12-03-2012, 02:27 PM
#16 |
sqeezin the bag
Location: the dry side of the blood brain barrier in SW Id
Oddometer: 863
Didn't the Fram filter get a thumbs down from some of the more knowledgable inmates a while back!
I might be wrong... Just ask my X... Sent from my rotary dial iPhone using Tapatalk
I might be wrong, just ask my X... If a man speaks, and there is no woman present to hear him,.. Is he still wrong? |
12-03-2012, 02:36 PM
#17 |
I have little to say
Haven't seen the Fram product mentioned herein.
Fram oil filters do get a poor rating from many due to inferior construction and marginal materials. Some years ago, racers reported the oil filter canisters being blown off the base plate causing motor damage and a crash. Also, I have read of cardboard being deposited in the oil galleries of engines. I would not use a Fram oil filter. I would however, use their air and fuel filters. It is interesting to note their most recent TV ads which show extreme oil pressure tests on Fram oil filters. |
12-03-2012, 02:45 PM
#18 |
A proud pragmatist.
Oddometer: 3,004
Frams or Pennzoil.....the last obviously came from the same factory.
Anyone here ever paid a couple bucks just for the pleasure of gutting them? I have, and kept some interesting pics....
Have tools, will travel!
12-03-2012, 02:48 PM
#19 | |
Also, I would suspect that the two filters have the same pressure relief and antidrainback specifications. Therefore it would follow that either filter could be fitted to either bike. However, it is obvious that the filter freeboard is different for the two applications and therefore, the filters are not interchangeable. Also, I would use caution not to run the smaller filter too long between changes. There is certainly limited filtering capacity in the smaller filter before the pressure relief might come into play. Having never seen the oil filter cavity on the 1200, I cannot comment regarding the fitment but, it is likely that the leaking filter was not tightened down onto the mounting base on the engine properly. Or, the filter canister was Leaking at the seam. |
12-03-2012, 02:50 PM
#20 |
12-03-2012, 04:34 PM
#21 |
A proud pragmatist.
Oddometer: 3,004
Hang on...I have a couple more filters to cut, a Napa Gold and a Purolator, they have been draining for a while so won't make a mess when I cut them up.
Then I will put them next to the standard by which I judge them all, the Fram and take more pics.
12-03-2012, 06:13 PM
#22 | |
12-04-2012, 09:38 AM
#23 | |
A proud pragmatist.
Oddometer: 3,004
![]() I hate Frams, had significant oil pressure losses (15-20psi) on my old Chevy V8 and clattering lifters on cold start ups. May have been caused by oil contamination from coolant turning the cardboard caps to mush but happened twice so switched to "good" filters with metal caps and never happened again. And then someone gave me a brand new Fram and I cut it up, the effing thing wasn't even crimped along the pleats, the metal crimp altough there was right off the pleats. No filtering there.....!
12-04-2012, 06:22 PM
#24 | |
"Cool" Aid!
Oddometer: 41,921
My guess is you have either crap stuck to the filter gasket or seal, or you have a defect in the mounting surface. Jim
12-05-2012, 04:13 AM
#25 |
Get Free
Oddometer: 738
You are the mighty Yoda, Jim. But alas.... You are wrong. Careful inspection multiple times showed that the housing was wiped perfectly clean with no residue or run left behind. The threads were also in great shape. I wish I would have taken a pic before I put the BMW back on.
12-06-2012, 01:56 PM
#26 | |
"Cool" Aid!
Oddometer: 41,921
The only place it can leak is at the rubber sealing surface. I didn't read back, but did you try a new 1100/1150 filter, or just go straight to the 1200? Jim
12-06-2012, 03:33 PM
#27 |
Get Free
Oddometer: 738
Good questions, Jim. We tried the HiFlo, Fram and WIX. We foun the part numbers at the standard places on advrider.
12-06-2012, 04:42 PM
#28 |
r00b
Oddometer: 97
These work for me
KN-164 -- Usually around $11. Been using them & the 163 on other bikes for years. After reading of some problems with the nut twisting off I give it a little stress test prior to install. No failures yet.
Pleasure in the undergarments puts perfection in the work. |
