Old 11-28-2012, 10:30 PM   #16
bmwktmbill
Traveler
Oddometer: 5,219
Mikl,
5 years ago I rode across Russia from Vladavostok to Latvia and then through Europe. You can see my KTM in the pictures. I had good luck and only one failure in Mongolia(a head gasket).
I met many Russian people and motorcyclists.
Who can not love the ISH.
I think you will grease the wheel bearings, steering head bearings and swing arm bolt and put on a new chain and sprockets.
I used this chain oiler.
http://www.pro-oiler.net/
I made it around the world on one chain but I needed two countershaft sprockets. Maybe you will take an extra countershaft sprocket with you.
Keep having fun!!!!
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-29-2012, 07:35 AM   #17
Pauls2ndblessing
Oddometer: 99
Great thread, can't wait for the ride report!
Pauls2ndblessing is offline   Reply With Quote
Old 11-29-2012, 11:36 AM   #18
Mikl Freeman OP
Spaceship Earth!
Mikl Freeman's Avatar
Oddometer: 39
Originally Posted by atravlr View Post
Dont forget to add some rubber/silicon along the edges, the vibration and the sound of metal on metal might make you miss hearing other important noises along the way.
Guys, Thank you for good advice!
Bill, I heard about your trip ) It is great) I'm always glad to hear about deep russian and 3rd world countries trips without comfort because it's trust, experience and karma)) Peace.
Destiny in Your Hands, Freedom in Our Hearts!
Mikl Freeman screwed with this post 06-02-2013 at 04:36 AM
Mikl Freeman is offline   Reply With Quote
Old 11-29-2012, 04:40 PM   #19
discoganya
discoganya's Avatar
Oddometer: 204
That skid plate looks crazy Good luck
2005 DR650, 2002 SV650, 2003 ZZR1200
discoganya is offline   Reply With Quote
Old 11-29-2012, 05:08 PM   #20
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,474
Nice job!
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 11-29-2012, 05:17 PM   #21
davesupreme
grand poobah
Oddometer: 1,743
yeah, man.... you look darn good!.....
davesupreme is offline   Reply With Quote
Old 11-30-2012, 02:41 PM   #22
Mikl Freeman OP
Spaceship Earth!
Oddometer: 39
workshop
Yeah! Brothers! Thanks for watching!
In the last days i finished one engine rebuild project in time with my build up, by the way it was XRR too )..The customer had lost the oil level and burnt all over from head to rod...
Mikl Freeman screwed with this post 06-02-2013 at 04:38 AM
Old 12-05-2012, 04:22 PM   #23
Mikl Freeman OP
Spaceship Earth!
Oddometer: 39
Hello Brothers! i'm back to report to you how the moving ahead is going!
The time is accelerating again and again..No rush but that's how I feel the time around, then i stop and have meditative analysis of the conditions..
So let's go to look at some work..
one week before i installed a sight tube..
Installed new wheel bearings , seals
installed front end with BRP submount
i ordered 22mm dust seal and took the full speedo mechanism off ...
My good old friend ground out new collars for me
I cleaned the frame
BRP submount and front end
installed hot grips with koso adjuster and scott grips
HDB handguards
My Xr has another master cylinder which I think is from TDM or other..So I relocated one hole for HDB switch holder installation and tapped the hole.
At this week I've been busy following
Installing new bearings not OEM but i think better than old ones)
Next it was fixing some issue like swingarm linkage frictions..
I tried to fix it with a very slim chrome stainless steel plate about 0.25 mm
Also i bought new linkage in nice condition on ebay, my one was eaten.
all was greased..
After that I had a chance to install KTM fan with therm switch..
I wanted to make it simple but made it difficult))) I cut old brackets from body and made new ones from alu plate and welded them on.
For the switch i found a good solution in this forum. I used a trail tech adapter.
I found time for the tank bracket! Thanks and big respect to Hodakaguy for the idea and work on it! I used this solution and built the same one from stainless steel metal..
bushings and washers was made from poliuretan
Installing new hi performance thermostat ordered from xr's only
and silicone hoses kit
THANKS FOR LOOKING! To be continued...
Mikl Freeman screwed with this post 06-02-2013 at 04:57 AM
Old 12-06-2012, 07:58 AM   #24
Kawidad
Kawidad's Avatar
Oddometer: 5,074
Nice work!
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-06-2012, 09:27 AM   #25
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,100
Great attention to detail.
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 12-08-2012, 02:14 AM   #26
Mikl Freeman OP
Spaceship Earth!
Oddometer: 39
Originally Posted by Kawidad View Post
Nice work!
Thank you, Guys!
and yeah) i think details make up the whole result...it's not only about material things it's everywhere in our life.
Now I'm busy with my last customer project, full rebuild of FLHX with SE 110" kit...
Have a good time, brothers!
Mikl Freeman screwed with this post 06-02-2013 at 04:59 AM
Old 12-08-2012, 02:44 AM   #27
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,672
You are very talented.
Nice job.
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 12-09-2012, 10:28 AM   #28
Steveman
Steveman's Avatar
Oddometer: 471
Amazing mate, just amazing. Love your modifictions...
Regards
Steve
Steveman is offline   Reply With Quote
Old 12-26-2012, 01:03 AM   #29
Mikl Freeman OP
Spaceship Earth!
Oddometer: 39
Regards
Steve
Nice job.
Thank You Guys!! Your nice words are a great help for me!!!
Mikl Freeman screwed with this post 06-02-2013 at 05:02 AM
Old 12-26-2012, 01:32 AM   #30
Off the grid
Seeker of the Unf
Off the grid's Avatar
Oddometer: 11,556
I to your tenacity, ingenuity and skill in craftsmanship.
That BRP is gonna be a world-killer!
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Times are GMT -7.   It's 04:50 AM.
