Old 12-05-2012, 03:11 PM   #1
Dan Kyle OP
Oddometer: 473
Ohlins Sale
Ohlins Sale for ADVRider Forum Inmates By Kyle Racing.
I have been meaning to do a new Ohlins sale for a while but you know how it goes.
This will be the third or fouth time we have done this so I hope by now we are known as a good Vendor to the Inmates.
What really pushed me to get it done was Ohlins announcing a price increase is on the way.
The new prices will be 5% higher than current Prices.
The New 5% higher prices go into effect on Jan 1, 2013
Ohlins makes 138 BMW shocks, alone, so rather than try and list all the shock prices here, Please use this link to look up what shock you want a price on.
http://www.bmws1000rr.net/pics/advforum.pdf
Please contact me with any questions or post them on this thread, I will take a look each day.
My contact information is:
Dan Kyle
Kyle Racing
831 394 1330
dan@kyleusa.com
Or send me a PM
Dan Kyle screwed with this post 12-06-2012 at 10:21 AM
Dan Kyle is offline   Reply With Quote
Old 12-05-2012, 03:17 PM   #2
Dan Kyle OP
Oddometer: 473
Ok now for some additional information on the Ohlins shocks.
Ohlins uses a series of letters and number to tell us what features each shock has, this is the information on that coding.
These Letter/Numbers are listed on the Link with the pricing next to the Shock Part Number.
Examples of Ohlins Codes:
S46ER1S
S46HR1C1S
S46D
S36DR1S
T36PR1C1
Shock Absorbers - Types and Adjustments
Start by finding out which shock absorber fits your bike. Then identify which kind of shock absorber it is and which adjustment features.
S, T
Single or Twin tube design
36,39,44,46 or 50 mm
Piston diameter
E - Emulsion type
D - Monotube high pressure gas type with internal reservoir in main body
P - Montotube high pressure gas type with external "piggy back" reservoir
H - Monotube high pressure gas type, hose mounted external reservoir
K - Emulsion type for cruiser bikes
Q1 - Progressive damping with two pistons
W - Delivered without spring
Adjustment features
C1 - Adjustable compression damping. Adjuster on reservoir
C2 - Adjustable high & low speed compression damping.
C4 - Electronically controlled (EC) compression damping
R1 - Adjustable rebound damping. Adjuster wheel on end-eye
R1 - Adjustable rebound with adjuster on the reservoir
R4 - Electronically controlled (EC) rebound damping adjuster
S - Hose mounted hydraulic spring preload adjuster
S1 - Electronically controlled (EC) hydraulic preload adjuster
B - Integrated hydraulic spring preload adjuster.
L - Adjustable length
Mechanical spring preload adjuster
Dan Kyle screwed with this post 12-05-2012 at 03:22 PM
Old 12-05-2012, 03:19 PM   #3
teizms
teizms's Avatar
Oddometer: 1,727
what is the recommendation for a 2005 R1200GS. 90% of the riding for this particular bike is with pillion and luggage. Combined weight of the two humans is roughly 290 pounds. The standard height is a bit tall and i would really like it to be a bit lower.
What does the installion usually run?
Why chose this over Wilburs?
Sorry about the basic questions but i am not mechanically gifted.
teizms is offline   Reply With Quote
Old 12-05-2012, 04:32 PM   #4
Dan Kyle OP
Oddometer: 473
Ohlins has a number of shocks for the R1200GS.
In a short shock, which will be about the same or a little lower than your stocker Ohlins Offers the BM508 and BM509.
I am not sure what the installation will run, as it will depend on what accessaries you have on the bike and what the shop hourly rate is.
Please check with whoever you plan to use to install them on that.
I believe Ohlins does these things better than any Motorcycle shock manufacture:
Support
Engineering
Resell Value
Ride Quality
Bike control
Feel
Build Quality
Ohlins has a number of advantages over all the other aftermarket shocks.
The first is support, Ohlins USA is the Distributor of Ohlins shocks in the USA and are owned by Ohlins Sweden.
This requires them to keep a large support staff and a very large inventory of spare parts.
So as the years go by there will always be parts and people who can service Ohlins shocks.
Ohlins has a number of shops like ours that can also do service and in our case warranty repairs if needed.
I work on maybe 1 or 2 Warranty problems a year. I sell more than 2000 Ohlins products a year.
The Warranty is 5 years on DEFECTS of parts or labor. This does not cover normal maintenance.
Ohlins is the largest producer of Aftermarket Motorcycle shocks.
Ohlins shocks are used all over the world at every level, including racing at the highest level.
This gives the 80 Ohlins Engineers first hand experiance in designing a reliable shock.
It means shocks are not just designed on a shock dyno, they are installed on bikes and tested by Ohlins Riders that include former racers.
Ohlins has an internet site called the Ohlins World Site, it lists all Ohlins Products made over the last 30 plus years.
I can look at spec sheets, Installation manuals, spare parts lists drawings, for everything Ohlins has ever made, this is a huge assist when Customers have Questions.
Old 12-05-2012, 04:38 PM   #5
Dan Kyle OP
Oddometer: 473
Ohlins has some new products in the last 12 months for the R1200GS and R1200GS Adv
The first are the ESP Replacement shocks.
Ohlins calls these the Mechatronic Shocks
Here is a link for detailed information on the BM670 and BM671 shock packages.
http://www.bmws1000rr.net/pics/mechatronic.pdf
Dan Kyle screwed with this post 12-06-2012 at 10:22 AM
Old 12-05-2012, 05:00 PM   #6
Dan Kyle OP
Oddometer: 473
The second new product for the R1200GS and R1200GS Adv are the TTX design shocks the BM676/ BM677 for the R1200GS and the BM678/BM679 for the R1200GS Adv
http://www.bmws1000rr.net/pics/dualsportbmw.pdf
I would like to explain a little about TTX type shocks.
Ohlins introduced these to us in 2007.
The are a completely different design them all prior Ohlins shock.
They use a solid piston to move oil to two remote valves with shim stacks.
One is the Rebound circuit and the other is the Compression circuit.
By using a solid piston to two separate valve it solves a number of problems conventional shocks have
First the two circuits, rebound and compression are completely separate, so when one is adjusted the other is NOT affected.
Second the design reduces the possibility of cavitation, this allows Ohlins to reduce the Gas Pressure inside the shock from as high as 20 bar (294 PSI) to 6 Bar (88PSI) .
What this means is lower pressure inside the shock.
Lower pressure trying to push out shock oil, this makes the job of the seals easier, Lower friction, and most important a more reliable shock.
Dan Kyle screwed with this post 12-06-2012 at 10:23 AM
Old 12-06-2012, 12:54 PM   #7
jad3675
Oddometer: 121
Hey Dan -
What's the price on a DU143?
Thanks,
John
'01 Aprilia Falco - '98 Ducati 916
jad3675 is offline   Reply With Quote
Old 12-06-2012, 01:30 PM   #8
Dan Kyle OP
Oddometer: 473
Originally Posted by jad3675 View Post
Hey Dan -
Thanks,
John
PM sent, Thanks, Dan
Old 12-07-2012, 11:01 AM   #9
tkb
Mr. Britten's bike
tkb's Avatar
Oddometer: 173
Great Service and Sale Price, a opportunity not to miss.
I'll bump this thread back to the top of the Vendor list. This is an excellent opportunity to get the Ohlins shocks that will transform your bike at a great price and from a dealer who is knowledgeable and very customer oriented. Give Dan a call, you will not be disappointed.
I have no connection with Dan and Kyle Racing--just bought a set of Ohlins from him yesterday after pestering him with numerous email questions and telephone calls, even changing my order, all of which he handled with good grace--could not be a better person with which to deal.
This ADvRider December sale price is not to be missed, and Dan tells me that Ohlins has announced a 5% price increase to take effect 1/2013. Don't miss out.
tkb is offline   Reply With Quote
Old 12-07-2012, 11:16 AM   #10
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 534
OK, I'll bite.How much to upgrade my 2011 GSA suspension with ESA?
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is online now   Reply With Quote
Old 12-07-2012, 01:19 PM   #11
fast4d
Oddometer: 2,278
sale on forks too?
I'm interested in FRGT202 for S1000rr (2012)
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 12-07-2012, 06:01 PM   #12
Dan Kyle OP
Oddometer: 473
PM with pricing sent.
Thanks, Dan
Old 12-07-2012, 06:04 PM   #13
Dan Kyle OP
Oddometer: 473
Originally Posted by fast4d View Post
sale on forks too?
Sure PM sent
We also have the FGRT811 forks for the S1000RR at $1900 a set.
The FGRT202 forks are more.
Old 12-07-2012, 10:32 PM   #14
greywolves
Too OLD to be a NOOB
greywolves's Avatar
Oddometer: 98
PM me a price on HO 931 please?
Also Ohlins Shocks '07 Triumph Scrambler...
greywolves screwed with this post 12-07-2012 at 10:40 PM
greywolves is offline   Reply With Quote
Old 12-08-2012, 01:48 PM   #15
Dan Kyle OP
Oddometer: 473
PM sent, thanks
Times are GMT -7.   It's 04:37 PM.
