11-07-2012, 11:15 AM
#586 | |
No endorsement, just as a "for example", 'cos I know that there are other systems available. http://www.digitalguarddawg.com/keyless.html ![]() John
The perverse must persevere |
11-13-2012, 02:22 PM
#587 |
Oddometer: 38
sorry..but those Bosch 6 volt coils for VW beetle are not the same as those for airhead? Whats the difference? If not, what are other options for i-coils?
(a little late with my reply / question...sorry)
the passion to keep fly...thats the best life cause the motorcycle...-moon92 |
11-13-2012, 10:31 PM
#588 |
Beemerholics Anonymous
Oddometer: 7,354
The bosch coils are the same for VWs, but there were different ones - just make sure they've got the same resistance.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
11-23-2012, 01:24 PM
#589 |
Mad Scientist
Oddometer: 2,966
If I'm not mistaken the VW coils are slightly larger in diameter.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
11-23-2012, 02:53 PM
#590 |
Oddometer: 819
Yep, larger in diameter and a bit longer too. The stock mounting brackets will work, but you might have to bend them in a bit so the coil doesn't rub on the tank.
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
12-05-2012, 04:03 PM
#591 |
Oddometer: 668
Can anyone recommend cheaper alternatives to mufflers (other than the very expensive BMW ones) for an airhead?
12-05-2012, 04:09 PM
#592 | |
Oddometer: 819
12-05-2012, 04:11 PM
#593 | |
Stay Horizontal
Oddometer: 1,600
R100RS Gallery, over 800 pictures... |
12-05-2012, 04:21 PM
#594 | |
Stay Horizontal
Oddometer: 1,600
12-05-2012, 04:32 PM
#596 | |
Stay Horizontal
Oddometer: 1,600
12-05-2012, 10:42 PM
#597 |
Oddometer: 2,052
If you are not fussy about originality there are good quality replicas of the Norton peashooters and Dunstall Decibels, etc, around - Flatracer in England or Trojan Classics in Oz usually have them.
Some of the classic guys stateside have them too, at a considerably higher price. I have a Decibel with a Overland 2 in 1 system on my R75/7 and it fitted straight on to the OEM bracket. It has a long straight taper like a Hoske, has better than OEM chrome, sounds better than OEM and flows a bit better too - the stock muffler struggled to cope with the flow from a 2 in 1 but the decibel copes fine.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST |
01-03-2013, 07:29 PM
#598 |
Oddometer: 41
wheel bearing shims
Anyone have a good source for wheel bearing shims for a 74 R90/6 front?
Thanks!! |
01-03-2013, 07:45 PM
#599 | |
Oddometer: 819
I can provide shims for either the /2 or /5. The /5 shims fit the /6 & /7 rear and the older R26 and R27 too. Included is a set of 6 and that is enough to do one wheel, in the worst case, and usually two wheels. Print these pages for your instructions. Six shims of various sizes will allow you to shim spacers to within .001," which is more accurate than either the /2 or /5 wedding ring system. The shims are worth about 5 cents each, but the die costs about $900, for each of the two types. A set of six, two of three sizes, of these shims cost $10, postage included. I sell these by the honor system. Email me with your address and I will mail them out to you with a SASE. It is up to you to insert payment and return. If you don't know how to use them, or don't like them, just return them in the SASE. Less book work for me means a cheaper price to you, so please honor this simple system. Thanks. The kit has six shims, two shims of three sizes from .002" to about .005". This allows adding length to the inside spacer from .002" up to .020", in increments of .001". That is double the accuracy of changing the /5 wedding bands and four times for the /2. Sometimes the shims are cut from metric sized shim material and sometimes American sized, but you still get a useful variety. You may get shims of 2,3 and 4 and sometimes 2, 3 and 5 thou. It matters none at all, because you will have what is needed to get a great variety. I changed my email address in late 2006, but forgot to change it here. Many riders have not been able to order shim kits. I apologize and hope that you will try again. ![]()
01-19-2013, 07:37 AM
#600 |
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,097
WTB: USA "high" bars for R75/5
Mine are pitted and rusty but solid. I just can't bring myself to reuse them so I need to replace them. Let me know if you have a set, thanks!
If you can't fix it with a hammer, you've got an electrical problem! |
