Old 12-04-2012, 06:04 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Rooney exhaust collector/muffler
This is a Rooney creation -- under-frame muffler for offroad airheads. Anybody ever make one of these, or have drawings/ideas?
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 12-04-2012, 06:15 PM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
I was looking into this a while back and wanted to copy a quat-D Ex-box like this:
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-04-2012, 06:32 PM   #3
LoJack
LoJack's Avatar
Oddometer: 1,572
I'd be surprised if this is computer modeled, but still interesting to see (not actually sure if image will work, so I'm linking the post after, which Airhead Wrangler did):
http://www.advrider.com/forums/showp...1&postcount=16
Unfinished and kinda ugly, but interesting to see the inside of a silencer. Is the Rooney aluminum or stainless? I can't really tell. Alu would be pretty nice.
LoJack is offline   Reply With Quote
Old 12-04-2012, 06:37 PM   #4
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Rooney's is stainless. Given where it sits, alu wouldn't withstand any bumps.
I've seen that link, but the collector is in the frame, for "over the top" pipes. I want to make one under the frame, behind the gearbox.
1970 R60/5
Old 12-04-2012, 10:06 PM   #5
isdt BMW
willserv@aol.com
Oddometer: 252
collector box
I would do this in stainless in a flash if I had not already made one in alloy. My 17 peice exhaust mimics the high pipes used by the gold metal winning bikes built by Herbert Schek in the 1973 ISDT. photos coming, I promise. I used two sets of stock head pipes to make up all of the bends. I made all of the peices and had a buddy tig it all together as I only have a 40 year old buzzbox, and a $125 mig.
isdt BMW is offline   Reply With Quote
Old 12-04-2012, 10:20 PM   #6
walkingbear
walkingbear's Avatar
Oddometer: 3,498
pics of the project
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 12-04-2012, 11:53 PM   #7
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
You're talking about one of the in-frame collectors, right? For the reversed pipes?
That wouldn't do for my project since it would put form over function. I'm not going to be doing enduro racing.
1970 R60/5
Old 12-05-2012, 01:08 PM   #8
LoJack
LoJack's Avatar
Oddometer: 1,572
Ok, I just thought it might be a good example of what it could look like. And considering skid plates are often aluminum, and there are ones that double as tool boxes maybe it would work. If weight isn't an issue, then sure, stainless is the way to go.
Old 12-05-2012, 01:17 PM   #9
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Plus...I'm not set up to weld aluminum. Would have to be stainless...extra few pounds.
1970 R60/5
Old 12-05-2012, 06:00 PM   #10
LoJack
LoJack's Avatar
Oddometer: 1,572
That'll do it. And a few pounds down there won't mean a whole lot, I suppose.
Since it's an enclosed part, it's easy enough to purge it. It'll give you stronger welds. Or get some of this stuff:
http://www.solarflux.com/
Old 12-05-2012, 07:23 PM   #11
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
I assume I'm right that this box should not be made of mild steel...? Condensation would sit in there and rot it out...?
1970 R60/5
Old 12-08-2012, 04:57 PM   #12
isdt BMW
willserv@aol.com
Oddometer: 252
Originally Posted by walkingbear View Post
pics of the project
pics are up, big bamboo posted them for me, look at isdtbmw post
Times are GMT -7.   It's 01:28 AM.
