Old 12-03-2012, 12:14 AM   #1
ironslede68 OP
ironslede68's Avatar
Oddometer: 457
replaced regulator/rectifier (06 Buell Ulysses)
on my 06 ulysses and it's still not charging. i put the new plug on the bike side to. put the wires on the same side that the old plug had them on in relation to the lock on the plug. do i have them backwards or should i be looking to replace the stator now as well.
this bike has been one of the best most fun i've ever riden. it does everything i've asked with no complaints so i'd like to get her up and going again. runs good now until the battery gets low
88 Harley FXRS
02 883 hugger
ironslede68 is offline   Reply With Quote
Old 12-03-2012, 12:28 AM   #2
PeterW
Oddometer: 2,639
Yup.
Sorry, I could add more words, but it comes down to that.
You can check the stator before buying a new one though. Use a multimeter and measure the voltages from each wire from the stator to ground, or between each pair. Should all be in the 60-70V AC range and all the same. You need someone with a manual to get exact numbers and where you should measure.
(a $10 eBay meter is fine for this)
Pete
PeterW is offline   Reply With Quote
Old 12-03-2012, 12:42 AM   #3
ironslede68 OP
Oddometer: 457
thanks pete, i've had many older harley's so i have many tools to work with the directions on the new plug didn't say what wire was supposed to be what and all of the wires on the new rectifier/regulator are the same color. it would help if i could find a manual to go with this bike. clear a few things up anyway.
88 Harley FXRS
02 883 hugger
Old 12-04-2012, 05:24 AM   #4
falcn
Squidless Soul
falcn's Avatar
Oddometer: 325
It doesn't matter on a three phase stator which wire goes to which wire on the regulator (as long as it is the input wires from the stator connection).
Your stator was most likely taken out by your regulator when it died, probably due to high resistance at the plug connection from the description you gave.
As stated you can disconnect the stator plug and check the three charging wires against each other in AC Voltage mode on your voltmeter. If you have less than 60+ it is done. Sounds like the insulation between the wires on the stator was made too hot and melted. Now one of the wires (or all three) are shorted together.
If really interested you can rewind your own stator, but most dont think it is worth their time and buy a replacement.
If you put the same style plug back on make sure you put dielectric grease in the connection to keep out moisture to prevent mor corrosion.
I know you said you already bought the regulator - too bad if you didn't get a MOSFET based unit to replace the OEM one. They generate less heat then the SCR based ones.
Just read that many people on Buell forums have used: http://www.customrewind.co/home_mf.htm to rewind their stators. I have no experience with them.
Loving the DS rides
falcn screwed with this post 12-04-2012 at 05:41 AM
falcn is offline   Reply With Quote
Old 12-04-2012, 10:09 PM   #5
ironslede68 OP
Oddometer: 457
just to be clear, the new regulator had the new style plug on it for the winding wires. the plug i replaced is the one from the regulator to the battery. don't know if i have those on the right side or not. haven't had enough spare time to check it again either. lifes not really cooperating right now. thanks for the link and info
88 Harley FXRS
02 883 hugger
Old 12-06-2012, 04:18 PM   #6
ironslede68 OP
Oddometer: 457
anybody got a procedure on testing a regulator?
88 Harley FXRS
02 883 hugger
Old 02-02-2013, 03:08 PM   #7
ironslede68 OP
Oddometer: 457
any of you guys happen to have the oem part number for a stator? thanks
88 Harley FXRS
02 883 hugger
Old 02-03-2013, 10:15 PM   #8
paul56
Usually gruntled
Oddometer: 123
29971-02Y is the oem number for a 38 amp 3-phase 06 Uly stator.
paul56 is offline   Reply With Quote
Old 02-05-2013, 01:28 AM   #9
ironslede68 OP
Oddometer: 457
thanks, i appreciate that.
88 Harley FXRS
02 883 hugger
Old 02-26-2013, 08:23 PM   #10
ironslede68 OP
Oddometer: 457
a look at what i found when i took it all apart.
http://www.youtube.com/watch?v=z29h5...layer_embedded
88 Harley FXRS
02 883 hugger
Old 02-27-2013, 04:38 AM   #11
jjdavidson
jjdavidson's Avatar
Oddometer: 46
Outs! Hope you get it ok. Any idea, what broke it?
jjdavidson is offline   Reply With Quote
Old 02-28-2013, 06:19 AM   #12
ironslede68 OP
Oddometer: 457
when i got it the chain was not adjusted just right, real jerky. i adjusted it and it smoothed out. don't know if it was already hurt or failed later. my first indication that something was wrong was the stator stopped charging. the clutch plates where holding it centered i guess. it was being grabby at stop lights but i'd just put a set of barnetts in it, the race clutches. adjusted them a few times. it straitened up and i didn't think much else about it. like i said it just stopped charging. i finnally got a chance to tear it down the other day and found needle bearing pieces in the rotor so i started looking at everything else real hard but it didn't take long to find. to tell you the truth, i'm getting excited about being able to ride it again. when it's right, it's an awe inspiring bike for sure.
88 Harley FXRS
02 883 hugger
Old 02-28-2013, 05:25 PM   #13
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,394
Nice video showing the problem you found. Maybe post it on Badweb so others can look for a potential problem when they have the primary apart?
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-01-2013, 09:33 PM   #14
ironslede68 OP
Oddometer: 457
i put it up over there already.
88 Harley FXRS
02 883 hugger
Times are GMT -7.   It's 07:59 AM.
