Old 12-04-2012, 09:00 AM   #6451
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,537
On the front of the shirt should be a rider with an ear to ear grin, on the back of the shirt should be a rider swinging a sledge hammer at the same machine.
Seth S
Seth S is online now   Reply With Quote
Old 12-04-2012, 09:37 AM   #6452
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
I'm glad you guys got the lemons. Both mine have been great.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 12-04-2012, 11:18 AM   #6453
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Well, we ride them off road more
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-04-2012, 11:47 AM   #6454
Seth S
Seth S's Avatar
Oddometer: 4,537
mine was good for the first 10,000 miles of racing and woods riding abuse. Then it popped the water pump seal and headgasket. I am not complaining.
Seth S
Old 12-04-2012, 12:16 PM   #6455
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
You are probably right. My tires never leave the pavement. I should have got a SM
Old 12-05-2012, 03:46 AM   #6456
NumNum
NumNum's Avatar
Oddometer: 11
Sweet pic Noah,
NumNum is offline   Reply With Quote
Old 12-06-2012, 06:51 PM   #6457
numbutt
john
numbutt's Avatar
Oddometer: 101
More on sidestand switch disable....
Ho-hum it must be winter in USA/north..threads are becoming mundane..!!.... thought id follow some others in disabling the sidestand switch...( in a slow quest to reduce ? the ocasional flame-out when racing to a stop )
Another inmate suggested a 1K to 3K resistor to repace the hall switch putting this resisror between the pink and black wires [ there are 3 wires going to the switch pink, black and blue ].
I did a few tests to ceate some understanding and what we have is a blue wire that supplies a regulated 5 Volts from the ECU to power the switch [ the switch is a Hall device [ linear response to a magnet ] coupled internally to a Schimdt trigger level detector that provide a snap action . [ hope im not boring anyone ]. Anyway, at ignition switch on, 5V is sent to blue and without the Hall connected the pink wire also reads 5 Volts. With the Hall switch in place and activated [ stand up ] the pink wire is locked down to 2.50Volts. Black is the earth wire or at earth potential [ 0 ].. I did a few tests to establish the ( voltage ) effect of adding the first mentioned resistor ''cheat '' to ''pull down '' the pink wire to about 2.5 Volts .
3.3K gives 3.02 volts
2.7K gives 2.78 Volts
2.2K gives 2.52 Volts [ test resistors between black and pink ]
1.8K gives 2.27 volts
1.5K gives 2.06 Volts
1.0K gives 1.6 Volts
After all this bull we must conclude that probably the best resistor to use is 2.2k { 2200 ohms } ...a standard value and i used a 1 watt metal oxide type [ most stable ] [ fortunately i carry many of every resistor 1 ohm ...1 Meg ohm at home so its an easy test !! ]
So after all that #&*@# , simply cut wires to stand above connector near shock, solder in 2.2 K ohms between Pink and Black, heat shrink it, then isolate and heat shrink off the blue so it cant short....and Bobs your uncle ....
numbutt is offline   Reply With Quote
Old 12-06-2012, 08:38 PM   #6458
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,144
great report but you lost me after "it must be winter in the USA/North"
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 12-06-2012, 09:41 PM   #6459
Seth S
Seth S's Avatar
Oddometer: 4,537
Call me lazy but I just bought a pre-made side stand switch and plugged it in.
Seth S
Old 12-07-2012, 12:04 AM   #6460
motoged
motoged's Avatar
Oddometer: 908
Yeah....I was gonna say that.
But some of these guys know how to make a simple job so effin complicated
Ged the Luddite
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 12-07-2012, 02:28 AM   #6461
ktmmitch
Oddometer: 626
3-Wheeler 690 Fun!!
We are currently working with Torque Racing on a customers very special machine.
It is a brand-new EML chassis that has been specifically designed to accept the KTM 690 Enduro engine,and we are currently working on manufacturing a new airbox,and silencer and radiator mountings to finish it off.
It had Reiger shocks all round,and the workmanship on the chassis is fantastic.
It will become a road-legal enduro machine,and I would love to have a go in it!!!
ktmmitch screwed with this post 12-07-2012 at 02:43 AM
ktmmitch is offline   Reply With Quote
Old 12-07-2012, 04:29 AM   #6462
LOZ
Oddometer: 1,209
its all happening at your place!!!!
LOZ is offline   Reply With Quote
Old 12-07-2012, 06:31 AM   #6463
Seth S
Seth S's Avatar
Oddometer: 4,537
fits the eariler bikes too?
Seth S
Old 12-07-2012, 06:33 AM   #6464
Seth S
Seth S's Avatar
Oddometer: 4,537
Ged the Luddite
I have learned over time that if someone has already taken the time to make a viable solution then it is often worth the cost of buying it vs the cost and time of creating your own solution. If there is no existing solution or the existing solution can be improved upon then its worth the effort.
Seth S
Old 12-07-2012, 08:34 AM   #6465
DirtJack
DirtJack's Avatar
Oddometer: 1,569
Most of us have used 2.2K ohm 1/4 watt resistor when disabling most any sensor/control. Seems to work well.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Times are GMT -7.   It's 08:54 PM.
