Old 11-10-2012, 07:07 AM   #16
Dan Alexander OP
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,304
Is that cooling with a ? or cooling with a !
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 11-10-2012, 07:08 AM   #17
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,787
Originally Posted by Dan Alexander View Post
If you mean the separations in the disc, it's not from wear, it's made that way for some reason. Maybe keeps it lighter or more flexible?
Yep, that what I was referencing as I was unaware of OEM segmented discs (as was Anorak, apparently). When Steptoe called it a "standard disc" I figured he meant OEM, but I wondered if it was an aftermarket disc since it was segmented. Others here know more about that than me though.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 11-14-2012, 10:15 AM   #18
Dan Alexander OP
Oddometer: 7,304
Yesterday afternoon I dropped off the clutch parts at Ottawa Clutch and they will be ready this afternoon. Great service there.
They are using new organic friction material as the kevlar they have is too large for the little BMW disc. They will also reface both of the mating surfaces and check the spring pressure to make sure it's up to spec.
The total is a whopping $90 and it'll be as good as new as compared to buying the kit from BMW for over $800CDN
Old 11-14-2012, 10:23 AM   #19
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,527
If the spring isn't right can the reheat it or something to make it right? Or will you have to replace that part?
scooteraug02 is offline   Reply With Quote
Old 11-14-2012, 10:51 AM   #20
Dan Alexander OP
Oddometer: 7,304
Actually I never asked
He figured it was fine just by looking at it but I'll know more this afternoon.
Old 11-14-2012, 11:21 AM   #21
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,766
I'd like to know, as well.
def is offline   Reply With Quote
Old 12-06-2012, 02:09 PM   #22
Dan Alexander OP
Oddometer: 7,304
So here's the clutch plate resurfaced with new friction material and the other parts milled flat and bead blasted which all cleaned up nicely. $90 which I think is pretty reasonable as BMW wants $800CDN for a new set.
I'm trying to find the bolt tightening specs but I'm coming up empty, does anyone have the torque vales handy??
Old 12-06-2012, 02:19 PM   #23
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,796
Looks Great! Who surfaced the plates? I have a couple here I want to do!
Right out of the BMW 1150 OE Manual: Should be the same for the 1100 - M6 replaceable bolts?
Tightening torque:
Housing cover to flywheel ............................ 12 Nm
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 12-06-2012, 02:34 PM   #24
Dan Alexander OP
Oddometer: 7,304
I took Dirt Boy's advice in post 3 and took them to Ottawa Clutch, they did the whole job in one day. I guess if you mailed them in it wouldn't be too expensive and easy as it's still in Canada. If you want you can send them to me and I'll drop them off for you.
http://www.ottawaclutch.com/
The owner is a biker and we had a good chat, he's done a few BMW bike clutches already so he's familiar.
Thanks for the specs, now back to the garage!
Old 12-06-2012, 02:35 PM   #25
Dirt_Boy
Dirt_Boy's Avatar
Location: Adelaide, Australia Home of Coopers Pale Ale MMMMM
Oddometer: 229
Great deal on the new clutch
For more all my India pics go to
http://s908.photobucket.com/albums/a...dia/?start=620 and http://s808.photobucket.com/albums/z...202/?start=300
Get it India 2010
Dirt_Boy is offline   Reply With Quote
Old 12-06-2012, 05:02 PM   #26
Dan Alexander OP
Oddometer: 7,304
Thanks for the heads up on the local shop.
Old 12-06-2012, 05:55 PM   #27
def
def's Avatar
Oddometer: 9,766
Uh-oh...the clutch indexing marks are all gone....now whaddya gonna do?
This from my 2001 GS REPROM;
Clutch to crankshaft hub, lightly oiled screws (new screws), 40Nm initial, 32 degrees rotation.
Housing cover to flywheel, 12Nm.
A little dab of moly fortified grease where the spring contacts the pressure plate and housing.
Keep us informed about the performance of the new clutch...that's quite a savings.
Did they perhaps also balance the whole assembly?
Old 12-06-2012, 06:00 PM   #28
Dan Alexander OP
Oddometer: 7,304
I used an angle grinder cut a little slot in the edges to index the parts with a painted line I put on the flywheel. You can see one on the flexible tang right at the bottom of the pic.
Old 12-06-2012, 06:08 PM   #29
Dan Alexander OP
Oddometer: 7,304
Not exactly sure of your terminology ..... 'housing cover' are the 2 pressure plates with the clutch in between?
Old 12-07-2012, 08:54 AM   #30
def
def's Avatar
Oddometer: 9,766
Hopefully, this will clear it up.
http://www.maxbmwmotorcycles.com/fic...8&rnd=08102012
Times are GMT -7.   It's 03:13 AM.
