page crucifixion in many public media. I am not that close to the GS years affected here, but the recalls I had on my GS were 1) proactively communicated to me from BMW, and 2) resolved with superior parts and/or techniques as in the case of lever interference on 05-07 handguards. Seeing how something similar played out with an Italian manufacturer made BMW look like heroes, as nothing was communicated through NHTSA or Ducati NA. Until I received legal notices it was a class action lawsuit.
2006 HP2e
Old 12-04-2012, 07:39 PM   #9
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,691
Again?
Jim
Old 12-04-2012, 08:56 PM   #10
Tosh Togo
Oddometer: 1,594
Originally Posted by JimVonBaden View Post
Again?
Jim
No... it's STILL a problem.
Not with the bike hardware; the problem is with the swill that passes for gasoline in this country.
the EPA, the DEQ, and the ethanol subsidies.
Old 12-06-2012, 02:58 PM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 51,691
No, are they doing another investigation, or is this just a rehash of the old one?
Jim
Times are GMT -7.   It's 06:28 PM.
