Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 12-06-2012, 08:17 AM   #6031
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,394
tag
2000 7 Mile Rd New Philly
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 12-06-2012, 08:19 AM   #6032
rxcrider
rxcrider's Avatar
Oddometer: 1,310
Originally Posted by Danjal View Post
Got a dremel and freezer space? If so, cut that hole straight across so you can get a flat head on it. Hose it with penatrant. If it gives then, great. If not, freeze it,heat the alum around the bolt and try again.
Or dremel a centerline in it and use a punch to bend the bolt in the holes.
What dremel bit do you have that will do this? Their little carbide ones I've tried never seem to last long enough for a job of this nature. The bolt is broken off below flush, so a cut off wheel won't work.
Matt - I don't know if Ed center punched it first, but he was trying to drill it in the frame to get the exhaust off so he could pull the head. Between the down tube of the frame and the header, he didn't really have a chance of drilling straight. I'm sure he now realizes he would have been better off using a bigger drill bit to remove the head and then dealing with the remaining stud afterwards, but hindsight is how we get experience. Or at least it is how I get most of mine. Looks kind of like this
'95+'95+'96 BMW R1100RS/RSL
AMA, OMTA (ohio organization), BRC, BMWMOA
rxcrider is offline   Reply With Quote
Old 12-06-2012, 10:19 AM   #6033
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,673
Tc bits. Slow em down and use oil. Heat seems to kill them. At this point he can use a drill bit for most of it then finish with the dremel. The main point is to get gap in there so the metal has room to be moved inward off the threads. He could cheat and just drill and retap into a sae size too. Probably faster too.
Danjal is offline   Reply With Quote
Old 12-06-2012, 11:15 AM   #6034
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,765
Now that the engine is out and there is room to work, why not try drilling for an easy out again? Without the frame and header pipe in the way you should have a much better chance of success. Start with a punch/drift to center the hole, then drill slow.
muddyrabbit is offline   Reply With Quote
Old 12-06-2012, 12:23 PM   #6035
rxcrider
rxcrider's Avatar
Oddometer: 1,310
slow and oil - will do next time I have need to use one. I was treating them like the larger ones I have for the die grinder. Guess they didn't like WOT & dry.
Old 12-06-2012, 01:32 PM   #6036
edhead
Oddometer: 186
Exhaustboltageddon
Fosnaught Auto in North Canton succuessfully extracted my broken exhaust bolt. Price was $42.50, which seems like a fair price to me.
So you all can go back to your regularlly scheduled ADV programming. I'll see what else I can muck up during the reassembling process.
Thanks for all the ideas, I enjoy hearing people's solutions to problems.
edhead is online now   Reply With Quote
Old 12-06-2012, 01:40 PM   #6037
rxcrider
rxcrider's Avatar
Oddometer: 1,310
Ed, are you using a helicoil / insert or re-using the existing threads in the head?
Old 12-06-2012, 02:17 PM   #6038
edhead
Oddometer: 186
Haven't picked it up, but I am pretty sure there is no helicoil.
Find out tomorrow exactly what was done.
Old 12-06-2012, 08:26 PM   #6039
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,172
3 part Adv Bike test
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 12-07-2012, 04:01 AM   #6040
ThomasVolomitz
New Old Stock
Oddometer: 4,394
Europe is full of old adventure bikes, not so here. Going to go place a new tag and see is my waterproof gear is actually what it says.
Still Riff Raff
Old 12-07-2012, 04:36 AM   #6041
muddyrabbit
Lost Boy
Oddometer: 3,765
Is it me or does the Tenere in that video look like a TDM with wire wheels?
Old 12-07-2012, 05:05 AM   #6042
ThomasVolomitz
New Old Stock
Oddometer: 4,394
next
On a 3 digit state route that adds up to 12.
Still Riff Raff
Old 12-07-2012, 06:08 AM   #6043
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,172
Does that happen to be buy a hunk of concrete (may be gone now) with lots of paint on it?
Michael
Old 12-07-2012, 07:13 AM   #6044
ThomasVolomitz
New Old Stock
Oddometer: 4,394
I think its a wooden sign.
Still Riff Raff
Old 12-07-2012, 08:05 AM   #6045
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,673
They're horrid compared to 1/2" die grinder bits. If I could find a dremel bit half as effective as the bit my dad has,I'd buy a dozen.
Times are GMT -7.   It's 03:36 PM.
