Old 05-17-2011, 12:55 PM   #61
supershaft
because I can
Oddometer: 9,116
Originally Posted by bmweuro View Post
60k is a lot compared to 70k- 90k for a new one. The running like crap, noise and chewing itself up only comes from a badly worn chain not from worn gears.
With all of this said ride it for 6 to 10 years and worry about it later unless your putting 20k a year on your bike,
You might add unless you want your bike to run right and sound right for longer than a season or two.
A badly worn chain and not from worn gears? You absolutely cannot have one without the other. One half of that setup is just as important as the other half in theory and practice.
But doing a half ass job does sometimes save you some money and work and it will get you down the road in this case. The ignition timing bouncing all over the place matters little to some that seem to be happy with it running and rattling down the road just good enough. Some airheads are proud of the fact that their engine sounds like someone shaking a rattle can of spray paint and yet somehow still runs . . . barely. Nothing at all wrong with that as long as they don't start blaming the machine for their own ways. It's just not my style and I recommend otherwise.
Old 05-17-2011, 08:25 PM   #62
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Originally Posted by Rapid Dog View Post
...INTERESTING READ....(caps off)
2 reasons I'm doing this,
(1) The leaking timing cover
(2) The jumpity timing mark when I look in there with a timing light.
I'm convinced that the PO(s?) F'd around with this bike in a less than knowledgable if not hamfisted manner.
God help me when I have to look inside the driveline...
Well, you can't blame me!
We never cracked the case or swapped the chain. No need to fix what ain't broken and we never had a problem with the timing!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 05-18-2011, 04:33 AM   #63
Beemerboff
Oddometer: 2,330
Cycleworks now has a neat, but pricey, puller kit which pulls the case, bearing and sprocket, and then presses them back on.
Nice if you dont like bashing the end of the crank with a lump hammer.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 05-18-2011, 07:13 AM   #64
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,543
....my case came off easily with the tap of a wooden dowel on each side. No problem there.
I'll be curious to see how the gear R&R goes...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-18-2011, 12:49 PM   #65
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Okay, for those of you that want to do the sprocket on the crank, here is a very cheap tool for the job,
It's a power steering pulley puller that I got at NAPA for $29.00
I have since seen it elsewhere for half of that.
It works on both styles
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 05-18-2011, 02:24 PM   #66
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,543
clearanceclarence
....nice! Good input.
I suspect you'd have to remove the front wheel and fender for clearance?
Old 05-18-2011, 02:45 PM   #67
tony the tiger
yeah - what he said...
tony the tiger's Avatar
Oddometer: 10,470
I know I did! Different puller, same principle...
Tony
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
tony the tiger is offline   Reply With Quote
Old 05-29-2011, 09:01 AM   #68
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,543
Like New!
...well all you FFs will be glad to know you wre right.
I had the timing chain and crank gear (only) replaced and now have a nice legible timing mark.
Add another $400 to this red bitch's build.
Old 05-29-2011, 09:06 AM   #69
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,776
I swapped a crankshaft sprocket yesterday. A standard three legged puller with an air impact wrench had it straight off. The pulses from the impact wrench give a nice smooth pull. Dropped the new sprocket in hot engine oil to warm it through evenly and it went straight on with just a gentle tap to seat it.
Rob Farmer is offline   Reply With Quote
Old 08-08-2012, 02:18 AM   #70
Padmei
enamoured
Oddometer: 3,717
Originally Posted by fishkens View Post
Here's a question: So why didn't BMW provide a spec for a worn chain or timing sprocket (per Clymers)?
It seems that we're entirely on our own when a fairly simple gauge (for sprockets) or spec for chain length could be provided (even bicyclists seem to have invented better guidelines for replacing these components).
Certainly, symptoms (noise, shaky timing marks, etc.) can indicate a need for a replacement but specs would help.
Just curious if anyone has any insights.
Just dragging this up again as it's my job for this week. I was asking myself this question today.
Here's my sprockets. I was wondering whether to replace the crank sprocket before I started reading this thread however I guess a new one is something i won't have to replace again. Thanks to all those sharing knowledge that has made my decision easier
here's mine.
Padmei is offline   Reply With Quote
Old 08-08-2012, 05:33 AM   #71
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,138
They're cheap and the timing/running benefits are dramatic.
It's a no-brainer.
Old 12-05-2012, 05:33 AM   #72
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
for keeps
Photo & Video Sharing by SmugMug
hardwaregrrl is online now   Reply With Quote
Old 12-05-2012, 07:18 AM   #73
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,455
Thanks Robert
Originally Posted by hardwaregrrl View Post
for keeps
Fred * Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified * '73 BMW R75/5 LWB * '94 MZ Silver Star Hack
Beater is online now   Reply With Quote
Times are GMT -7.   It's 05:33 AM.
