Old 12-05-2012, 06:19 PM   #1
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,261
R100 GS Oil cooler lines Question
Hi everybody,
looking to upgrade/replace the stainless lines on my gspd oil cooler. I have looked at the relocation kit from Touratech but really would just like new lines, probably aftermarket...partly for good looks and partly because mine have corroded quite a bit on the outside of the braiding with rusty grime and basic wear.
Any idea of the threading?
Could I buy a basic Pepboys aftermarket oil cooler line kit?
Does someone sell one already made?
Any help would be appreciated.
Any pictures of what youv'e done would be fantastic.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 12-05-2012, 06:40 PM   #2
Ullr
C+ Racing
Ullr's Avatar
Oddometer: 271
New lines are 125 from BMW. I have a lot of oil and hydraulic lines made locally and I doubt they could beat that price.
Ullr is offline   Reply With Quote
Old 12-05-2012, 07:28 PM   #3
bmwrench
Oddometer: 2,355
BMW's oil cooler uses a 16 X 1.5mm "Bubble Fitting" . This type of fitting is quite difficult to source and expensive.
bmwrench is offline   Reply With Quote
Old 12-05-2012, 08:12 PM   #4
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,393
Take your existing lines to any hydraulic place. They can disassemble the fittings & make up new hoses. I did that when I shifted the cooler off the crashbars & into a central position on the frame. Be aware that the fittuings into the cooler can get quite corroded. I thought I was going to trash my cooler getting them off.
I put on rubber hoses (they are braided internally). Given the use I have put the bike to (4WD tracks, gravel etc), these are better - easier to clean. The picture is just after installing. They fit better now, once I put proper clips onto them in order to route them more neatly.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 12-05-2012 at 08:23 PM
Box'a'bits is offline   Reply With Quote
Old 12-06-2012, 05:22 AM   #5
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,261
Excellent Boxabits
thank you for that and great pics. I actually have a lot of aircraft repair places around me of which many say hydraulic something or another so I would imagine thats a good resource for me.
Thanks a ton.
Mae West
Old 12-06-2012, 03:48 PM   #6
luxlogs
luxlogs's Avatar
Oddometer: 304
Another 50 bucks and your in Touratech Territory.
Pretty Sure the kit is $175
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
luxlogs is offline   Reply With Quote
Old 12-07-2012, 01:38 AM   #7
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,570
I;m pretty sure the Touratech lines are made by Motoren Israel in Germany so don't pay for the added mark up. If your local hydraulics shop can make you the proper lines cheaper then I would go that route.Remember your oil pressure go spike as high as 150 PSI.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 02-23-2013, 07:42 PM   #8
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Can you elaborate on the fittings on both ends? I would like to make up some SS lines for my RT cooler?
Les_Garten is offline   Reply With Quote
Old 02-24-2013, 10:07 AM   #9
bmwrench
Oddometer: 2,355
The banjo fittings at the thermostat are easy; you can buy two banjo adapters and straight hose ends or dedicated banjo hose ends for that location. The cooler ports are another story. I have found only one source for the bubble flares. These can also be had in an adapter and hose end or as a dedicated hose end. Oddly, the dedicated ends are available in black only. I have machined a hidden adapter but have not had a chance to test it.
Old 02-24-2013, 12:29 PM   #10
Les_Garten
Les_Garten's Avatar
Oddometer: 732
How hard would it be to change the fittings on the Cooler out to AN?
Old 02-24-2013, 12:57 PM   #11
bmwrench
Oddometer: 2,355
Funny you should ask. I bought weld on -6 male fittings to do just that, and consulted with my favorite welder about the idea. He was in favor of it, but since I was planning on retailing this conversion, I shelved them. It would have required cutting off the original fittings and welding on the A/N fittings without leaks.
So yes, I think it's possible.
Old 02-24-2013, 02:26 PM   #12
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Hmmm, would I just weld onto the current fittings, or saw them off or what? I obviously am looking for a relatively clean look. That doesn't leak of course!
<<This is my Airhead, there are many like it, but this one is mine>>
My "Orange Snappy Club" Membership Photo
Times are GMT -7.   It's 10:16 AM.
