Old 12-05-2012, 11:21 AM   #1
Quickv4 OP
Pro Turd Polisher
Quickv4's Avatar
Location: Dickinson, Nort' Dakohtah- Orig. from Wiscowsin
Oddometer: 550
KZ1100 missfires and dies at idle when warm
I just got a 1982 kz1100a as a project. Got it running. Thoroughly cleaned and set the carbs, made sure the airbox boots seated properly and had no vaccume leaks.
The bike runs good when cold, pulls hard, idles well. However, as it warms up, it will refuse to idle and will hiccup when accelrating hard.
When I pull the plugs from when it stalls at idle, all are black, not wet, but dry black, indicating a rich condition or maybe ignition problems?
Im thinking it may be either the coils or ignition pickups..?
Here is a video from a somewhat cold start to warm up...
http://m.youtube.com/watch?v=bCs6_G8VlUM
Jerry
____________________________
Great forum and Resource for 1st and 2nd gen Honda V4s SabMagIntercept
www.v4hondabbs.com
Quickv4 is offline   Reply With Quote
Old 12-05-2012, 04:18 PM   #2
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,032
Kind of sounds ignition related to me if it runs worse as it warms up.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 12-05-2012, 05:28 PM   #3
Tosh Togo
Oddometer: 1,594
Originally Posted by Dave in Wi View Post
Kind of sounds like it's too rich to me if it runs worse as it warms up.
Fixt.
Tosh Togo is offline   Reply With Quote
Old 12-06-2012, 02:53 AM   #4
manxkipper
Fishpistel
manxkipper's Avatar
Oddometer: 515
Sounds similar to the issue I had many years ago with my Z1300. One of the ignition pickup coils (it had 3) was faulty and only at idle when hot. I assumed the coil was breaking down with heat. Replaced it with one from a Z1000J. No problem thereafter.
Norton 650 Mercury
1936 BSA Y-13 Project
1969 BSA Rocket 3
2014 KTM 1190R
manxkipper is offline   Reply With Quote
Old 12-07-2012, 05:21 AM   #5
Dave in Wi
Dave in Wi's Avatar
Oddometer: 2,032
Originally Posted by Tosh Togo View Post
Fixt.
Entirely possible. What's that old saying, most electrical problems are carb related?
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
Old 12-07-2012, 06:03 AM   #6
Quickv4 OP
Pro Turd Polisher
Quickv4's Avatar
Oddometer: 550
If it is fuel related, why are all four plus indicating rich?
When I rebuilt the carbs, I did not replace the orings for the pilot jet plugs. Ive read that these plugs force the piolt jet to siphon fuel through the main jet instead of the float bowl. Maybe they are leaky, and the idle jets are sucking in too much fuel??
Jerry
www.v4hondabbs.com
Old 12-07-2012, 07:33 AM   #7
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Do you have access to a four gas analyzer?
you don't see luggage racks on a hearse..........act accordingly
Old 12-08-2012, 08:41 PM   #8
channelcat
channelcat's Avatar
Oddometer: 176
if you did not replace the pilot jet o-rings, you did not rebuild the carbs. basic. thanks for the reminder.
http://www.youtube.com/watch?v=CKVMl2Ft_gU
channelcat is offline   Reply With Quote
Old 12-09-2012, 07:14 PM   #9
metalmechanic
Mechanical rider
Oddometer: 1
Sounds like Ur condenser or capacitor for your ignition is shot. Easy fix. I could be wrong tho.... :)
metalmechanic is offline   Reply With Quote
Times are GMT -7.   It's 11:22 PM.
